[Recovery] Safestrap Recovery V3.1 [01/04 3.12 - Flash Stock+] [All Versions]
5 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 07 November 2012 - 01:02 PM
SAFESTRAP v3.12 (2nd-System Bootstrap / Recovery)
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. Always have a fastboot available for disaster recovery. **
md5sum: 9b3d75e84c06d1e71af1bf1bad57faf3
FOLLOW THESE INSTRUCTIONS:
NOTES:
  • ROMS based on Android 4.2.1 *MUST* go into rom-slot1 currently. This will be fixed in the future.
CHANGES:
  • [01/04] (3.12) Fix initial file selector location for backup/restore
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions. * STILL TESTING -- BUGGY*
  • [12/29] (3.10) Enable flashing to stock ROM
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
  • [10/17] (3.05) Fixed SD card / emmc sharing in recovery (UMS)
  • [10/17] (3.05) Fixed recovery installation/removal from ROM-slots
  • [10/14] Updated to v3.04 BETA.
  • [10/14] Recovery is now based off TWRP 2.2.2.1 (fully featured touch-based recovery)
  • [10/14] Can create up to 4 Virtual ROM-slots to flash ROMs to and when "Active" ALL TWRP functions affect that ROM-slot (For example: Flashing .zips, Backup and Restore)
  • [10/14] Nearly instant swapping from ROM to ROM
  • [10/14] User selectable data partition sizes during ROM slot creation: 1GB, 2GB or 3GB
  • [10/14] ROM slots are saved on the internal emmc space so that preinstall and webtop partitions are no longer used and shouldn't break OTAs.
  • [10/14] Charging in recovery
  • [10/14] Supports "Reboot Recovery" from Android OS
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery. SPECIAL THANKS TO:
  • The entire TWRP team who has built an AMAZING recovery system.
  • The testers which have helped in past and present versions of Safestrap, knowing that it could mean they brick their devices.
As always, let me know what you think!
  • droid69 likes this
#2 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
RESERVED FOR FURTHER INSTRUCTIONS
#3 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
  • LocationLa Rioja - Argentina
Posted 07 November 2012 - 09:47 PM
Woww awasome, very thanks :0
Enviado desde mi HTC Sensation XE with Beats Audio Z715e usando Tapatalk 2
Firmware Team: Kent_lkc - Kwachu - daywalker04 - Pzyduck - Skrilax_CZ - toto221
#4 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 15 November 2012 - 06:50 PM
OP Updated with PAID APP FIX (3.05.16)
md5sum: e0590ed7e4f9799c323cf6e5a5e8f86a
#5 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 20 November 2012 - 09:40 AM
New bugfix version of Safestrap (3.05.17) is ready for download.
The main changes center around making sure your stock ROM's "/data/media" (sdcard) is available in Safestrap no matter what rom-slot is active. Also, making sure it's mounted correctly for ROMs which are installed on the rom-slots (as opposed to mounting the ROM's /data/media).
#6 tinchoska
tinchoska
Posted 21 January 2013 - 01:16 PM
Is it possible that, when i try to do full wipe on personal argentina firmware safestrap told me that didnt do wipes?
Enviado desde mi XT925 usando Tapatalk 2
