[Rom - 4.1.2] - [Toro/maguro] - Kang - Liquid Smooth Rc7 - Fornicated (Dark) Ui Edition
liquid smooth kang rom
1 reply to this topic
#1 JayR_Themer
JayR_Themer
    Themer
  • 10 posts
Posted 10 November 2012 - 11:16 AM
LIQUID SMOOTH RC7 KANG FORNICATED (DARK) UI EDITION
ANDROID 4.1.2 JZO54K
WHAT'S INSIDE:
- Everything Liquid Smooth RC-7 has plus more!
- Dark themed UI
- Blacked out Contacts/People app
- Blacked out Email
- Blacked out Mms
- Travp624's awesome Mms native self-theming options
- Dark themed Caclulator
- Themed Keyboard
- Removed status bar notification tinting (annoying)
- Blue themed lockscreen sliders with nice drop shadow
- Completely source built
- Zipaligned/Optimized for peak performance
NEW FORNICATIONS FOR RC-7
- Status bar expanded clock and date now blue
- Statusbar expanded network now blue
- Activity picker now uses dark theme(thanks travp624!)
- Status bar network mode blue
- Wallet lock screen targets now blue
- New calculator button style
- A few minor graphical bug fixes
G-APPS--
- Any Gapps packacge will likely work. Some may not auto restore market apps. Auto restore is not a ROM feature. I recommend travp624's all in one Gapps located here
These complete the the Fornicated (Dark) UI theme, and auto restore works!
- As for the Calendar.apk, I have not done anything with it. It is a finicky app. Some Gapps packages contain a different named Calendar apk, and some dont contain one at all. So after you flash and setup this ROM, visit travp624's inverted apps thread and install the calendar apk. You may have 2 calendar apk's after that. Delete the non inverted one. If not, disregard.
OTHER INVERTED APPS -- ALL CREDIT TRAVP624
RECOMMENDATIONS--
- Highly recommend a clean install. If you don't, please do so before reporting bugs. Thank you.
- Highly recommend you install Trinity Kernel. The color contrast is amazing, and performance/battery life has been great for me as well. You can grab it here
- Another great new kernel is Zen Kernel by bbedward and team ADA. You can find it on any of the popular forums.
CREDITS--
- Liquid Smoooth ROM's / CM for the base of this ROM
- travp624 for his inverted sources to refernce and awesome native Mms theming options!
- TheShamrock7 for testing and feedback
- Google for open source of course!
- dan96815 for maguro testing, thanks a ton bro!
INSTRUCTIONS--
- DOWNLOAD ROM TO PHONE STORAGE
- REBOOT RECOVERY
- WIPE DATA/CACHE/DALVIK - HIGHLY RECOMMENDED
- FLASH ROM
- FLASH G-APPS
- BOOT UP
- ENJOY VISUAL FORNICATIONS
SCREEN SHOTS -- Not yet updated for rc7, much the same however.
TORO ROM DOWNLOAD--
MAGURO ROM DOWNLOAD--
#2 JayR_Themer
JayR_Themer
    Themer
  • 10 posts
Posted 10 November 2012 - 11:17 AM
EXTRA STUFF--
-4.2 Keyboard Fornicated-
-Revert lock screen to stock-
TORO
MAGURO
Also tagged with one or more of these keywords: liquid smooth, kang, rom
