[Recovery][Locked Devices] Safestrap Recovery V3.1 [01/04 3.12 - Stock Flash +] [All Versions]
219 replies to this topic
#81 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 12 November 2012 - 08:56 AM
i'm missing something, i installed Safetrap in the JellyBean leak and then followed the steps to get stock in the Stock ROM slot but when i Activate the ROM Slot-1 and then select Restore the backup i made is not available it is only available from Stock ROM. What am i missing?
This is the bug I'm fixing right now.
The internal "sdcard" area is changing with the data partition (since its /data/media).
As was mentioned, a temp fix is to backup to the external.
Sent from my XT894 using Tapatalk 2
#82 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Posted 12 November 2012 - 09:24 AM
It seems the link in the second post is bad! Good job on this as usual @Hashcode0f
Edit: wow!
#83 Nnnnr12
Nnnnr12
  • 418 posts
  • Google+:hairstont14
  • LocationLagrange, Ga
Posted 12 November 2012 - 04:20 PM
I know the number one rule to every forum but... Is the build ready? What complications are you having and could I help in any way?
-tapped from my RAZR maxx HD with Safestrap
#84 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 12 November 2012 - 09:52 PM
Mostly, I'm blind troubleshooting and then working with testers to see if the /data/media issues are fixed. It's just trial and error. So it takes time.
#85 msassounian
msassounian
  • 39 posts
Posted 13 November 2012 - 12:06 AM
Hi everyone. first I wanted to say thank you especially to hashcode for this! i'm pretty new to this whole thing so forgive me for my ignorance...but i have a question.
when i go into my phones storage via settings, if i scroll down i see lots of USB disks. i'm not sure if they're always there or not, but i have a feeling it may be because i created and deleted my virtual rom a couple times while trying to set it up. could this be the case? and if so...is there a way to get rid of these?
#86 NattyBee
NattyBee
  • 647 posts
Posted 13 November 2012 - 01:30 AM
Just one more reason we need to get you an HD...I think we need to get everyone to pull together some funds, let's all buy Hashcode a RAZR HD! What do you guys say?
  • lownslow200sx likes this
#87 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
Posted 13 November 2012 - 01:10 PM
Can someone provide me with the link to the file in the 2nd post so I can get stock going?
#88 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 13 November 2012 - 06:20 PM
so just making sure, at the moment if your using ss3 you can not install paid for apps right?
#89 natedogg11
natedogg11
  • 66 posts
Posted 13 November 2012 - 06:21 PM
Anyone have this problem....I am unable to create new rom slots. When it is working it says "error creating data partition" in the terminal area. Worked fine for me last time. I can flash and have no other issues, but trying to create the 2nd slot is proving very difficult. Any suggestions?
#90 Nnnnr12
Nnnnr12
  • 418 posts
Posted 13 November 2012 - 07:02 PM
Hashcode I just downloaded a paid app using the rom Virteous and I got no errors! I'm so happy!
#91 onequbit
onequbit
  • 6 posts
Posted 13 November 2012 - 07:14 PM
I had this happen to me a couple of times when I had one of the virtual slots active. The trick for me was to activate the stock slot, then reboot back into Safestrap, then create the new slot and activate it. Definitely a bug though.
#92 jtair
jtair
  • 7 posts
Posted 14 November 2012 - 04:45 AM
What did you do to get paid apps to work on new ROM?
#93 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 14 November 2012 - 06:09 AM
Good morning, am I missing something???? Using a ROM? I didn't think there were any ROMs for Razr HD retail version yet?
Proud father of a US Marine
#94 discstu37
discstu37
  • 7 posts
Posted 14 November 2012 - 06:20 AM
Quick question. This is my first time using SS since I am coming from a Nexus -> GS3 -> Maxx HD (long story, lots of $$$ :)). Not new to flashing ROMs, but just using SS in general. I made a back up of my stock ROM, then partitioned ROM slot 1 and loaded up the Vitrious 1.2 ROM and GApps. Everything seemed to work fine, but when I went to reboot, I got stuck in a loop for booting up. I get the SS splash screen (indicating a ROM is active, not stock), but it keeps looping back to that screen when I select continue or wait the 10 seconds. If I hit recovery, the phone basically goes black and becomes unresponsive; I need to do a hard reset, not hit continue/wait and boot into recovery in order to switch back to stock. I've read through the forum and I don't see anything that necessarily touches on this, since I'm unable to even boot into the ROM. (Side note: my stock is the leaked JB build.)
Thanks in advance if anyone has any tips.
#95 NattyBee
NattyBee
  • 647 posts
Posted 14 November 2012 - 06:37 AM
class='bbc_url' title='External link' rel='nofollow external'> http://rootzwiki.com/topic/36022-rom-vitreous-12-11132012-jelly-bean-41-42/
  • newskate9 likes this
#96 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 14 November 2012 - 08:17 AM
COOL! Time to take a look. Thank you!
#97 Nnnnr12
Nnnnr12
  • 418 posts
Posted 14 November 2012 - 08:28 AM
It's faster than stock jb.... Way faster.
#98 NattyBee
NattyBee
  • 647 posts
Posted 14 November 2012 - 09:01 AM
Hey, no problem :)
It it? How is it otherwise? Stable? I may have to try it
#99 Nnnnr12
Nnnnr12
  • 418 posts
Posted 14 November 2012 - 12:14 PM
Hey, no problem
Very stable for me no complaints except if. You like smart actions or the droid notification sound its not for you.
#100 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 14 November 2012 - 01:39 PM
Here's a new test build for the RAZR-HD:
This has 1 BUG really in the recovery and that's how the handling of /sdcard changes if you activate a rom-slot. Make your backups to the ext-sd and you'll be able to restore them to rom-slots.
And this should boot them up correctly with the /sdcard showing the right files.
I'll do another bugfix version once I fix the internal sdcard handling inside recovery.
REPORT: Let me know if this fixes the stock ROM paid apps issue.
