HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#141 chrisc2u
chrisc2u
  • 50 posts
Posted 03 November 2012 - 07:45 PM
Well, at least you have A method for getting root I suppose. :)
The updated root exploit does save a few steps (updating superuser and binaries before OTA Rootkeeper backup, temp unroot). Let me know if anyone would like the updated exploit posted with new instructions to save those steps. Thanks houch80 for testing the update!
#142 JackTheRipper
JackTheRipper
  • 13 posts
  • LocationHuntsville Alabama
Posted 03 November 2012 - 09:19 PM
when I rooted originally I replaced su with the other one on the market, I didn't update binaries. I did use OTA rootkeeper, did the bkp, temp unroot, installed the update, used OTA to restore root... rebooted and I had root. I then updated binaries for grins.... I've always had issues using OTA rootkeeper but a reboot usually resolve's all.
#143 SamuriHL
  • 44,204 posts
Posted 04 November 2012 - 06:57 AM
I personally use SuperSU Pro which also has root keeping abilities. I don't know how it compares to OTA Rootkeeper, though.
#144 NattyBee
NattyBee
  • 647 posts
Posted 04 November 2012 - 08:21 AM
hmm...2 things:
are any of you noticing any lag in your phone's performance since installing the JB update? mine is noticeably slower than on the ICS...
and OTA Rootkeeper failed to restore root for me...gonna try rebooting but it looks like I'll be fastbooting back to stock and just waiting for official most likely
**update** reboot seems to have fixed the lag issue...
#145 razrsedge
razrsedge
  • 12 posts
Posted 04 November 2012 - 08:27 AM
Does this mean we might have a better kernel for the JB ROMs so that Bluetooth might finally work?
#146 megahertz1970
megahertz1970
  • 228 posts
  • Google+:markw4itg@gmail.com
  • LocationPiscataway, NJ
Posted 04 November 2012 - 08:31 AM
Well I have used 2 different file explorers and don't see an external sd1 directory or any external sd directory for that matter. Is it somewhere else than the home directory?
#147 rgb24
rgb24
Posted 04 November 2012 - 08:45 AM
You will have to buy and put an SD card in your phone is order to have an extetnal directory. It goes in next to the sim card.
#148 lovemyram4x4
lovemyram4x4
  • 52 posts
Mnt/external1 is were the Razr HDs have been putting them for me.
Sent from my DROID RAZR HD using Xparent Red Tapatalk 2
#149 megahertz1970
megahertz1970
  • 228 posts
Posted 04 November 2012 - 08:47 AM
I have an eternal sd card.
#150 megahertz1970
megahertz1970
  • 228 posts
Posted 04 November 2012 - 08:50 AM
Thanks 4x4
#151 rgb24
rgb24
Posted 04 November 2012 - 08:52 AM
Open the files app that came on your phone. It shold have a list. the first item in the list is Device storage, this is internal storage. The next item should be SD card,this is the external storage.
#152 michaeltchuang
michaeltchuang
Posted 04 November 2012 - 04:27 PM
I downloaded the zip and crc file and put it into the external folder. Following these instructions
When i try to apply update from recovery i get
Verifying update package...
Installing update...
assert failed: file_getprop("/system/build.prop", "ro.build.fingerprint") == "motorola/XT926_verizon/vanquish:4.0.4/7.7.1Q-144_VQW_S33425-2/3:user/release-keys" || file_getprop("/system/build.prop", "ro.build.fingerprint") == "motorola/XT926_verizon/vanquish:4.1.1/9.8.1Q_337/39:user/release-keys"
E: Error in tmp/sideload/package.zip
(Status 7)
Installation aborted
My maxx hd build should be stock and not rooted since i just bought the device from verizon
System: 0.6.25.XT926.Verizon.en.US
Version: 4.0.4
Build: 7.7.1Q-144_VQW_S334-25
Is it cuz my build isn't the right stock version? Can someone help me out? What am i doing wrong?
#153 NattyBee
NattyBee
  • 647 posts
Posted 04 November 2012 - 04:30 PM
Sounds like you didn't take the OTA update...there was a minor OTA update (security patch or something) that you need to take before you will be able to flash this leak...
Sent from my RAZR MAXX HD using Tapatalk 2
#154 houch80
houch80
  • 96 posts
  • LocationIllinois
(Status 7)
Version: 4.0.4
Did you do the OTA update?
#155 michaeltchuang
michaeltchuang
Posted 04 November 2012 - 04:45 PM
Yeah that was it...silly me...thanks!
#156 Nnnnr12
Nnnnr12
  • 418 posts
  • Google+:hairstont14
  • LocationLagrange, Ga
Posted 04 November 2012 - 04:54 PM
So when we get safestrap this can be converted into a rom right?
#157 NattyBee
NattyBee
  • 647 posts
Posted 04 November 2012 - 05:03 PM
so...are any of you able to boot into recovery? I have tried the method used in ICS, but am unable to get into recovery on this JB leak....
#158 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 04 November 2012 - 06:47 PM
After using this JB build for a few days it seems to have a bit of lag here and there. Touch seems more responsive than it was on ICS but it tends to lag out at times...
#159 NattyBee
NattyBee
  • 647 posts
Posted 04 November 2012 - 06:51 PM
I have noticed this as well...at first at least. After a few reboots I am not getting the noticeable lag I had been getting...but, this is an early leak, so it is to be expected that we'll notice a few unpolished spots lol
#160 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 04 November 2012 - 06:55 PM
No way I could go back to using ICS now though lol
21 user(s) are reading this topic
0 members, 21 guests, 0 anonymous users
