#321
Posted 09 November 2012 - 04:28 PM
#322
Posted 09 November 2012 - 06:04 PM
Wanted to know what what DOESN'T work in this?
Camera? I know USB doesn't work..apart from that? Data? WiFi?
Sent from my XT910 using Xparent Red Tapatalk 2
#323
Posted 09 November 2012 - 06:18 PM
Usb works fine. The newer builds of Android have removed mass storage.Plz excuse my noobness, but I come from a time when ICS leaks were many and most of them had something missing.
#324
Posted 09 November 2012 - 09:44 PM
meaning? So what happens when u connect it to the comp? And what else doesn't work? Camera? Flash? Data?
#325
Posted 09 November 2012 - 09:55 PM
Everything works in the leak, when you plug it into the PC it only displays connected as Media device or Camera but you can still access you internal-SD
and external-SD when you have it mounted as a Media device.
#326
Posted 09 November 2012 - 11:02 PM
oh OK..Thanx! So its good for a daily driver right? This is like the final built?
#327
Posted 09 November 2012 - 11:15 PM
I can't say its the final build, but for sure a daily driver.
#328
Posted 10 November 2012 - 02:15 AM
thanks a ton bro! Gonna try this soon...I can't say its the final build, but for sure a daily driver.
#329
Posted 10 November 2012 - 05:08 AM
assert failed: apply_patch_check ("/system/bin/logwrapper"."23d23abf573e78e4bfe692fedf631ad1faa3179e"."4a63fec78956def045b442910a754fa640db8f5a")
E:Error in/temp/sideload/package.zip
(Status 7)
Installation aborted.
Any one have any ideas? I have the latest OTA update. Now I did install the JB update once before but didn't like it so I fastbooted back to ICS & reinstalled the OTA update. So I don't have a clue. I want to be able run the new JB theme.
#330
Posted 10 November 2012 - 05:09 AM
#331
Posted 10 November 2012 - 05:28 AM
When I tried to install this leash I got this error
(Status 7)
You have bootstrap installed. You have to be complete stock.
#332
Posted 10 November 2012 - 07:00 AM
I believe that is for Google Now. They added a feature in the new GNow update that monitors your Gmail account. Super slick stuff like package tracking, flight info (don't have to search it first) and other stuff.So a little bit after installing I get a notification that a ton of processes want access to my Google account. Is this normal? Don't recall anything like this on my nexus 7.
#333
Posted 10 November 2012 - 07:21 AM
#334
Posted 10 November 2012 - 07:29 AM
I can't boot into recovery on the JB leak. I pull up the recovery menu, and select recovery, the droid with the ! shows up, and I hold VOL+ and VOL- but there is no response. Am I missing something? I've been searching the threads, but I can't find anything that says the recovery shouldn't work.
It shouldn't look like Andy with an exclamation, it should look like Andy on his back with his tummy opened up
#335
Posted 10 November 2012 - 07:45 AM
Fails here, too... and I just got under 80% before trying.... figured I'd let it charge for a bit and try it while on the charger.
on the ! screen, it used to disappear after a few seconds, now it's just stuck there until you hold power + voldown for a while.
#336
Posted 10 November 2012 - 07:54 AM
u know this crucial step when installing an update? To hold vol up+vol down and power button to see the recovery options...?It shouldn't look like Andy with an exclamation, it should look like Andy on his back with his tummy opened up
Worth a shot...
#337
Posted 10 November 2012 - 07:58 AM
#338
Posted 10 November 2012 - 08:00 AM
That's why I'm confused. I got it to work fine to install jb leak. I'm pretty sure I'm doing the same thing now, but can't get the blue recovery to show up. Idk..
It seems like a problem with the leak. I had the same issue. Try holding vol - & + for up to a minute while at the Android with triangle exclamation. Mine went through after about a minute
#339
Posted 10 November 2012 - 08:04 AM
#340
Posted 10 November 2012 - 08:27 AM
I have Matt's fastboot files and one update...
Will that work?
13 user(s) are reading this topic
0 members, 13 guests, 0 anonymous users
