HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#181 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 06:57 AM
This dawned on me this morning when talking to @nattybee . For ppl that made a SU backup try doing this»»
in terminal emulator. Thanks to @Natty bee for finding the thread for me.
  • NattyBee likes this
#182 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 07:03 AM
To what are you guys referring? the LED Blinker? mine is working fine...
Mine wasn't working, I dont think, then I installed my LightFlow app and all seems fine now.
#183 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 07:05 AM
hmm...I wonder....I use Handcent, which controls the LED blinker for MMS/SMS...I wonder if that might make a difference, like forcing it to work on the SMS/MMS may have caused it to "awaken" in the system? maybe a stupid thought, but LightFlow making it work for you has brought that idea to my mind...
#184 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 07:06 AM
OK if you want your notification lights on or off you can do it by using SQLite editor or something equal.
1) Select Com.android.providers.settings
2) Settings DB
3) Settings
4) Line 84 edit to 1=true 2=false
Now save and reboot.
#185 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 07:28 AM
Chris2u also has an updated script to keep root when upgrading from ICS to JB. I have tested it and it works; however, this wont work if you have already upgraded.
#186 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 07:30 AM
I am now wondering the same thing, I seriously cant remember if my notifications were not working before hand, I don't think that they were. Now even when I turn off the LightFlow monitor the notifications still work now.
#187 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 07:35 AM
yeah, Handcent is one of the first apps I install on every device/rom I use, so I couldn't say if LED was working prior to installation or not
#188 Narffran
Narffran
  • 147 posts
  • Twitter:Fran_Granfield
  • LocationNorth of Boston MA
Posted 05 November 2012 - 07:42 AM
Sure is nice to see @NattyBee active again. He's almost giddy like a school girl with this phone. :P
#189 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 07:49 AM
haha, indeed, it is good to be back! sorry about my inactivity as of late... I do plan to be much more active once again...it seems my passion for this has been rekindled! :P or something like that...you know what I mean. be prepared to see much more of this hippy in the community ;)
and yes, I do love this phone, it's a truly sweet device for sure!
#190 TweakedSystems
TweakedSystems
  • 122 posts
Posted 05 November 2012 - 08:44 AM
will this work on RAZR MAXX?
#191 NattyBee
NattyBee
  • 647 posts
Posted 05 November 2012 - 08:46 AM
it'll work on the Razr Maxx HD, but if you're referring to the regular Razr Maxx, than no, this will not work...sorry...
#192 chrisc2u
chrisc2u
  • 50 posts
Posted 05 November 2012 - 08:52 AM
I didn't notice the notification not working either, but will take your word for it :). I am using LightFlow so I can put my big blinking light to sleep at night so it doesn't light up my room. A really nice feature of LightFlow (and one of their competitor apps (name?) as well)
#193 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 09:01 AM
2) Settings DB
3) Settings
I have found this in data/data/com.android.providers.settings/databases/settings.db, Once I go into com.android.providers.settings I have a databases and lib folders. I then choose the databases folder then go into settings.db, open with SQLite Databse Viewer then I see a list. Am I going to the wrong place? I am using root explorer to find the file.
#194 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 09:33 AM
You have to use SQlite
#195 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 09:44 AM
When I use SQllite Editor I still do not see the Settings after selecting com.android.providers.settings then settings.db, I have android_metadata, bluetotth_devices, bookmarks, secure, sqlite_sequence, and system, but no settings.
#196 SamuriHL
  • 44,205 posts
Posted 05 November 2012 - 09:46 AM
I'd be very surprised if that is the case. I know 2 ppl on the Razr M how had JB on it with no root and used the current root exploit while on JB without issue. However the HD did get that small security patch already so maybe that is what closed the hole. Not sure seeing as the M did not get that update I don't believe.
It'd not surprise me if they closed the exploit. Time will tell though. At least there's a work around to allow you guys to keep root. What sucks is not being able to determine if they up the security. I can imagine a situation where you install a new leak, root doesn't restore correctly, and then no fastbooting back. THAT would really blow. I guess what I'm saying is be cautious of the unknown. :)
#197 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 10:05 AM
i think its system after settings DB sorry
#198 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 05 November 2012 - 10:17 AM
Whoever lost root they can try this in terminal emulator This is only if you made a backup using OTA RootKeeper.
/system/su-
[font=inherit]mount -o remount rw/system[/font]
[font=inherit]chmod 6755 /system/bin/su[/font]
[font=inherit]then exit out of terminal and reboot your device. This should work. If anyone does not have root after making a backup using ota rootkeeper and is still having problems please PM me i have a few things ppl can try to maby restore root without having to start all over.[/font]
#199 houch80
houch80
  • 96 posts
  • LocationIllinois
Posted 05 November 2012 - 10:32 AM
Ha, ok, when I go into the system after settings.db, on line 84 it has media_button_receiver configured for amazon playback...
#200 racingelting
racingelting
  • 8 posts
  • Twitter:@racingelting
Posted 05 November 2012 - 10:41 AM
The updated root exploit does save a few steps (updating superuser and binaries before OTA Rootkeeper backup, temp unroot). Let me know if anyone would like the updated exploit posted with new instructions to save those steps. Thanks houch80 for testing the update!
Did you post this somewhere?
Thanks, Jamie
15 user(s) are reading this topic
0 members, 15 guests, 0 anonymous users
