Motorola Smart Actions
Motorola Smart Actions Smart Actions Smart Actions Llama Automateit Tasker
17 replies to this topic
#1 UrbanDroid
UrbanDroid
  • 14 posts
  • LocationAuburn, Alabama
Posted 07 November 2012 - 09:46 AM
I am in search of the official smart actions app from Motorola. Now I know I have a Motorola Droid RaZr and you may say," Doesn't that come installed on your phone stock?" The problem is that on a custom rom this app is absent. After using smart actions for so long it is hard to find a decent replacement. All the other so called smart apps that can control the same actions I need to control are completely user un-friendly. I need the simplicity back in my phone and life that was smart actions!
So. Does anyone know of a port? I see that Motorola has it for download on the Play store, but there is no way to download from my phone and I cannot push it as it refuses to install if I do. XDA and other sites have topics around this issue, but most have gone cold and others have veered onto other similar apps such as Llama, Automateit, or Tasker. These apps are not what I want. Please try to keep this topic on topic. I only want Smart Actions, not a replacement or substitute.
Thanks,
UrbanDroid
#2 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 07 November 2012 - 09:58 AM
Flick 4.0 has a smart actions zip installer u can download.......
Sent from my MZ617 using Tapatalk 2
GOT KRACKFLASHING?
#3 diasas
diasas
  • 11 posts
Posted 07 November 2012 - 10:46 AM
here you go just pulled from my razr. put into system\app fix premissions. rw-r--r--, mite need to run it.
#4 UrbanDroid
UrbanDroid
  • 14 posts
Posted 07 November 2012 - 11:50 AM
Getting force close when trying to create a new rule. Any suggestions? Im close at least. The app does launch and i can start rules and edit options within the rule, but as soon as i try and save the rule it force closes.
EDIT: i am on Licorice CM10 v. 1.4
#5 UrbanDroid
UrbanDroid
  • 14 posts
Posted 07 November 2012 - 12:00 PM
Link Please?
#6 diasas
diasas
  • 11 posts
Posted 07 November 2012 - 12:16 PM
I was having trouble like that also, I had to install the program from the system\app, then do a reboot. That should fix it right up for you.
#7 UrbanDroid
UrbanDroid
  • 14 posts
Posted 07 November 2012 - 12:23 PM
Where you on a custom rom? The rom i am running is a cm10 jellybean based rom.
EDIT: Still getting force closing even after a fresh install into /system/app then a reboot.
I have also tried a cache and dalvik cache wipe to no avail...
#8 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 07 November 2012 - 12:44 PM
This is the Smart Actions installer from Flick.....
  1.83MB   134 downloads
#9 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 07 November 2012 - 01:13 PM
Has anyone succesfully installed this on a non-Moto based Rom? I am not entirely sure it's possible.
#10 UrbanDroid
UrbanDroid
  • 14 posts
Posted 07 November 2012 - 01:24 PM
Im gonna try the updater file he provided. I assume you flash the .zip for this to work?
EDIT: Flashed the .zip and no dice.
#11 UrbanDroid
UrbanDroid
  • 14 posts
Posted 07 November 2012 - 04:43 PM
It seems there is some permission or perhaps a system file or framework that is missing. It seems like i read in one of the threads on XDA that there is some file associated in motoblur that allows the Smart Actions app to access the other system files. Could someone Clarify?
EDIT: Who would the best developer be to contact on this matter?
#12 UrbanDroid
UrbanDroid
  • 14 posts
Posted 11 November 2012 - 05:15 AM
Has anyone found anything on this? I have pmd a couple people and haven't received any response yet. Let me know if you or anyone else has any ideas. I'm still on the hunt.
  • spikes2020 likes this
#13 spikes2020
spikes2020
Posted 21 November 2012 - 09:56 AM
Any more news on this?
I liked how it turned off my ringer every day at work, and i could turn off my radio after 1am to save battery, if i forgot to plug it in.
Anything else that could replace this?
I got mine to run, and edit the profiles, but it wouldnt do anything... i set it all day to be on vibrate and it did nothing.
#14 jrbxx7
jrbxx7
  • 94 posts
  • LocationIdaho
Posted 21 November 2012 - 10:21 AM
From what I've gathered it will only work on stock based roms like simplex, arctic hd and flick... correct me if im wrong tho.... tasker app will do stuff like that...
SeNt FrOm .......OvErFlAsHeD SPYDER Xt912
GOT KRACKFLASHING?
#15 snives
snives
  • 947 posts
Posted 21 November 2012 - 10:12 PM
Effectively, yes. With Llama and Tasker being available it would be kind of silly to take the time to work around all of the dependencies to make it work with a non-blur ROM.
#16 krzyxb0rdr
krzyxb0rdr
Posted 26 November 2012 - 01:03 AM
hmmm... I just searched it (smart actions) in the google play store. it's an official app by motorola. using it on my eclipse rom for razr, which had it removed. It works no problem. Been using it for weeks. No forecloses.
#17 Guest_BDH_*
Guest_BDH_*
Posted 26 November 2012 - 01:10 AM
Eclipse is stock based.
#18 akili
akili
  • 12 posts
Posted 21 December 2012 - 08:07 AM
when deboating i deleted social location and it broke smart actions for meand according to the safe to debloat list for stock moto as well. maybe that needs to be installed as well.
sorry to bring back an old subject just browsing at work.
Also tagged with one or more of these keywords: Motorola Smart Actions, Smart, Actions, Smart Actions, Llama, Automateit, Tasker
