[Recovery][Locked Devices] Safestrap Recovery V3.1 [01/04 3.12 - Stock Flash +] [All Versions]
219 replies to this topic
#41 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 08 November 2012 - 05:00 AM
IF USERS on STOCK ICS want a method for getting that onto a rom-slot as well, let me know.
First off Thx Hash for the efforts like always. That said when time permits if you could put together what is needed for ICS on a ROM slot would be great. I'm no fan of leaks or messing with them anymore but would like to have an option to mess with stock SW tho.
#42 NattyBee
NattyBee
  • 647 posts
Posted 08 November 2012 - 09:55 AM
The man the myth the legend comes threw again ! Thanks bud for everything you do.
Just doin' my thing. I told you I would
I never had a doubt I told you that you should of ran for president!
NEXT STEP GET A HD IN YOUR HANDS!
Yes, I think it is past time we get an HD into Hashcode's hands...
Sent from my RAZR MAXX HD using Tapatalk 2
#43 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 08 November 2012 - 10:38 AM
Update OP with a new version: 3.05.12
Changes:
  • [11/08] (3.05.12) Atrix-HD touch support
  • [11/08] (3.05.09) Revamped loopback devices, testing fix for paid apps
Download here:
I recommend swapping back to stock ROM where you can install right over the old app. Then go into Safestrap APK and use "Install Recovery". Should be good to reboot and test Titanium Backup restores which were giving errors before in the rom-slots.
#44 dmbfan13
dmbfan13
  • 21 posts
Posted 08 November 2012 - 12:52 PM
Changes:
Download here:
Could you add the full version number that's installed? Somewhat confusing.
#45 Nnnnr12
Nnnnr12
  • 418 posts
  • Google+:hairstont14
  • LocationLagrange, Ga
Posted 08 November 2012 - 01:13 PM
Changes:
Download here:
The download is going very slow for my using my phone I get 38-40 mbps with my wifi and it still goes slow.
-tapped from my RAZR maxx HD with Safestrap
#46 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 02:12 PM
I installed the latest version & created a 3GB ROMslot(as my stock showed I was using over 2GB already. To try things & get ready to start flashing stuff I made a backup of my stock & restored it to the slot I created. Everything seems to be working except it doesn't seem that some user data was backed up/restored. I had to d/l & apply my elixir widget icon packs & the real race game that came on the ROM needs to d/l the 400MB update again.
My apps usage went from over 2GB to only 863MB. I'm thinking that maybe my extracted folder was being added to the apps in the storage manager. My used & free don't quite add up to 3GB either.
  70.42KB   26 downloads
Sent from my DROID RAZR HD using Xparent Red Tapatalk 2
#47 Nnnnr12
Nnnnr12
  • 418 posts
Posted 08 November 2012 - 02:25 PM
I upgraded and my paid apps wont download (titanium backup pro key)
#48 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 02:31 PM
I didn't test this yet since everything was already there from the backup/restore. I was planning on getting another paid app so I guess if it doesn't work still I'll just have to wait or go back to my stock slot.
Edit: I just installed a paid app I no longer use & it worked fine for me. However when I uninstalled it my navigation bar & keys disappeared & I had to do a reset(the app does put something in notification area so it be related to said app).
#49 Nnnnr12
Nnnnr12
  • 418 posts
Posted 08 November 2012 - 02:39 PM
I love how fast it switches back and forth. Way faster than the plain razr...well...when I had one.
#50 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 02:47 PM
Yeah & if hashcode adds the ROM slot Chooser on the boot screen it will be even better for switching. I don't normally switch that often so I'm fine the way it is, hell I was fine with the way it was just because it opened a lot of doors for us, but this is much better.
  • lownslow200sx likes this
#51 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 08 November 2012 - 03:00 PM
Are you on a retail standard model with 16GB internal emmc chip? From what I saw there won't be enough space available to make the 3GB data. Only the MAXX models (with 32GB internal emmc) have enough I think.
Can you go show me a "ls -l /sdcard/safestrap/rom-slot1/" ?
Re Slow Download: I think goo.im is taking a beating.
#52 dmbfan13
dmbfan13
  • 21 posts
Posted 08 November 2012 - 03:21 PM
From his picture, he still is only able to use approximately 2gb of the 16gb internal memory. Am I missing something? For instance, I have the RAZR Maxx HD and Im on the stock slot. Its showing I have 32gb of internal memory. After apps, pictures, audio and downloads, I have 21.74 gb left to use. However, if I follow your method and use Slot 1, I only had 1.62gb of space after everything. Still a bug I take it?
#53 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 03:29 PM
I have a dev edition so yeah it's the same as the standard retail. I had 8GB free prior to setting up the ROM slot,so shouldn't the system & user partitions even with 3GB be less than that. Also windows shows it 2.95GB which is closer than what storage manager says.
Where do I need to be to run a list command on the rom-slot1 did?
#54 Nnnnr12
Nnnnr12
  • 418 posts
Posted 08 November 2012 - 05:13 PM
Hmm.. I'll try again i'll flash the new rom :)
#55 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 06:00 PM
Well after flashing a new ROM I got the can't install on USB error.
Strange that it worked on the restored backup of the stock slot.
#56 NattyBee
NattyBee
  • 647 posts
Posted 08 November 2012 - 06:36 PM
I'm surprised you would run SS on a dev unit, lol
#57 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 06:49 PM
I didn't want to unlock it & void my warranty right away in case there's something wrong with & until I get to the point that can't do what I want/need with SS I probably keep it locked. I've been really tempted to unlock it though, but since hashcode got us SS already I should be content for awhile.
#58 zephyrus14
zephyrus14
  • 216 posts
  • Twitter:@johnmarciniak
  • LocationThe Region
Posted 08 November 2012 - 07:19 PM
After I download Safestrap, I'm getting a force close on launch. Am I missing something?
I'm on the JB leak.
<EDIT>
I think I have a false root. Reading previous posts to figure out how to fix this.
#59 lovemyram4x4
lovemyram4x4
  • 52 posts
Posted 08 November 2012 - 07:37 PM
OK, after going back into the stock slot I can get to the rom_slot1 dir. Here's a screen shot from root browser.
  33.46KB   27 downloads
It looks like I could actually do 2 slots at 3GB.
  73.07KB   20 downloads
#60 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 08 November 2012 - 11:24 PM
I need a "ls -l /" command run from stock and pastebin'd somewhere, please. :)
