HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#81 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 02 November 2012 - 01:38 PM
There we go... I updated the SU binary before backing up and flashing update.. running JB fully rooted now :)
#82 chrisc2u
chrisc2u
  • 50 posts
Posted 02 November 2012 - 01:48 PM
Interesting, I just did the same thing and no root. Did you confirm with an application that needs root? OTA rootkeeper tells me I have root, but I don't.
#83 SamuriHL
  • 44,416 posts
Posted 02 November 2012 - 01:50 PM
Thank you so much will try and let you know the results shortly :-)
Thanks! I hope it works!
#84 YankInDaSouth
YankInDaSouth
  • 15 posts
  • LocationSharpsburg, GA
Aside from being a chore to retain root, how's this leak treating you all? Still have good reception, call quality, data speed, etc.?
~~ Tapped from the 7th dimension~~
#85 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 01:54 PM
BIG HUGE WARNING...I can't promise anything here. I'm told this SHOULD work but I can't be held responsible if it blasts your data. I don't have a RAZR HD and can't test it, so, I'm in uncharted territory here. I'd like to know if it works. Try at your own risk. Should be safer than the full one which is GUARANTEED to wipe everything. :D
Extract that into the directory that you extracted the FXZ into. Then flash this XML file with RSD. Don't pick the wrong one by mistake. This has a Keep_Data on the end! :)
I copied that file and renamed it and loaded it into RSD and when I click on start, it immediately says Failed flashing process. unknown fastboot command (getvar)
#86 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 02 November 2012 - 01:58 PM
Basically I fastbooted back to stock, ran the 702 update I think it is, rooted the device, updated the SU binary, made SU backup, temp unroot, flash JB update, and restored my su backup.
Edit: While root call blocker does get root priveledges, it doesn't seem to work with Motos JB :(
#87 SamuriHL
  • 44,416 posts
Um....wtf. Considering it's an EXACT copy of the one that ships with the FXZ except for the erase userdata command removed, that's pretty messed up. I have no idea.
#88 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:00 PM
yeah i noticed I compared the two files and the lines are the same that have the line getvar in there
#89 SamuriHL
  • 44,416 posts
Posted 02 November 2012 - 02:02 PM
Yea, so, I don't know what would cause that to fail. Are you using RSD Lite 6.1.4?
#90 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:03 PM
I am using 5.7 as it seems to be more successful, from what I have heard, than 6.1.4 But I will download 6.1.4 and try it just to see...
#91 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:10 PM
So 6.1.4 does the same thing. When I put the original xml file back in, I get the same error as well. Not sure whats going on.
#92 TragicRemedy
TragicRemedy
  • 87 posts
Nice..... my Bionic is jealous... it wants JB.
#93 SamuriHL
  • 44,416 posts
Posted 02 November 2012 - 02:12 PM
Ok. Grab this while you're at it:
<link removed as it no workie>
Extract it into the directory you extracted the FXZ to. If RSD doesn't work, run the KeepData.bat. I also changed the Keep Data XML file slightly and removed some more erase commands so make sure when you try again that you use the new one.
#94 chrisc2u
chrisc2u
  • 50 posts
Can you see if Rom Toolbox gets root permissions?
#95 SamuriHL
  • 44,416 posts
Ok, get my latest zip file and run the KeepData.bat file. That'll flash the damn thing with moto-fastboot.
#96 chrisc2u
chrisc2u
  • 50 posts
Posted 02 November 2012 - 02:14 PM
I have used it for a few hours, surfing, conference calls and email and it has been great. Love all of the new google now features and the expanded notifications.
#97 YankInDaSouth
YankInDaSouth
  • 15 posts
Posted 02 November 2012 - 02:18 PM
Good to hear! Thanks for the response ... This is going to make this leak hard to resist! I been missing me some JB goodness!!!
Sent from my DROID RAZR MAXX HD using Tapatalk 2
#98 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:23 PM
This doesnt look good :( it Will not boot back up now...
Ap Fastboot Flash Mode (S)
Device is LOCKED. Status Code:0
No Valid PIV block in SP for system
piv validation failed (system)
Fastboot Reason: Boot Failure
#99 SamuriHL
  • 44,416 posts
Posted 02 November 2012 - 02:29 PM
UMMMM. WTF? What the HELL is going on with your phone? :(
Get Matt's util and restore it using that. If that doesn't work, post a message there and see if Matt has any idea. This definitely should NOT have failed since it's doing EXACTLY what the FXZ file is doing. I'm very very confused here. :(
#100 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 02 November 2012 - 02:33 PM
Guess my phone doesn't like me. I will try that and see what happens.
20 user(s) are reading this topic
0 members, 20 guests, 0 anonymous users
