Safestrap Is Disabled How Do I Fix This?
16 replies to this topic
#1 Pego99
Pego99
  • 99 posts
Posted 09 November 2012 - 04:26 PM
I installed safestrap using the 1.82 razr utility here. I installed the recovery state with the safestrap app. Safestrap app says recovery state installed safe system not active?
When I restart the phone and hit the menu button a very very light screen starts saying safestrap is disabled and system will start in 10 seconds and the phone starts normally.
How can I fix this?I have a Razr Maxx running 4.0.4. Please help.
#2 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 09 November 2012 - 05:06 PM
You need to touch the menu key when the very light screen starts saying safestrap is disabled to get into recovery then set up a new rom slot, then activate the new rom slot and flash your rom of choice then safestrap will be enabled.
For more info check this out:
  • ITSBRYANN and lowtyde like this
#3 Pego99
Pego99
  • 99 posts
Posted 09 November 2012 - 05:15 PM
When I touch the menu key a screen appears saying bootstrap is disabled and then the phone starts normally. Safestrap is there but disabled. That is my problem.
#4 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 09 November 2012 - 05:19 PM
are you hitting the menu key before that screen comes up?
#5 Pego99
Pego99
  • 99 posts
Posted 09 November 2012 - 05:25 PM
I was so now when I see the disabled screen I hit the menu button and safestrap started voila. Thanks. So please explain when do I hit the menu button? I got it to work but not sure the correct way?
#6 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 09 November 2012 - 05:35 PM
You need to let it start to boot then that screen will come up on its own, once it comes up hit the menu key and it will take you to recovery.
#7 Pego99
Pego99
  • 99 posts
Posted 09 November 2012 - 05:51 PM
Ok. When I do that I get the menu with 9 choices but it says safestrap disabled at the top and no boot menu choices?
#8 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 09 November 2012 - 05:58 PM
What version of safestrap did you install.
#9 Pego99
Pego99
  • 99 posts
Posted 09 November 2012 - 06:03 PM
ver 2.11
#10 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 09 November 2012 - 06:12 PM
ver 2.11
Ok download
which is a huge update to the version you are currently running then follow the
before you install and you should be set. let me know if you run into any issues
#11 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 09 November 2012 - 08:58 PM
ver 2.11
Did you get it working yet?
#12 Pego99
Pego99
  • 99 posts
Posted 10 November 2012 - 06:21 AM
Thanks. Yes I did but I am thinking about going to version 3.05 of SS. Is 3.05 as good as 2.11?
#13 Pego99
Pego99
  • 99 posts
Posted 10 November 2012 - 07:05 AM
Ok I installed 3.05 and want to do a backup. The backup section makes the cache and .android security backup OPTIONS. Are they necessary to include?
#14 ITSBRYANN
ITSBRYANN
  • 90 posts
  • Twitter:itsbryandude
  • LocationNC
Posted 15 November 2012 - 05:39 PM
ss 3.05 hasyour stck rom already backed up. keep a nandroid backup, but flashing is simple with safestrap3.0.5
rooted RAZR runnin HDish black widow Jellybean
#15 Nyuielisco
Nyuielisco
  • Google+:marcelinho
  • Current Device(s):droid razr utility
Posted 28 June 2016 - 09:32 PM
Ok download
#16 Nyuielisco
Nyuielisco
Posted 28 June 2016 - 09:40 PM
Hello please I have the same problem with Safestrap disabled.I've installed Android 6.0.1 on my Droid Rarz Xt912 and I accidentally deleted the Safestrap folder in Es file manager and the phone is rebooting saying that safestrap disabled.Please I don't know how to do? Help me to reactive Safestrap.
#17 Nyuielisco
Nyuielisco
Posted 28 June 2016 - 09:41 PM
