#461
Posted 26 November 2012 - 03:34 PM
#462
Posted 26 November 2012 - 03:41 PM
Sent from my DROID RAZR M using Tapatalk 2
#463
Posted 26 November 2012 - 03:52 PM
Well my SS side is empty, I'll give it a go. In this order:
Fastboot - Root - Update root and protect it. install SS then try for the OTA to see what happens.
Did I miss a step?
Done.
I followed my own steps after installing SafeStrap checked for updates and it was there ready to go. I then boot into SafeStrap wiped Cache and rebooted. Checked for updates again and the update was there ready to go. Downloaded and installed fine.
So I think we can rule SafeStrap out as being the problem. Now to fastboot again so I can make it purty the way I had it.
#464
Posted 26 November 2012 - 03:53 PM
#465
Posted 26 November 2012 - 03:57 PM
#466
Posted 26 November 2012 - 05:00 PM
#467
Posted 26 November 2012 - 05:02 PM
#468
Posted 26 November 2012 - 05:04 PM
#469
Posted 26 November 2012 - 05:22 PM
Ah OK. So this is the jellybean leak. Do you still need the crc file?
I personally haven't. But it's good to have.
#470
Posted 26 November 2012 - 05:31 PM
I can't find the jellybean leak and Crc file.does anyone have a working one. The one in earlier post downloaded as 0.7.2xt926.
I don't currently have a mirror of the CRC file, but I added Matt's mirror to the OP...
#471
Posted 26 November 2012 - 05:35 PM
#472
Posted 26 November 2012 - 05:38 PM
I don't know...gimme a few and I'll put up a dropbox linkI can't find the crc file... is it absolutely necessary or cab I just. Flash without it?
#473
Posted 26 November 2012 - 10:53 PM
#474
Posted 27 November 2012 - 02:59 AM
Anybody have a mirror to the update.zip OP link appears to be down?
That was my fault...try it now, the mirror should be working
- Jcubed likes this
#475
Posted 28 November 2012 - 02:45 PM
Well my friends it turns out that the DROID RAZR HD can get better. This is a NON OFFICIAL Jelly Bean leak , not an OTA, not from Verizon. I have installed this and been running it for a little bit. I can tell you Its fast and fluid, many changes, and yes Google Now works just fine. Oh I have to mention YES Temple Run works! All jokes aside we do know that you can get back to stock using either RSD lite or @Mattlgroff's Utility . Also we have no clue to how many more will come out till the official OTA roles out. If you choose to install this leak, please be familiar with using ADB and RSDLite.This is a simple process to get to JB.
1) You must be a 100% stock with the 6MB maintenance OTA upate (0.7.2.XT926.Verizon.en.US)
2) Download the Update Zip >>>>>>>>>>>>>>>>>
Put on external1.
2a) Not sure if you need the crc file but get it >>>>>>>>>>> Just put on external1 also.(Right click on link, "save as")
3) You do not have to back up any of your data. It will stay the same as you left it. Unless you feel like it.
4) THOSE WHO ARE ROOTED & WISH TO KEEP ROOT-
a) Go into Play Store > My Apps....update SuperUser
b ) open SuperUser-- swipe to the left info tab.
- Tap on the 3rd Line (SU Binary tap to check for updates)
- update your binary to the latest.
c) download OTA RootKeeper from Play Store
-open OTA Rootkeeper > protect root (or delete backup if you have one already, and then Protect Root)
- Temp Unroot
5) Power down device.
6) Boot into Recovery:
- boot up while holding Power + Volume UP
- use Volume DOWN to navigate to "Recovery"
- use Volume UP to select
- when you see the Android on his back with the triangle Exclamation > Press Volume UP & DOWN
7) Select "Update from External"
8) Choose Zip (Blur_Version.0.7.2.XT926.Verizon.en.US).
9) Profit !
TO RESTORE ROOT:
10) on boot-- open OTS RootKeeper.
a) Restore Root
b ) Reboot (root doesn't seem to take until rebooted)
11) you should now have your Root Privileges restored!
**** IF YOU CHOOSE TO UPDATE TO THIS LEAK YOU ARE ASSUMING ALL LIABILITYS AND/OR DAMAGE THAT MAY HAPPEN. DROIDRZR.COM IS NOT AT FAULT AND SHALL NOT BE HELD RESPONSIBLE IN ANY WAY, SHAPE OR FORM****
DirtyDroidX
If ever I have helped you in any way please hit the like button
I SPENT MANY HOURS DOWNLOADING/UPLOADING FILES LIKE THIS. PLEASE BE KIND ENOUGH NOT TO PUT THIS FILE DIRECTLY ON ANY OTHER WEBSITE. ALL WE ASK IS A LINK BACK TO THIS ORIGINAL OP. IF ANY SITE WANTS TO HOST THE FILE, THAT IS NO PROBLEM JUST PLEASE GIVE CREDIT WHERE IT IS DUE. THIS IS A COMMUNITY THAT DEPENDS ON EACHOTHER. THANK YOU !
any one have de crc file, the link is broken!!! :S
#476
Posted 28 November 2012 - 02:47 PM
can u send me the link for da crc filee!!! thanks!!
#477
Posted 28 November 2012 - 03:06 PM
sorry about that...meant to get to it last night...try this:
- chino_valdez likes this
#478
Posted 28 November 2012 - 03:14 PM
#479
Posted 29 November 2012 - 08:46 AM
or
Put on external1.
or
- Temp Unroot
9) Profit !
TO RESTORE ROOT:
a) Restore Root
DirtyDroidX
Anyone can help me, the day yesterday jb install the update on my verizon, who came from the factory with the requirements that are asked, however after actulizarlo I have no network, no data signal grab, that I can do? try re-flash the recovery but not activated, I need help!
#480
Posted 29 November 2012 - 03:08 PM
21 user(s) are reading this topic
0 members, 21 guests, 0 anonymous users
