I rooted and unlocked my xt926 bootloader over a year ago when I first got it. I would like to upgrade to the 4.4(Kit-Kat) bootloader. How would I go about this?
Thanks!
Posted 01 August 2014 - 05:54 AM
Thanks!
Posted 01 August 2014 - 06:13 AM
Posted 01 August 2014 - 06:56 AM
I am a little confused on what part of that OP shows how to upgrade the bootloader if you are already unlocked on the old bootloader. Am I missing something?
Posted 01 August 2014 - 07:03 AM
You can just go
. It was in the OP of the other thread I pointed you to. Just keep in mind, when you do it, you will need to upgrade your custom recovery to work on the KK build. There are links to that in that thread.
