Does anyone know if we can put the Photo Sphere camera on this build???
Yes. Go . I gave it a try and it works well.
Posted 06 November 2012 - 06:29 AM
Posted 06 November 2012 - 06:33 AM
Yes. Go
Posted 06 November 2012 - 06:34 AM
Thanks !!
Posted 06 November 2012 - 06:39 AM
While I did not encounter any root or sbf issue, I can regain root, can go back to ICS all day long. However, I have a different kind of problem. I lost IMEI, ESN, ICCID... they all show "unknown". Consequently, mobile network state shows "Disconnected". After a reboot, I will get 4G like normal for about 10 seconds. It acts as if the sim card isn't there, or that Verizon is blocking me. I've used Matt's Utility to go back to ICS, and everything works again. I've done this 3 times already, with same result.
Edit: I just took the sim out and put in my Maxx (not Maxx HD) and could get 4G service just fine.
Posted 06 November 2012 - 08:05 AM
Thanks to DroidRzr.com, houch80,chrisc2u, and NattyBee I am on Jelly Bean with NO problems. I love it on my Nexus 7 and so far it is awesome on my phone........s*$t now I have the rooting bug again. I think since I use my phone for business daily I will stick with the OTA leaks vs any custom Roms.
Thanks all,
Jamie
Posted 06 November 2012 - 08:07 AM
So there seems to be some issues with this. Is it worth the plunge?
Posted 06 November 2012 - 08:20 AM
Proud father of a US Marine
Posted 06 November 2012 - 08:47 AM
Glad you are up and running Jamie. Special thanks to DirtyDroidX for providing us with this wonderful leak!
Posted 06 November 2012 - 09:47 AM
Posted 06 November 2012 - 10:06 AM
Anyone run in to the issue of Foxfi not working after installing the leak? It fails and tells me to use Bluetooth Dun, and then that fails too!
Posted 06 November 2012 - 10:51 AM
FoxFi does the same for me as well :-(
Posted 06 November 2012 - 10:54 AM
Looks like Foxfi Dev may need to make some changes in JB
Posted 06 November 2012 - 11:10 AM
Perhaps - that's what I found with Llama, and a few other, "huh????"'s. So, dropped back.
Pretty cool we can do that, huh!!!!
Posted 06 November 2012 - 11:18 AM
Posted 06 November 2012 - 01:17 PM
Posted 06 November 2012 - 03:27 PM
Posted 06 November 2012 - 03:32 PM
have you tried Matt's utility? I that method to go back & it went without a hitch...Installed the leak the day it came out, went groovy etc etc etc. Now I want to go back and just get back on the official firmware.
I can NOT for the life of me flash back.
What I have tried:
RSD 5.7 & RSD 6.1.4 (rebooting after each install etc...)
Re-install the drivers from the Motorola Mobility website.
REBOOT THREE FREAKING TIMES
Taking my SIM/SD cards out
Different combos of connecting phone to computer and opening RSD
Changing the freaking levels of UAC on Windows...
My error: "Failed flashing process. Unknown fastboot command. (getvar)"
I don't get what I'm missing... I'm not new to this, but I feel like I am now lol
Help???
Posted 06 November 2012 - 03:33 PM
Sent from my RAZR MAXX HD using Tapatalk 2
Posted 06 November 2012 - 03:50 PM
Posted 06 November 2012 - 03:53 PM
where's external1
0 members, 25 guests, 0 anonymous users
