#261
Posted 06 November 2012 - 04:12 PM
#262 Guest_DirtyDroidX_*
Posted 06 November 2012 - 04:31 PM
Tapped from my XT926, XT913 or SCH-i535.
#263
Posted 06 November 2012 - 05:51 PM
#264
Posted 06 November 2012 - 06:04 PM
Thanks for posting this, I walked through the process and the key difference was updating the SU binary before using OTA rootkeeper to backup and temp unroot.
So to summarize the process:
1. You are stock with the non-JB verizon pushed update (6MB) applied (Settings > About Phone > System update tells you your device is up to date)
2. You root (or are already rooted)
3. You go into the Superuser app, swipe to the left the info tab (if you don't see this, the make sure you have the latest superuse update from the app store)
4. Tap on the 3rd line (su binary tap to check for updates)
5. Update the binaries to the latest
6. Open OTA Vodoo RootKeeper and Protect Root (or delete and create a new backup if you have already used the app to backup)
7. Temp unroot in OTA Vodoo RootKeeper
8. Power off the device
9. Power + volume up, then press volume up and down simultaneously when you see the android.
10. Volume down until recovery is highlighted, then volume up to select recovery
11. Choose install update from external sd card
12. Select file to update
13. After boot, restore root using OTA Vodoo RootKeeper
14. Repeat steps 3 and 4 to confirm you have root
Root and flashing back to stock can be done using Matt's utility (thanks Matt!)
I think this should work for everyone having issues, let me know if you are able to get JB root using these instructions.
Trying this now really hope it works..
Edit: Nope staying on ics until another method comes along with easier root.
#265 Guest_DirtyDroidX_*
Posted 06 November 2012 - 08:35 PM
Entitlement check still works? lol. My MAXX gets here thursday.
Lol yeah buddy!
Where have you been ? Under a rock !
#266
Posted 06 November 2012 - 08:40 PM
#267
Posted 06 November 2012 - 10:10 PM
Lol yeah buddy!
Around doing cleanup mostly. I don't post as often but I'm always around. I'll be more active once my new phone gets here and work isn't kicking my rear end.
#268
Posted 06 November 2012 - 10:34 PM
In case people skim I'm going to put this in bold and red text. THIS FILE WILL WIPE YOUR DATA FOR PURPOSES OF COMING FROM JB BACK TO ICS. YOU WILL HAVE ISSUES WITHOUT A WIPE SO I LEFT IT THIS WAY INTENTIONALLY.
- Unpack your existing XML ZIP file if you haven't already
- Delete/Move the existing XML
- Unpack this modified file and drop it in
- Run RSD and point it at the new XML (which should at this point be in the folder with all the other shiz.
- Profit?
Let me know if it works or not. Should be fine though for those looking to use RSD to return to stock from JB.
#269
Posted 06 November 2012 - 10:43 PM
Who ever is removing the getvar lines from the XML should also remove the erase user data line so you can have a keep data rsd xml. It will allow you to over between leaks more easily without losing data. That's the premise of how the house of bionic works.
That theory works if you're coming from the same version of android that you're reverting to (usually...). Coming from JB back to ICS will require a wipe.
#270
Posted 07 November 2012 - 03:58 AM
JB isn't as big of an upgrade as going from gb to ics. You might be surprised to find that it'll work without a wipe. Ics has become very robust about the system data.
#271
Posted 07 November 2012 - 04:42 AM
As I presently don't have a device to test with I'm playing it safe.
#272
Posted 07 November 2012 - 06:37 AM
It will bootloop...I did it the other day (my initial upgrade, I forgot to update SU and my binaries) and I went back and didn't wipe data...boot loop, lol
Sent from my RAZR MAXX HD using Tapatalk 2
#273
Posted 07 November 2012 - 07:00 AM
What are you running into issues with? I think this is a relatively simple process if you just walk through the instructions and don't skip any of the steps. Plenty of people here happy to help if you want to give it a go
#274
Posted 07 November 2012 - 07:16 AM
That's surprising....and sucks. TiBU or Rom Toolbox Pro FTW I guess! Remember to only backup and restore apps and app data, not system data.
#275
Posted 07 November 2012 - 09:03 AM
Could someone please post a copy of their kindle.apk app?
thank you.
#276
Posted 07 November 2012 - 09:05 AM
I'm trying to install the JB leak, but the install keeps abort because it cannot find kindle.apk (i must have uninstalled it by accident because everything else i just froze with Titanium backup). I also tried installing the kindle app from the market and copying it to systemvendorapp but it still didn't like it.
thank you.
Fast boot back to 4.0.4 then install the ota then try again.
-tapped from my cm10 ktoonsez kernel'd Galaxy s3
#277
Posted 07 November 2012 - 09:34 AM
thank you.
Yep, I was going to suggest the same thing...grab Matt's Utility, it'll make it a painless procedure... I mean, if I had the files (I think you need the .odex file too?) I would send you...but I am already on JB so I doubt my files would be compatible with what it's looking for...
#278
Posted 07 November 2012 - 09:46 AM
By the way, how do you guys like JB on this phone? Are there any nasty side effects since this is an early leak?
#279
Posted 07 November 2012 - 09:59 AM
Does Matt's utility contain everything I need? I have the motorola usb drivers installed.
His utility has everything needed to get back to the stock/factory software. I have used it with no problems at all. I have not noticed anything nasty side effects besides a few apps not working correctly. All my main apps are fine. After using this there is no way I would go back to stock ics on this phone.
#280
Posted 07 November 2012 - 10:01 AM
I did the same thing, froze apps with titanium backup, then unfroze them for the update. It would not work no matter what I tried. So I used Matt's Utility to go back to stock and then I had no problems.
13 user(s) are reading this topic
0 members, 13 guests, 0 anonymous users
