Nothing But Issues With This Phone After Rooting/unlocking
Posted 31 October 2012 - 11:37 AM
I rooted and unlocked my new s3 and experienced random freezes, reboots, and the screen freaking out in general.
When the black model came out, I promplty used odin to go back to stock, and exchanged my white for a black one.
I rooted and unlocked my black one and are experiencing the same problems.
I'm beginning to think either it's my computer or the EZ Unlock tool from the play store that's causing my problems.
I've ran blackbean, Liquid, Stock AOKP, and Eclipse on both phones. Experienced the problems above on all ROMs.
What do you guys think my problem is? I'm going back to stock right now and using the command prompt method to unlock my BL this time.
Posted 31 October 2012 - 01:23 PM
if you're still having issues, go into recovery, select Advanced, and select fix permissions. that might help.
Samsung Galaxy S III SCH-I535|16GB|stone white|rooted|bootloader unlocked|Ziggy kernel|Synergy ROM
Posted 31 October 2012 - 03:30 PM
I just went in to fix permissions and was greeted with the "phone is activating" screen. Had to lose out of it but so far so good.
Posted 03 November 2012 - 09:48 AM
Posted 03 November 2012 - 10:44 AM
Sent from my XT912 using Xparent ICS Tapatalk 2
Posted 26 January 2013 - 09:48 PM
We recommend a person check out
Posted 29 January 2013 - 04:13 AM
This link is for GSM carrier unlock.You can obtain swift way to unlock ones phone.
"quote from Samsung Unlock"
Cell Phone / Mobile unlocking is the process of removing the lock which prevents the device from accepting and being able to use a SIM card from a rival GSM network. Network providers place such locks on handsets to prevent the easy migration from one network to another. We provide unlock solutions which help our customer to remove these locks by inputting simple codes in to the handset with specialist instructions that allow access to special unlock menu's on the handset.
"/quote"
Not bootloader unlocking.
Pixel 2 XL, Pixel XL, Nexus 6, Nexus 5, Nexus 7, Samsung GS3, Bionic, OG Droid, SCH-i760, a flip phone or two, and a few others.
Posted 05 February 2013 - 08:49 AM
The only issues I have had is messing around with some tweaks that I didn't know how to use.
