[Recovery]TWRP 2.8.5.0 (03-14-15)
recovery twrp KK bootloader 2.8.0.0 2.7.1.0 xt926 JB Bootloader 2.8.1.0 2.8.3.0 2.8.5.0
230 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 08 August 2014 - 03:11 AM
TWRP 2.8.5.0
For xt926
With 4.4.2 BL & Unlocked Bootloaders only
Change Log
Follow Link for additional information...
Click
Recovery installer:
4.4.2 Bootloader ONLY
Fastboot image only:
Now Remember Flash responsibly and read, read, read.......
  • ibolski, johnthehillbilly, cmh714 and 14 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 08 August 2014 - 03:35 AM
TWRP 2.8.0.0
For xt926 4.4.2 & Unlocked Bootloaders only
Also Unified MSM8960 for 4.1.2 Bootloader Devices
What's new in 2.8.0.0:
  • Fix a bug that caused weird graphics and touch issues
  • Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
  • Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
  • Add support for color in the console and give error, warning, and highlight lines different colors
  • Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
  • Improve handling of /misc thanks to mdmower
  • Improve setting of time on Qualcomm devices thanks to [NUT]
  • Allow using images on slidervalue GUI objects thanks to Tassadar
  • Allow using variables and addition and subtraction in variables for easier theming
  • Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
  • Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
  • Other minor fixes and improvements
Recovery installer:
4.1.2 Bootloader ONLY
TWRP 2.7.1.0 with Screenshot feature...
For xt926 4.4.2 Unlocked Bootloaders only
This will allow much faster trouble shooting while installing or coaching on how to install something. The mighty Developers updated the Source all I did was build it in with my ROM build. Tested and well see Screenshots below..
The only thing that I noticed different is the screenshot feature.
All other functions work normal.
To take these screenshots while in recovery mode is
the same way you take them on Stock.
Key combo Power + volume down.
It will place all Screenshots taken in your Picture/Screenshot
folder. If you have a external storage installed it will place them there
instead of internal.
Recovery installer:
Standard Theme
My Theme
Standard Theme
My Theme
ScreenShot of the Theme Home
#3 cmh714
Posted 08 August 2014 - 06:26 AM
Nice feature to add :)
  • nobe1976 likes this
#4 watson387
watson387
  • 128 posts
Posted 08 August 2014 - 02:31 PM
Very nice! Thanks for this!
#5 transmissiontech
transmissiontech
    Your Tranny Specialist
  • 7,484 posts
Posted 08 August 2014 - 02:39 PM
Id test it for ya but i dont think it would work on my bionic.... :ph34r:
Google pixel 32 gig....
#6 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 08 August 2014 - 03:36 PM
Nope that Bionic will get cornfused and not know what ta do..... B)
Sent from my VS980 4G
#7 watson387
watson387
  • 128 posts
Posted 09 August 2014 - 07:37 AM
This is so cool! lol
  92.84KB   95 downloads
#8 transmissiontech
transmissiontech
  • 7,484 posts
Posted 09 August 2014 - 08:02 AM
  66.5KB   91 downloads
From my bionic
#9 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 09 August 2014 - 08:45 AM
Hay look at you all updated and what not...
#10 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 09 August 2014 - 12:34 PM
I ran into problems where I couldn't flash a the latest CM11 nightly for KK-based Xt926 and gapps wouldn't flash either nor would SuperSu (the latest v2.02).
I had to revert back to the previous, non-screenshot version in order for it to work.
I can't remember off the top of my head what it said, but it came up in red colored fonts that the flashed failed due to the zip being bad, corrupted or something to that effect.
#11 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 09 August 2014 - 01:15 PM
I can't remeber if the verify zip file is checked or not in the older 2.7.1.0 by default..  Any one remember?
#12 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 09 August 2014 - 03:18 PM
No it is not
#13 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 09 August 2014 - 03:29 PM
OK I just ran through it a few more times. What is causing this error is the mounting of the system itself. After a ROM install the system is requested to unmount. Since gapps check the system/build prop for verification it fails. One must manually mount the system in order for the gapps to follow through... Going to see why this is happening. Maybe lack of busybox in the recovery.
#14 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 09 August 2014 - 04:10 PM
I bet your error looked kinda like that
$3π+ £®m€ ×X× ®∆z® |/|@xX Π¶ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
  • ibolski likes this
#15 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 10 August 2014 - 04:33 AM
Yup. That was it. Scared me at first because I thought something was wrong with my phone until I remembered I flashed this version. Makes sense now.
Thanks for figuring this out.
And look how the screenshot became so useful in this situation! ;)
#16 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 10 August 2014 - 01:21 PM
Busybox installs Fixed...
OP updated with new links
  • watson387 likes this
#17 ncsuwolfs
ncsuwolfs
  • 76 posts
  • Current Device(s):Razr HD (unlocked)
Posted 10 August 2014 - 06:29 PM
dont know if ive missed something along the way but ive always had the wrong date and time bug on twrp since kit kat, which is fixed in this version... awesome.... thanks
  • nobe1976 and watson387 like this
#18 watson387
watson387
  • 128 posts
Posted 11 August 2014 - 09:25 AM
Nice! Mine was always wrong too but I just checked it again after reading this post and it's right now! :D
#19 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 15 August 2014 - 05:17 PM
My WIP.... and yes it's going to be available for JB Bootloader.
  • Joseberga and watson387 like this
#20 spainter
spainter
    Droid Oracle
  • 3,339 posts
  • LocationUtah
Posted 15 August 2014 - 05:45 PM
Looks great Nobe.  Also I go with the others on the date fixed on my wifes phone.  First time it has been right since rooting and unlocking.
Also tagged with one or more of these keywords: recovery, twrp, KK bootloader, 2.8.0.0, 2.7.1.0, xt926, JB Bootloader, 2.8.1.0, 2.8.3.0, 2.8.5.0
