[Recovery][Locked Devices] Safestrap Recovery V3.1 [01/04 3.12 - Stock Flash +] [All Versions]
219 replies to this topic
#161 chudze
chudze
  • 6 posts
Posted 25 November 2012 - 04:32 PM
I installed the safestrap, it shows recovery state installed, and safe system not active. when i shut off the phone and restart, it restarts normally with no special screen. I have the razr HD. can someone help me, i would like to try and install a rom.
#162 megahertz1970
megahertz1970
  • 228 posts
  • Google+:markw4itg@gmail.com
  • LocationPiscataway, NJ
Posted 27 November 2012 - 07:49 AM
I think this version of safestrap is really cool but I don't like the fact that you only have 3GB of internal storage. With that being said is there a safestrap V2 for the Razr HD?
#163 benihurst
benihurst
Posted 02 December 2012 - 02:44 AM
I had the same problem, are you sure you downloaded the correct version?
#164 benihurst
benihurst
Posted 02 December 2012 - 02:54 AM
I successfully installed safestrap and created a rom slot. I tried CM10 Alpha and Vitreous 1.2. They all installed fine but when I boot the rom it hangs at the bootlogo (CM10 Bootanimation or the colored X depending on the rom). I doublechecked the MD5 checksums etc. all looks good, but it does not boot. Any ideas?
I have a:
XT925
7.71.26003.XT925.O2.en.DE
Rooted
#165 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 03 December 2012 - 12:56 AM
7.71 seems like an earlier ICS version of the OS. You'd need to be on a JB leak of some sort and then it's not guaranteed to work on the XT925. :/
#166 o0beaner
o0beaner
  • 10 posts
  • Twitter:o0beaner
Posted 03 December 2012 - 08:34 AM
I am running SS 3.05.17, and am having an issue that I do not see reported here...
After installing SafeStrap and rebooting into recovery, I can successfully take a backup and create a new ROM slot. Following that though, I cannot restore my stock backup to it. With ROM-Slot-1 active, if I select Restore, there are no backups there to restore. If I activate the Stock ROM slot, I can see my backups. Any insight? How do I restore the stock backup to a custom ROM slot?
Thanks.
Running rooted JB leak.
#167 chazall1
chazall1
  • 35 posts
Posted 06 December 2012 - 12:36 PM
I have an Unlocked, Razr HD Dev edition running TWRP at the moment. I am rooted and running Official JB. I have been trying to flash both CM10 and Vit Roms, and they both Fail to install. I did not think that SS3, .17 was for My Device. If I can use SS3, what is the best option to Remove TWRP.
Believe In "Open Source"
#168 jasonpotts42
jasonpotts42
  • 7 posts
Posted 15 December 2012 - 10:56 AM
I think I have the the correct version, or at least the latest version
I am also not getting the SS splash screen.
Razr Maxx HD OTA Jellybean SafeStrap 3.05. 17 Recovery State: Installed
When I power up phone there is no safestrap splash screen.
Edit 12/31/12; I had to reboot into recovery, then I got the splash screen and a fully functional SS, also all future power ups now include the splash screen. SS works great and so does the Batakang ROM So thanks to all the hard work I am bloatware free =)
#169 originaldobo
originaldobo
  • 18 posts
  • Twitter:@originaldobo
  • Google+:dobo122884
  • LocationLakeland F.L
  • Current Device(s):Razr HD
Posted 25 December 2012 - 08:37 AM
I agree 3gb is far to little and Google music does not let me push offline music to SD and nor does other apps. This is the only thing keeping me from flashing ROMs
#170 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
  • LocationLa Rioja - Argentina
Posted 30 December 2012 - 10:52 PM
Work in RAZR HD XT925 JB 4.1.2 Telstra Australia
Enviado desde mi XT925 usando Tapatalk 2
Firmware Team: Kent_lkc - Kwachu - daywalker04 - Pzyduck - Skrilax_CZ - toto221
#171 Pasquale1981
Pasquale1981
  • 5 posts
Posted 01 January 2013 - 07:02 PM
how we looking with stock rom slot flashing support?
#172 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 04 January 2013 - 11:51 AM
Updated the OP for new Safestrap version 3.12:
md5sum: 9b3d75e84c06d1e71af1bf1bad57faf3
FOLLOW THESE INSTRUCTIONS:
CHANGES:
  • [01/04] (3.12) Fix initial file selector location for backup/restore
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions. * STILL TESTING -- BUGGY*
  • [12/29] (3.10) Enable flashing to stock ROM
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
#173 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 04 January 2013 - 11:52 AM
So GoogleMusic has to keep the music files inside the /data partition? Not in either the internal sd or external sd?
#174 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 04 January 2013 - 12:06 PM
I know this is late but yes you can use SS on your Dev edition. I have a Dev edition and currently the only way to flash ANY of the ROMs out is to use SS. Thatsaid don't worry about the custom recovery you have installed atm. Just install the SS *.apk and then move forward from there to get a ROM installed by following Hashc odes instructions on using SS
#175 FastKatt
FastKatt
  • 26 posts
  • Twitter:@FastKatt
  • Google+:FastKatt
  • Location37312
  • Current Device(s):D1, DX, Bionic, D4, RazrMaxx, Note2
Posted 04 January 2013 - 12:53 PM
Wrong Forum
Post Moved
Edited by FastKatt, 04 January 2013 - 12:56 PM.
Me: Motorola RazrMaxx - Rooted | Wife: Samsung Galaxy Note 2 - Stock | Son: Motorola Droid 4 - Rooted | Daughter: Motorola Bionic - Stock | Spare Rooted Phones: LG Vortex & 3 Droid 1s
#176 originaldobo
originaldobo
  • 18 posts
Posted 04 January 2013 - 06:37 PM
Cant seem to flash anything on the stock slot still. Screen just goes black and thats it ,also upon further inspection I see when installing Rom's Im getting a error now any thoughts ? Edit: I decided to start over with ss 3.05 I flashed batakang slot 1 than I backed it up in slot one. Restored slot ones back up to the stock ROM slot and profit it worked. I deleted the slot one partition and rebooted the device now I have 11gb to my disposal and the ROM feels genuinely faster and more responsive.
#177 ducats
ducats
  • 54 posts
  • LocationBakersfield, CA
Posted 05 January 2013 - 10:30 AM
When you flashed onto stock slot... what did you wipe or not wipe?
#178 originaldobo
originaldobo
  • 18 posts
Posted 05 January 2013 - 11:07 AM
I wiped
#179 theviper90210
theviper90210
  • 28 posts
Posted 05 January 2013 - 11:18 AM
Can I install 3.12 right over 3.11 or is there something special you have to do?
#180 ducats
ducats
  • 54 posts
Posted 05 January 2013 - 12:03 PM
I wiped
You wiped cache, dalvik and system? I ask because when I do a full wipe, nothing boots, when I don't wipe, nothing boots lol.
