HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#161 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 04 November 2012 - 06:57 PM
BTW I can get into recovery just fine
#162 NattyBee
NattyBee
  • 647 posts
Posted 04 November 2012 - 07:00 PM
Can you describe your method exactly, please?
Sent from my RAZR MAXX HD using Tapatalk 2
#163 NattyBee
NattyBee
  • 647 posts
No way I could go back to using ICS now though lol
Agreed
#164 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 05 November 2012 - 05:58 AM
I copied that file and renamed it and loaded it into RSD and when I click on start, it immediately says Failed flashing process. unknown fastboot command (getvar)
Simple fix really my M was doing the same thing. If oyu go into the fastboot file and find the *.xml in the folder oped/Edit it. The first line in the XML will have getvar in it. Forget how it is labeled tho. Anywhoo just delete the entire line out fo the XML and then save the changes. After that the full fastboot file will flash fine in RSD. Oh and if you DO NOT want your internal memory wiped out when using the fastboot file delete the last line in the XML file that says userdata in it.
Somehow, though, I suspect they closed the moto2go exploit in JB.
I'd be very surprised if that is the case. I know 2 ppl on the Razr M how had JB on it with no root and used the current root exploit while on JB without issue. However the HD did get that small security patch already so maybe that is what closed the hole. Not sure seeing as the M did not get that update I don't believe.
#165 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 06:04 AM
You do know you can go back to 100% stock?
#166 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 06:05 AM
If anyone wants to have the notification lights turned on I will post it for you.
#167 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 06:06 AM
Hold Volume Up and Power until you get to the boot screen. Press Volume Down to select Recovery, then hit Volume up to choose it,
#168 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:11 AM
I don't think the small security patch for the HD was what closed the hole, as motofail works fine on ICS after the security patch...whatever they did to close the exploit was done in the JB...
#169 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:13 AM
Yes, that is the method used for ICS which was needed to get to the JB update...but since flashing the JB update I get as far as the Android with triangle exclamation and then I have to force shutdown, as it will go no further
#170 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Lol @natty is the only one with this problem lol :) I think ?
Its hold both volume + - & pwr for a few seconds, when phone is off. Select recovery then when Andy pops up with a red triangle hold both Vol -+ till the menus pops up.
#171 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:14 AM
I'm pretty sure he meant "there's no way I would ever willingly go back to ICS" lmao
#172 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:15 AM
Lol @natty is the only one with this problem lol I think ?
This I have tried multiple times...I usually give up after holding -+ for about 45-50 seconds though, so maybe I should be here holding it longer?
#173 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 06:16 AM
Hmm weird, I just tried it on mine and it worked :)
#174 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
O woops :P Big +1 on that.
  • NattyBee likes this
#175 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 06:19 AM
Also I think there is a bug in recovery if yours don't work, use a app like ROM toolbox or terminal and choose reboot recovery or from terminal su , reboot recovery . Then try holding in both keys till it pops up.
#176 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 06:20 AM
I was wondering why notifications were not seeming to go off... Please post.
#177 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:23 AM
ok, just tried again...it seems I have to hold the +- keys for a full minute in order to get into recovery....but at least I got in, so I'm satisfied....lol
#178 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 05 November 2012 - 06:24 AM
Yeah I know.. Meant that the issues aren't enough to go back. Liking JB :)
#179 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 06:25 AM
To what are you guys referring? the LED Blinker? mine is working fine...
#180 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 05 November 2012 - 06:39 AM
Mine work also.
20 user(s) are reading this topic
0 members, 20 guests, 0 anonymous users
