[Recovery] Safestrap Recovery V3.1 [01/04 3.12 - Stock Flashing+] [All Versions]
121 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 15 November 2012 - 04:52 PM
SAFESTRAP v3.12 (2nd-System Bootstrap / Recovery)
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. Always have a fastboot available for disaster recovery. **
md5sum: 46032557a37e5df7c73ab982810c6a39
FOLLOW THESE INSTRUCTIONS:
CHANGES:
  • [01/04] (3.12) Fix initial file selector location for backup/restore
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions. * STILL TESTING -- BUGGY*
  • [12/29] (3.10) Enable flashing to stock ROM
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
  • [10/17] (3.05) Fixed SD card / emmc sharing in recovery (UMS)
  • [10/17] (3.05) Fixed recovery installation/removal from ROM-slots
  • [10/14] Updated to v3.04 BETA.
  • [10/14] Recovery is now based off TWRP 2.2.2.1 (fully featured touch-based recovery)
  • [10/14] Can create up to 4 Virtual ROM-slots to flash ROMs to and when "Active" ALL TWRP functions affect that ROM-slot (For example: Flashing .zips, Backup and Restore)
  • [10/14] Nearly instant swapping from ROM to ROM
  • [10/14] User selectable data partition sizes during ROM slot creation: 1GB, 2GB or 3GB
  • [10/14] ROM slots are saved on the internal emmc space so that preinstall and webtop partitions are no longer used and shouldn't break OTAs.
  • [10/14] Charging in recovery
  • [10/14] Supports "Reboot Recovery" from Android OS
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery.
SPECIAL THANKS TO:
  • The entire TWRP team who has built an AMAZING recovery system.
  • The testers which have helped in past and present versions of Safestrap, knowing that it could mean they brick their devices.
As always, let me know what you think!
  • mhous33, marxman3 and wapiti_j like this
#2 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 15 November 2012 - 04:54 PM
RESERVED
#3 got556
got556
  • 452 posts
  • Twitter:@got556
  • LocationChicago
Posted 15 November 2012 - 04:55 PM
WTG Hash! Will be running this on my g/f's M.
#4 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 15 November 2012 - 06:54 PM
OP Updated with PAID APP FIX (3.05.19)
md5sum: 3e0c2a531b5c535b64abb5f1d544de7f
#5 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 15 November 2012 - 08:20 PM
THANK YOU!!!!!!!
#6 marxman3
marxman3
  • 290 posts
Posted 16 November 2012 - 09:22 AM
When I go into recovery it does not load my sd card (internal or external) so I don't have an option to flash the new CM10 build and start working on getting a ROM out. What am I doing wrong?
Edit - or I can take a minute and look through the files and see it is just listed under a different name than SS for the OG Razr.......my bad
#7 Trylek09
Trylek09
  • 57 posts
  • LocationUSA - East Coast
  • Current Device(s):Razr M
Posted 16 November 2012 - 10:11 AM
Got it up and running on my Razr M (official JB ota) with no problems at all! Thanks Hash! You are truly the king of code!
Love the new look!
#8 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 20 November 2012 - 09:38 AM
New bugfix version of Safestrap for RAZR-M (3.05.20) is ready for download.
The main changes center around making sure your stock ROM's "/data/media" (sdcard) is available in Safestrap no matter what rom-slot is active. Also, making sure it's mounted correctly for ROMs which are installed on the rom-slots (as opposed to mounting the ROM's /data/media).
#9 NattyBee
NattyBee
  • 647 posts
Posted 20 November 2012 - 07:28 PM
Thanks brother! You rock!
Sent from my DROID RAZR M using Tapatalk 2
#10 Trylek09
Trylek09
  • 57 posts
Posted 26 November 2012 - 07:46 PM
<3 Hash
#11 Mazer
Mazer
  • Google+:gplus.to/mazer
Posted 27 November 2012 - 11:01 AM
Hey, Hashcode, I just bought a RAZR M, and would like to start development on it (I was developing for the Thunderbolt before.) Do you have a github or something for your CM 10 build? Working from scratch wouldn't be very fun, and developers working together is always nice. Credits will go to you, of course.
Edit: I found your github -- Googleing first should always be done, silly me. Do you mind if I fork your repos?
Mazer
#12 Squeaky192
Squeaky192
  • 12 posts
  • Current Device(s):RAZR M
Posted 23 December 2012 - 11:24 AM
Hate to post in here, but I can't find anything after searching.
Just rooted, installed safestrap and everytime I open it I get "Unfortunately , Safestrap has Stopped."
Any workaround for this? I've tried multiple .apks and nothing.
#13 rickw
rickw
    corvette dude
  • 1,951 posts
  • Google+:rickwebb001@gmail.com
  • LocationDelaware
  • Current Device(s):S4 dev edition,moto x dev,Nexus 6
Posted 23 December 2012 - 11:26 AM
did you install a rom?
#14 Squeaky192
Squeaky192
  • 12 posts
Posted 23 December 2012 - 11:27 AM
I haven't even got that far. Safestrap literally won't open.
#15 rickw
rickw
    corvette dude
  • 1,951 posts
  • LocationDelaware
Posted 23 December 2012 - 11:28 AM
sorry,did you install recovery?
#16 rickw
rickw
    corvette dude
  • 1,951 posts
  • LocationDelaware
Posted 23 December 2012 - 11:31 AM
#17 Squeaky192
Squeaky192
  • 12 posts
I can't get that far. The APP force quits. I'm running the JB leak, but I doubt that has anything to do with it.
I've seen the same issue with others, but never a resolution in other threads.
#18 rickw
rickw
    corvette dude
  • 1,951 posts
  • LocationDelaware
Posted 23 December 2012 - 11:32 AM
when you try to open app it f/c's ?
#19 Squeaky192
Squeaky192
  • 12 posts
Posted 23 December 2012 - 11:33 AM
Yes. Tried multiple apks and installed the same, but the app won't open.
#20 rickw
rickw
    corvette dude
  • 1,951 posts
  • LocationDelaware
Posted 23 December 2012 - 11:34 AM
did you remove old safestrap
