Hello There Need Help Big Time Phone Not Working At All
3 replies to this topic
#1 hooperb63
hooperb63
  • 6 posts
Posted 07 November 2012 - 05:17 PM
Hello there i need help please ive unlocked bootloader and i rooted my razr i and i had problems gettng clockwork recovery on there. anyhow i fastbooted the clockwork recovery file on there and that didnt work. kept failing. then all of sudden my stock recovery wouldnt work. i kept trying and eventually got in to it. i deleted cache and factory recovery and now every time i try to do anythink bootloader loads up every time phone wont even turn off just keeps loading up the bootloader screen every time. so its obviously the system file has gone. but everytime i try to put a fasboot file on there fastboot flash system then file.zip it sends the system over and says sending on cmd and even says multiflashing system and download on my phone about 4-5 times then it says finished on cmd but my phone still displays multiflashing system and just seems to get stuck. please help i have no phone at the moment!!!
also dont know if it helps but when i reboot it says
fastboot reason: boot failure
fastboot max download size 100mb
usb connected
at the top in white says ap fastboot flash mode (secure boot)
20.0D (sha - 0ba4df3)
IFWI Info: 42.19
emmc INFO: size 8gb
barcode n/a
battery (okay) :3.78v temp 36.0
transfer mode - usb connected
rom-key Motorola-key
THEN BLUE
NORMAL POWERUP
RECOVERY
FACTORY
BP TOOLS
SWITCH CONSOLE DEFAULT: NULL
POWER OFF
PLEASE HELP THANKS.
#2 hooperb63
hooperb63
  • 6 posts
Posted 07 November 2012 - 06:47 PM
resolved jp004 did it for me thanks jp ur a star!! :-)
#3 dunnkel
dunnkel
Posted 01 December 2012 - 07:51 AM
Hello
How do you solved it? I have the same problem
#4 jaylonimran
jaylonimran
Posted 27 January 2013 - 02:22 AM
You could get instant resolution for unlock a phone.
You can even examine over samsung unlocking
