My XT910 doesn't boot/recover after running ClockworkMod
xt910 cwm
7 replies to this topic
#1 kuramayoko10
kuramayoko10
  • 6 posts
Posted 10 September 2014 - 01:48 PM
I was preparing my phone (Droid Razr XT910) to upgrade it to Android 4.4 (
It was currently at version 4.1.2.
This is what I did:
1. Rooted the device
2. Used RootChecker as well as Vodoo OTA Rootkeeper to check if the root was really successful
3. Installed RazrTouchBlack to run ClockworkMod Recovery (version 5.8.4.5)
-- everything so far as specified here:
4. On step 6 from the above link, I got an error message at the end: "could not backup Data"
5. So I tried the option Backup into Internal Storage. This time the backup completed succesfully
7. I selected Reboot now
-- Description of problem below
8. At reboot I get a screen saying "Error on coding" and explaining that the system could not find my files and that I had to restore it.
9. After pressing Restore, it reboots and goes to a screen with the green Android and a progress bar.
10. It finishes its work and shows Motorola Logo
11. It gives the same "Error on coding" message
12. i tried booting into Recovery Mode and it says: "DEVICE LOCKED: status 0"
I didn't go any further. What should I do next?
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 10 September 2014 - 02:26 PM
If your bootloader is not unlocked, you won't be able to load a recovery.  It's a 910, so you should be able to unlock.  Unlock, then load the recovery.
#3 kuramayoko10
kuramayoko10
  • 6 posts
Posted 11 September 2014 - 07:21 AM
I tried unlocking the Bootloader following
However the command outputs an error message: FAILED (remote: unsupported command)
I checked on another
from Motorola, and it does not list the Droid Razr (XT910) as a unlockable device =/
What should I do?
I checked and saw that CWM is no longer installed on my device.
Is it possible to reinstall it and flash a new ROM?
Or ist it possible to flash a new ROM at all?
#4 kuramayoko10
kuramayoko10
  • 6 posts
Posted 11 September 2014 - 07:34 AM
I am willing to follow this guide:
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 September 2014 - 07:52 AM
I stand corrected, I thought the 910 could be unlocked but everything I've found says it can't. :( With that being said, you won't be able to load CWM. You'll need to use SafeStrap. However, I know very little else about the 910, so I won't be able to provide help for ROMs, etc. You can use the House of Moto to restore your phone to stock, though.
XT910 forum:
#6 kuramayoko10
kuramayoko10
  • 6 posts
Posted 11 September 2014 - 08:26 AM
Ah, I hadn't found the XT910 discussion forums. Thank you very much!
#7 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 11 September 2014 - 09:29 AM
Yeah, they've been put into "Legacy Devices."  Good luck.
#8 livinginkaos
Posted 11 September 2014 - 12:25 PM
Note - Topic moved to a more appropriate location.
  • RikRong likes this
Also tagged with one or more of these keywords: xt910, cwm
