* * * * * 2 votes
[FXZ] 4.4.2 183.46.15
87 replies to this topic
#1 SamuriHL
  • 44,414 posts
Posted 10 September 2014 - 05:03 AM
WARNING: You REALLY need to UNDERSTAND and read EVERYTHING or you MAY brick your phone!
IF YOU HAVE NOT UNLOCKED, THIS BUILD WILL PREVENT YOU FROM DOING SO.  STOP NOW and GO UNLOCK!
Purpose of this thread:
To get you, the locked or unlocked RAZR M XT907 owner, from any version to 4.4.2 (KDA20.62-15.1).
Things you will need:
FXZ
Instructions:
Use the
 with KEEP DATA to flash this to your phone with RSD.
OR
Use the
 with KEEP DATA to flash this to your phone with fastboot.
This will get you a clean OTA install with no data loss.  ---> You will lose root. <---
SUPPORT:
Q: My RAZR HD or M is stuck in AP Fastboot mode with a sticky bit failure.  Help?
A:
  Follow that.
  • ZKK007, livinginkaos, miss_sticks and 7 others like this
#2 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 11 September 2014 - 01:35 PM
What has been changed in this update?
Need Help? Send me a message
#3 Donald21413
Donald21413
  • 23 posts
Posted 13 September 2014 - 10:32 AM
Any way for unlocked users to keep root after this one?
#4 SamuriHL
  • 44,414 posts
Posted 13 September 2014 - 10:46 AM
Unlocked users ALWAYS have a way to install root.  Flash TWRP or CWM, then flash SuperSU zip.
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 13 September 2014 - 02:01 PM
Go
to get latest SuperSU zip
Also this thread should be pinned :)
#6 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 13 September 2014 - 06:07 PM
According to VZW, security updates (TR and Motopocalypse) and a stability update for the messenger app. Essentially, they fixed the exploits and pushed it. Lol.
Sent from my RAZR M (Team Gummy Nightlies) from Tapatalk Pro.
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
#7 roaoro
roaoro
  • 17 posts
  • Current Device(s):Razr M
Posted 14 September 2014 - 02:07 PM
FYI, Upgraded via OTA on my unlocked razr m, and I did not lose root or custom recovery.
#8 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 14 September 2014 - 02:47 PM
Did the same on my daughter's m. Kept root and custom recovery.
Taped from my Moto X Dev
#9 CWM8012
CWM8012
  • 25 posts
  • Current Device(s):Xt907
Posted 15 September 2014 - 03:47 PM
If I want a clean install, could I do a full install instead of using keep data?
#10 livinginkaos
Posted 15 September 2014 - 03:59 PM
Yep, that will erase data. Be like out of the box.
sent from my G3
#11 netizenmt
netizenmt
  • 150 posts
Of course. However, as has been stated several times, if you want to be able to root, go back to a previous version or install custom ROMs, or you think there is the remotest possibility you may want to, unlock your bootloader BEFORE you update to .15. Otherwise, you will not be able to undo the upgrade to .15.
#12 Jhordan3h
Jhordan3h
Posted 18 September 2014 - 12:31 AM
Sorry, I'm new to the group, I am not clear about whether you can or can no longer be root when upgrading to 183.46.15, it is impossible to be root with the new update? Because I did flash with 183.46.15 from scratch and now I can not root nor towelroot. Thank you.
#13 livinginkaos
Posted 18 September 2014 - 04:05 AM
if you are unlocked, you can root thru custom recovery regardless. If you are not unlocked and flashed the 15 build, there is no root for you.
sent from my G3
#14 Jhordan3h
Jhordan3h
Posted 18 September 2014 - 09:08 AM
Then you can either downgrade to the .10 build ??
#15 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 18 September 2014 - 09:26 AM
no
#16 SamuriHL
  • 44,414 posts
Posted 18 September 2014 - 10:08 AM
If only there were some warnings in the OP....
  • syuyo, RikRong, xKroniK13x and 3 others like this
#17 zekemo
zekemo
Posted 18 September 2014 - 10:45 AM
Sam. I didn't want to pester you with a PM but I just wanted to thank you for your work on the xt926. I ran into the trustzone 11 error and found a solution in your thread on other forum. Thanks for your patients with the others too; there were some ridiculous posts you endured. I unlocked last night and do not regret it, even with the limited ROM development we still have some solid choices. Anyway, thanks for your time and effort.
  • SamuriHL likes this
#18 syuyo
syuyo
Posted 23 September 2014 - 12:58 AM
hi i flashed this FXZ and now im trying to flash twrp via fastboot commands but i keep getting <bootloader> variable not supported. i have no idea how to use fastboot to flash it ive looked online and to no avail i cannot get it to flash. i flashed it with flashify on the previous OTA but i cant do that without root now.
i am unlocked.
edit: I dont know what happened i just kept on flashing it and somehow it took. now to figure out what sideloading is to install superuser....
#19 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 September 2014 - 06:15 AM
i am unlocked.
Sideloading is just downloading to your external SD. Find the Superuser thread on XDA, DL the .zip, save it to your SD, and flash in recovery.
SuperSU:
#20 SamuriHL
  • 44,414 posts
Posted 23 September 2014 - 06:30 AM
SuperSU:
Small correction.  Sideloading is NOT copying it to your external SD.  That is a different process.  Sideloading involves using ADB from recovery and pushing the zip from your PC to the device directly.  For example, my unlock root tool uses sideloading to load SuperSU and it does so by walking the user through loading recovery, setting it up for ADB sideload mode, and then it pushes SuperSU with a:
adb sideload <supersu zip filename here>
Sideloading is confusing to many people which is why I wanted to make the correction.
  • livinginkaos, syuyo and RikRong like this
