BR 35 Razr Deodex DSJ 1.1 is a Rom just like motorola handed, ie has all blurs the rom and native applications, exceptions are due to the tweaks and some inclusions.
Tweaks:
Deodex, zipaligned, ultra fast GPS fix, supercharged services.jar, providing init.d enabled defragmentation of database to start, kernel tweaks to improve battery management, network tweaks to improve speed data, Dalvik VM tweaks, launcher locked in memory, super fast, inserted new modules management kernel and loaded as standard managed by the pegasusq sio. Without overclocking.
UI:
Launcher, widget, camera and gallery ported the Razr HD
status bar with battery 1 percent and 6 toggles
6 shutdown options
popup transparent
Changed the file manager ported by the native MIUI
Extras:
Audio and video enhancement
DSP manager
Zipalign
Sysctl enabled
Init.d support
Extra Kernel Modules:
Pegasusq
hotplugx
smartassV2
SIO
cifs
ntfs
Summary:
Excellent visual, speed, stability and battery life without leaving a lot out of originality.
Bugs:
No functioning because as said is the motorola rom with some improvements in order to achieve more functionality and speed without instability.
Just do not do factory reset.
NOTE: This rom has been developed to be used on 180_SLC-6.7.2-35BR
Installation - Read carefully:
If You've updated your version 672.180.350.XT910.Brasil.en.BR Razr to make the downloads 1, 2 and 3 if not 4 do too.
If you did not update to version 672.180.350.XT910.Brasil.en.BR make the first (4).
If you already did install superuser (2): configurations, options Developer, enable USB debugging and connect it to the PC as a media device, unzip the file to the PC and run the rootscript.bat, wait for conclusion the razr will two restart time and the window will close, make sure the application appears superuser, if yes proceed, if not repeat the installation;
Copy the file (3) for the razr and install it;
Copy the file (1) for the razr, restart it through the CWM Touch Razr or another boot manager since that is not a safestrap (do not any wipe, installer will automatically wipes needed) and install the rom, restart the first initialization will take about 5 minutes.
Ready!
Note: There may be a crash on the first start during the "Updating Applications", if this happens just restart the machine.
Do not know how to restart the locked razr? simultaneously press the volume buttons and power for more than 15 seconds to notice a vibration.
Downloads:
1- Rom
2- Superuser
3- CWM Touch Razr
4- 6.7.2-180_SLC-35BR
Attention! Download and Install Fix Circle 3D widget via Boot Manager
IMPORTANT:
Many participated in this rom because reunite tweaks tested and modified but not created, mods and includes applications like file manager ported from MIUI, police.jar, services.jar, systemui and framework developed among others by other resulting in this rom, so if you of somehow participated in creating this rom please contact the better I'll be happy to mention your name and your work.
Thx:
Motorola, Google, Leisures, MIUI, hacker812c, Whirleyes, ...
Razr Br 35 Deodex Dsj 1.1
deivesj
, Nov 02 2012 07:51 AM
No replies to this topic
