Thanks for the tip. Generally speaking, if something takes more than a few seconds, I go into panic mode
That's how we all react...you're not special... lol! Just kidding..
Sent from my XT910 using Xparent Red Tapatalk 2
Posted 10 November 2012 - 08:28 AM
Posted 10 November 2012 - 08:38 AM
Any specific version of Stock ICS I need to be on..?
I have Matt's fastboot files and one update...
Will that work?
Posted 10 November 2012 - 08:46 AM
just realized there is no 'Thanks ' button..so....Thanks mate..That should work...there was only a small maintenance OTA that needs to be taken after going back to stock
Posted 10 November 2012 - 09:21 AM
It seems like a problem with the leak. I had the same issue. Try holding vol - & + for up to a minute while at the Android with triangle exclamation. Mine went through after about a minute
Posted 10 November 2012 - 09:30 AM
Haha, there is a "like" buttonjust realized there is no 'Thanks ' button..so....Thanks mate..
Posted 10 November 2012 - 09:31 AM
Weird--mine goes directly to the white-type "fastboot" menu--no Andy. I get an extra second or two to make a selection v. the micro second on stock ICS.
Posted 10 November 2012 - 09:43 AM
Once you're in the white, fastboot menu...volume down to "recovery" and volume up to select. Then you will see the. Android guy with a triangle exclamation...
Posted 10 November 2012 - 09:45 AM
Yeah--brain fart here. Mis-read post 333. Sorry. Late, soggy nite last nite... . Thanks for the reply.
Posted 10 November 2012 - 11:07 AM
When I tried to install this leash I got this error
assert failed: apply_patch_check ("/system/bin/logwrapper"."23d23abf573e78e4bfe692fedf631ad1faa3179e"."4a63fec78956def045b442910a754fa640db8f5a")
E:Error in/temp/sideload/package.zip
(Status 7)
Installation aborted.
Any one have any ideas? I have the latest OTA update. Now I did install the JB update once before but didn't like it so I fastbooted back to ICS & reinstalled the OTA update. So I don't have a clue. I want to be able run the new JB theme.
Posted 10 November 2012 - 12:48 PM
Your recovery partition has a non stock mime in it . Meaning u had bootstrap/safe strap installed. Edit the file and try again or fastboot back.
Posted 10 November 2012 - 12:53 PM
(Status 7)
Posted 10 November 2012 - 01:56 PM
Posted 10 November 2012 - 09:35 PM
Just fastboot back with Matt's util, take the OTA update, and then install JB. Done.
Posted 10 November 2012 - 09:40 PM
and what about root? I mean, before flashing JB, do we need root or do we flash with a complete stock and then root JB directly?Oh and one very important question.. I have XT912, GSM...will this work?
Posted 10 November 2012 - 09:43 PM
oh wait..I thought this was for RaZr OG...??If you have a GSM device then its XT910 and no this with not work on your device this is for XT926 Razr HD/HD MAXX.
Posted 10 November 2012 - 09:47 PM
This is the reason I hate it when they name all the phones alike...damn..almost bricked my device...thanks a ton man!
Sent from my RaZr HD.
Posted 10 November 2012 - 09:52 PM
Posted 10 November 2012 - 10:00 PM
yea..I've tried all of that...well most of it..This is as close to Jelly Bean as you can get for now on your device.
AOSP, CM10, AOKP from Hascode & Dhacker.
Posted 11 November 2012 - 12:14 AM
18.8KB 6 downloads
But I want an official ROM JB...
BTW, I've seen in a lot of pics, there is this widget called 'My library' on the home screen...what widget is that?
0 members, 12 guests, 0 anonymous users
