HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#101 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 02:34 PM
Guess my phone doesn't like me. I will try that and see what happens.
Good luck. Sorry this happened to you! UGH!!!!
#102 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:49 PM
That seemed to get me back up and working. Guess I should be able to upgrade from here. Thanks for taking the time to help me :)
#103 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 02:52 PM
I feel VERY relieved that fixed it. Again, very sorry about the brick there. SIGH! I'm glad you're up and running! Have fun!
  • houch80 likes this
#104 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 02 November 2012 - 03:05 PM
A status 7 error in whatever.apk means your system is failing checks. Just faatboot back and start over , take the first OTA etc etc
Tapped from my XT926, XT913 or SCH-i535.
#105 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 03:07 PM
He was having issues fastbooting in RSD. Matt's util did the trick. Still would like to give you guys a working KEEP DATA XML file for RSD.
#106 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 03:15 PM
If I hadn't had fastboot issues, I am sure your xml file would have worked lol.
#107 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 03:20 PM
I can repost it for those that want to have it and try it out.
#108 Narffran
Narffran
  • 147 posts
  • Twitter:Fran_Granfield
  • LocationNorth of Boston MA
Posted 02 November 2012 - 03:23 PM
No issues here. Now that I had some time.
Did the OTA update, rooted and voodo, flashed the leak then restored root with no issues.
I'm a happy camper now thanks to Droidrzr and all the fine folks here.
#109 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 03:24 PM
That's the Keep Data XML script. Unzip it into the directory that you extracted the FXZ to and use it instead of the original XML file. It should, hopefully, in theory, keep your data. But what do I know. :D
#110 chrisc2u
chrisc2u
  • 50 posts
Posted 02 November 2012 - 03:40 PM
Basically I fastbooted back to stock, ran the 702 update I think it is, rooted the device, updated the SU binary, made SU backup, temp unroot, flash JB update, and restored my su backup.
Edit: While root call blocker does get root priveledges, it doesn't seem to work with Motos JB :(
Thanks for posting this, I walked through the process and the key difference was updating the SU binary before using OTA rootkeeper to backup and temp unroot.
So to summarize the process:
1. You are stock with the non-JB verizon pushed update (6MB) applied (Settings > About Phone > System update tells you your device is up to date)
2. You root (or are already rooted)
3. You go into the Superuser app, swipe to the left the info tab (if you don't see this, the make sure you have the latest superuse update from the app store)
4. Tap on the 3rd line (su binary tap to check for updates)
5. Update the binaries to the latest
6. Open OTA Vodoo RootKeeper and Protect Root (or delete and create a new backup if you have already used the app to backup)
7. Temp unroot in OTA Vodoo RootKeeper
8. Power off the device
9. Power + volume up, then press volume up and down simultaneously when you see the android.
10. Volume down until recovery is highlighted, then volume up to select recovery
11. Choose install update from external sd card
12. Select file to update
13. After boot, restore root using OTA Vodoo RootKeeper
14. Repeat steps 3 and 4 to confirm you have root
Root and flashing back to stock can be done using Matt's utility (thanks Matt!)
I think this should work for everyone having issues, let me know if you are able to get JB root using these instructions.
  • jroc, NattyBee, krazyace38 and 2 others like this
#111 DMBatCOFC
DMBatCOFC
  • Twitter:dmbatcofc
Posted 02 November 2012 - 03:51 PM
Silly question.... on my stock RAZR MAXX HD I don't have a folder called "external1" so I created it on my SD card. Does the folder name matter? Is it ok if both files are on the root of the SD card? Thanks in advance for the help.
#112 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 02 November 2012 - 04:32 PM
chrisc2u glad you got root working :) I am guessing the su binary that is distributed with the ICS exploit isn't compatible with Jelly Bean.
#113 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 02 November 2012 - 04:44 PM
I'm guessing we will be seeing more builds... People app isn't even themed....
#114 melog69
melog69
  • 7 posts
  • Twitter:melog69
Posted 02 November 2012 - 04:47 PM
The phone has a partition for storing data that is recognized as sdcard and your sdcard is recognized as sdcard-ext or external that is all
#115 ajm144k
ajm144k
  • Validating
  • 16 posts
Posted 02 November 2012 - 04:53 PM
so whats the gameplan if i lost root and matt's utility isnt rooting the leak?
#116 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 02 November 2012 - 05:14 PM
I would recommend fastbooting back to stock and follow the steps from chrisc2u in post #110.
#117 chrisc2u
chrisc2u
  • 50 posts
Posted 02 November 2012 - 05:47 PM
Thanks for pointing me in the right direction STiK. That has me wondering... If we update the Superuser.apk (and binary files if not included in the app) in the current root method, it should/could root the JB leak?
Matt, or other Devs, could you comment or take a look? I am happy to play, but not sure what files would need to be updated besides Superuser.apk
#118 Narffran
Narffran
  • 147 posts
Posted 02 November 2012 - 05:51 PM
I'll second that. Matt's utility works fine for going back to ICS and starting over. Following post 110 you should have no issues.
  • lownslow200sx likes this
#119 SamuriHL
  • 44,204 posts
Posted 02 November 2012 - 05:54 PM
It's a thought. Try updating the su binary and the superuser.apk in the current root exploit and see if that works. Somehow, though, I suspect they closed the moto2go exploit in JB.
#120 chrisc2u
chrisc2u
  • 50 posts
Posted 02 November 2012 - 06:12 PM
Ok, I've got the app, can I just copy my SU from \system\bin?
12 user(s) are reading this topic
0 members, 12 guests, 0 anonymous users
