What we got here is something that you can add on to the current Stock 4.4.2 183.46.1X.xt907 update.
Advance Power menu allowing you to use without the need for Xposed framework. There will be some additional addons to this section, but with the limit of
Time it will not be in a fast pace as normal updates. Hope that you enjoy...
Screen Teasers...
All things that I needed to accomplish these features
were found from below links. Thanks goes to the guys for these guide.
Advance Power Menu
http://forum.xda-dev...covery-t2446597
Installation Instructions.
ROM must be Deodexed......(See HERE for the Stock Zip)
Place update on internal Storage
Boot into Recovery
Apply update without any wipes.
Reboot into System and Enjoy......
The Goods
If you like my Work
