#41
Posted 02 November 2012 - 09:42 AM
Update: It appears I don't have root, rootkeeper gave me a false positive. Has anyone else kept root during the upgrade?
#42
Posted 02 November 2012 - 09:52 AM
#43
Posted 02 November 2012 - 09:53 AM
it gets stuck on boot image i believe its like step 17
It just gets "stuck"? It doesn't fail with an error?
#44
Posted 02 November 2012 - 09:57 AM
Yea im sorry it says fail. =[ anyway u guys can help me out i would greatly appreciate it.
#45
Posted 02 November 2012 - 10:02 AM
#46
Posted 02 November 2012 - 10:06 AM
#47
Posted 02 November 2012 - 10:07 AM
#48
Posted 02 November 2012 - 10:18 AM
#49
Posted 02 November 2012 - 10:29 AM
How long did it take for your device to be recognized??? I waited a couple minutes and it was never recognizedI was able to by just following these instructions
#50
Posted 02 November 2012 - 10:38 AM
And your phone was in AP Fastboot mode? Original cable that came with the phone? USB 2.0 port? Latest drivers installed? Sorry for all the questions but there's literally a whole list of reasons that can cause this problem.
#51
Posted 02 November 2012 - 10:43 AM
AP Fastboot mode YES
Original Cable NO, does it really matter???
Latest Drivers YES, or at least the on the first post
#52
Posted 02 November 2012 - 10:51 AM
Yes the cable mcan make a difference. I was trying to talk my Dad threw rooting his D4 after he got the ICS update and he was not using the OEM cable and no luck. I finally asked what cable and he told me, so i said find the OEM one and sure as crap it rooted right away
#53
#54
When trying to rule out why your phone isn't being recognized, yes, it matters. If it was working, then no, it wouldn't matter. LOL I'm only half kidding here. We've seen problems with non-OEM cables before. Just trying to help you rule out any issues.
#55
Posted 02 November 2012 - 11:02 AM
#56
Posted 02 November 2012 - 11:20 AM
- jroc likes this
#57
Posted 02 November 2012 - 11:21 AM
#58 Guest_DirtyDroidX_*
Posted 02 November 2012 - 11:27 AM
Yes I can confirm I used RSDLite to get back on path!
When I loaded the leak the first time RootKeeper showed no su permissions. I went into SU app, updated the version and binary and I was good to ho. So in the end each device is different , you may have problems doing ,A when others are having problems with B. This comes with the territory. With a little bit of persistence and a knowhow all will be good.
#59
Posted 02 November 2012 - 11:28 AM
#60 Guest_DirtyDroidX_*
Posted 02 November 2012 - 11:31 AM
When people say "it doesn't work" it's not easy to figure out if it's the exact same problem or something different. If you give the exact error you're getting that'd be helpful.
Lol big +1
Everyone needs to make sure drivers are installed , OEM cable , etc. I've seen strange things happen . My one desktop would fail in RSD if I had it hooked up in the front but when plugged in the back , no problems.
- ashuva likes this
