Moto XT925 got bricked , no backups, usb not communicating with PC
XT925 bricked droidgurus
24 replies to this topic
#1 gorkhe12
gorkhe12
Posted 31 August 2014 - 01:41 PM
I tried to update my working MotoXT925 with the latest CM Mods but on the process I screwed up pretty badly. My backup did not worked properly and I think I flashed wrong firmware after which phone stopped communicating with PC.
Issue looks like I have either deleted the firmware so bad or flashed the wrong version. fastmode and adb does not work. It gives ..waiting for device... message only in the windows command terminal if I try some fastboot commands. It does not go to recovery mode also when I press volume keys. The green led light comes for sometime and it goes away when I try to get into recovery mode.
So my question to all guru out there how to give a new life to my cellphone , any suggestions, ideas or help are greatly appreciated.
thanks
gorkhey
#2 johnthehillbilly
Posted 31 August 2014 - 01:47 PM
Can you even boot the phone into fast boot ?
HD tapadriving..... hillbilly style!!!
#3 gorkhe12
gorkhe12
Posted 01 September 2014 - 05:35 AM
Nope , there is a green led light when connected to PC. I think its hardbricked.
#4 SamuriHL
  • 44,534 posts
Posted 01 September 2014 - 06:57 AM
Does it show up on the PC as qhsusb_dload?
  • hbang likes this
#5 pirloui
pirloui
  • LocationFrance
Posted 10 September 2014 - 05:48 AM
hello,
I have the same problem and actually indicates qhsusb_dload.
#6 SamuriHL
  • 44,534 posts
Posted 10 September 2014 - 05:51 AM
Then it's permanently bricked.  Since the files required to fix it have never been leaked, at the moment there's nothing you can do about it.
  • hbang likes this
#7 pirloui
pirloui
  • LocationFrance
Posted 10 September 2014 - 06:41 AM
thank you for your answer, despite the bad news;-)
#8 hbang
hbang
  • 8 posts
Posted 22 November 2014 - 03:51 AM
reposted  on House of Moto
#9 Dssj
Dssj
  • 8 posts
  • LocationPrague, Czech
  • Current Device(s):Motorola Droid RAZR M
Posted 28 November 2014 - 12:39 AM
I heard that the phone can be forced to boot to fastboot by Motorola factory cable
Sent from my Motorola DROID RAZR M
#10 bataglia
bataglia
  • 11 posts
Posted 21 March 2015 - 05:07 PM
I know it's an old thread, but its almost exactly my issue: my computer just recognizes my razr HD on the recovery mode, I can enter the fastboot, but since I can't wipe the /data, I couldnt install the stock rom properly. Is there anything I can do to save my razr?
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 22 March 2015 - 03:02 AM
Since you can get into fastboot, go here and follow the instructions carefully:
[4.1] . Make sure your battery is charged, before you try anything, though.
  • bataglia likes this
#12 bataglia
bataglia
  • 11 posts
Posted 22 March 2015 - 04:22 AM
I will read it carefully and hope it saves me
Thanks!
#13 bataglia
bataglia
  • 11 posts
Posted 22 March 2015 - 04:53 AM
No success, I already got stucked in the first step. adb devices while on fastboot mode after reinstalling usb drivers showed me no devices at all.
#14 SamuriHL
  • 44,534 posts
Posted 22 March 2015 - 05:00 AM
Of course it doesn't. Adb doesn't work on fastboot mode. Use fastboot to show the device.
#15 bataglia
bataglia
  • 11 posts
Posted 22 March 2015 - 05:39 AM
Okie, I'll try it
Edit 1: worked like charm, thanks! Now proceeding to the next step :p
Edit 2: this is my situation: I tried to install cyanogenmod, but it couldn't wipe the /data stuff. So I ended up with a boot loop about inconsistent UID stuff, and "error mounting /data" (now fixed).
I couldn't find the firmware for my xt925 on firmware.center, but I got a 628mb one in xda. Will it work?
#16 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 22 March 2015 - 08:41 AM
Okie, I'll try it
Where did you find the original FW you used?
#17 bataglia
bataglia
  • 11 posts
Posted 22 March 2015 - 08:55 AM
The Vivo Brasil one.
#18 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 22 March 2015 - 09:57 AM
Looks like good files to me. I believe those are the same guys that ran the SBF website.
#19 bataglia
bataglia
  • 11 posts
Posted 22 March 2015 - 12:11 PM
Just a question: do I need to be 100% sure it is the same firmware that came with my cellphone or just being from the same model/vendor is ok? I mean, mine is a XT925 from Vivo, but now I found on motofirmware center, I noticed there are 2 firmwares: 7.7.1Q-144_VQL_S3-49 and 9.8.2Q-50-XT925_VQLM-20_Vivo_BR_VANQJBVIVBRLA_S1FF. How do I know which one is the correct firmware?
#20 SamuriHL
  • 44,534 posts
Posted 22 March 2015 - 12:24 PM
Flashing the wrong thing is a good way to brick a device so you should be careful.  Finding the correct firmware can be a chore.  I'm not able to help on that issue.
Also tagged with one or more of these keywords: XT925, bricked, droidgurus
