OK so I am rooted and have an unlocked bootloader on android 4.4.2. I can't seem to do anything with any recovery that I try to flash. Every time I try to install ROMs or anything for that matter I get installation fails. My recovery, which is twrp 2.7.1.0, does let me backup my current ROM but whenever I try to restore to it it says it failed. Leaving me to factory rest my device every time after I get an installation fail after I try to install a custom ROM, which is cyanogenmod 11. I've honestly never had these problems before on the nexus 7 that I have rooted so I'm not sure what to do. If you have any ideas on what I'm doing wrong, or if you can show me a recovery that works on android 4.4.2 that would also be nice. My device is the Droid RAZR M by the way. Any help would be very much appreciated.
Razr M( xt907 ) Recovery Problems 4.4.2 Kitkat
CWM8012
, Aug 08 2014 05:54 PM
xt907 razr m kitkat 4.4.2 recovery custom roms
1 reply to this topic
Posted 08 August 2014 - 05:54 PM
Posted 18 August 2014 - 04:41 AM
Which CM11 version are you flashing? Try wiping all data (under advanced wipe) except for your external SD and go from there. I had to do that before I could boot a custom ROM, as did some others.
Sent from my RAZR M (CM Nightlies) from Tapatalk Pro.
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
Also tagged with one or more of these keywords: xt907, razr m, kitkat, 4.4.2, recovery, custom, roms
