HD Jelly bean 4.1.1 DROID RAZR HD HD JB
497 replies to this topic
#1 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 01 November 2012 - 07:00 PM
POPULAR
Well my friends it turns out that the DROID RAZR HD can get better. This is a NON OFFICIAL Jelly Bean leak , not an OTA, not from Verizon. I have installed this and been running it for a little bit. I can tell you Its fast and fluid, many changes, and yes Google Now works just fine. Oh I have to mention YES Temple Run works! All jokes aside we do know that you can get back to stock using either RSD lite or @Mattlgroff's Utility . Also we have no clue to how many more will come out till the official OTA roles out. If you choose to install this leak, please be familiar with using ADB and RSDLite.This is a simple process to get to JB.
  532.7KB   418 downloads
  163.87KB   520 downloads
  108.47KB   525 downloads
  532.67KB   480 downloads
  215.12KB   349 downloads
1) You must be a 100% stock with the 6MB maintenance OTA upate (0.7.2.XT926.Verizon.en.US)
2) Download the Update Zip >>>>>>>>>>>>>>>>>
or
Put on external1.
2a) Not sure if you need the crc file but get it >>>>>>>>>>>
or
Just put on external1 also.(Right click on link, "save as")
3) You do not have to back up any of your data. It will stay the same as you left it. Unless you feel like it.
4) THOSE WHO ARE ROOTED & WISH TO KEEP ROOT-
a) Go into Play Store > My Apps....update SuperUser
b ) open SuperUser-- swipe to the left info tab.
- Tap on the 3rd Line (SU Binary tap to check for updates)
- update your binary to the latest.
c) download OTA RootKeeper from Play Store
-open OTA Rootkeeper > protect root (or delete backup if you have one already, and then Protect Root)
- Temp Unroot
5) Power down device.
6) Boot into Recovery:
- boot up while holding Power + Volume UP
- use Volume DOWN to navigate to "Recovery"
- use Volume UP to select
- when you see the Android on his back with the triangle Exclamation > Press Volume UP & DOWN
7) Select "Update from External"
8) Choose Zip (Blur_Version.0.7.2.XT926.Verizon.en.US).
9) Profit !
TO RESTORE ROOT:
10) on boot-- open OTA RootKeeper.
a) Restore Root
b ) Reboot (root doesn't seem to take until rebooted)
11) you should now have your Root Privileges restored!
**** IF YOU CHOOSE TO UPDATE TO THIS LEAK YOU ARE ASSUMING ALL LIABILITYS AND/OR DAMAGE THAT MAY HAPPEN. DROIDRZR.COM IS NOT AT FAULT AND SHALL NOT BE HELD RESPONSIBLE IN ANY WAY, SHAPE OR FORM****
DirtyDroidX
If ever I have helped you in any way please hit the like button :D
I SPENT MANY HOURS DOWNLOADING/UPLOADING FILES LIKE THIS. PLEASE BE KIND ENOUGH NOT TO PUT THIS FILE DIRECTLY ON ANY OTHER WEBSITE. ALL WE ASK IS A LINK BACK TO THIS ORIGINAL OP. IF ANY SITE WANTS TO HOST THE FILE, THAT IS NO PROBLEM JUST PLEASE GIVE CREDIT WHERE IT IS DUE. THIS IS A COMMUNITY THAT DEPENDS ON EACHOTHER. THANK YOU !
  • Bignadad, quadjacks, imandroid and 27 others like this
#2 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 01 November 2012 - 07:06 PM
Awesome find, thanks DirtyDroidX.
#3 johnthehillbilly
Posted 01 November 2012 - 07:08 PM
Very nice........Still no JB love for og razr tho... :(
  • imandroid likes this
#4 tucstwo
  • Google+:tucstwo@gmail.com
Posted 01 November 2012 - 07:10 PM
Who's da man? U da man! Who's da man? U da man! Who's da man? I da man! Who's da man? Dirtydroidx! Big props people. Nice find!
  • JackTheRipper likes this
#5 mrbobrowitz
mrbobrowitz
Can we flash this to the RAZR HD MAXX?
#6 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
Posted 01 November 2012 - 07:25 PM
Yep :)
  • jroc likes this
#7 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 01 November 2012 - 07:26 PM
yes
#8 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
  • Twitter:@quadjacks
  • LocationFort Drum, NY
  • Current Device(s):Maxx HD
Posted 01 November 2012 - 07:31 PM
So who's gonna take the plunge to verify whether or not we can get back on the OTA path?
  • lownslow200sx and ajm144k like this
#9 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 01 November 2012 - 07:35 PM
lol yeah who is going to. I will try to go back in the am. my eyes hurt to bad to do it tonight. Im sure even if we cant sbf @mattagroff will be able to patch a boot img for us to get back on path like we did before.
  • mattlgroff, jroc and lownslow200sx like this
#10 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 01 November 2012 - 11:02 PM
For sure. That will definitely work again if we have to. :)
  • YankInDaSouth likes this
#11 dsel909
dsel909
  • 10 posts
Posted 01 November 2012 - 11:26 PM
#12 dsel909
dsel909
  • 10 posts
Posted 01 November 2012 - 11:28 PM
I just sbf back to ics i took the risk but we are good
no im lying dont sbf back lol
#13 SamuriHL
  • 44,414 posts
Posted 02 November 2012 - 05:18 AM
GUYS!!! Please check the security on the cdt.bin. I assume you have the fastboot files for this phone, yes? Run the CDTParser against the cdt.bin from the FXZ and then compare it against the cdt.bin from this update. That will allow you to know for SURE if the security has been changed. And I'm actually VERY curious about that so I'd appreciate if someone could do that. If you have the FXZ and this update and need help on how to check, please PM me. Thanks!
#14 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
Posted 02 November 2012 - 05:23 AM
I detect a BUBBLE BURSTER! lol
#15 SamuriHL
  • 44,414 posts
Posted 02 November 2012 - 05:24 AM
ROFLMAO! No, I just don't want to see guessing when we have a tool that's able to tell us BEFORE people flash it. LOL ;)
#16 SamuriHL
  • 44,414 posts
Posted 02 November 2012 - 05:49 AM
I'm looking at the update and the FXZ and I can honestly say this is one WEIRD PHONE! :) There is no cdt.bin partition. So, I'm looking and seeing what I can find for you all.
  • ajm144k likes this
#17 SamuriHL
  • 44,414 posts
Posted 02 November 2012 - 05:56 AM
It seems that the cdtparser is not going to help here. WOW, I really don't understand this phone. LOL. So, I guess someone is going to have to be brave after all and just simply try it. UGH.
#18 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
Posted 02 November 2012 - 06:08 AM
lol, yeah, what he said!
#19 quadjacks
quadjacks
    THE 4 of us!
  • 330 posts
Posted 02 November 2012 - 06:10 AM
I totally agree!
#20 SamuriHL
  • 44,414 posts
Posted 02 November 2012 - 06:28 AM
So Matt pointed out the error of my ways. LMAO. That's an S4 you got in this thing, not an OMAP. My apologies. However, if you do apply this update, keep it on your external1. If you try to fastboot back to ICS and fail, Matt's unstuck method can fix it so you can at least get back to this update. But not knowing the security is a bit disconcerting. ;)
13 user(s) are reading this topic
0 members, 13 guests, 0 anonymous users
