HELP... Droid Rzr xt912, won't charge, won't turn on, ? inside battery, tried the 3 finger reboot...
? in battery wont power on wont charge
5 replies to this topic
#1 xyz
xyz
  • 6 posts
  • Current Device(s):Motorola
Posted 27 July 2014 - 04:07 PM
Someone please help me. I have a Droid Rzr XT912. It will not charge, it will not turn on. There is a ? inside the battery picture. I have tried to reboot with the old "3 finger salute" and nothing happened. Any ideas?
#2 stewie griffin
stewie griffin
  • 101 posts
Posted 27 July 2014 - 05:24 PM
On the droid x, from a few years ago, if the phone was plugged in without a battery, it would show an outline of a battery with a ? inside. It sounds like your phone is having battery issues. The battery may be going bad. Were you trying to flash a rom, or modifying it and accidentally delete something? Try turning the phone off and leave it plugged in and see if it will charge for a few hours.
  • xyz likes this
#3 livinginkaos
Posted 27 July 2014 - 05:39 PM
If you've dropped it, it may be that the battery connector had come loose as well.
sent from my G3
  • xyz likes this
#4 cmh714
Posted 27 July 2014 - 05:51 PM
I had to get a TBH adapter to jumpstart mine when it did that years ago.....I also replaced the battery....
  • xyz likes this
#5 xyz
xyz
  • 6 posts
Posted 27 July 2014 - 06:44 PM
Thanks for the help!! I didnt drop it. Its an odd story, everything is stock, Verizon. I got the phone from a friend who had it flashed it once. I erased and reset the phone back to the start. I played with manual programming a bit, ##program, typed in my mdn, min, got a new sim card from Verizon, changed the LTE settings to 3g test, and changed a few other things I've read in here. I was able to talk and txt, but no data w/o WiFi.  But I never hooked it up to a computer to reflash or root. Infact, I've never flashed or rooted before. I'm trying to learn for my own interest and enjoyment. Trying to teach myself. Untill this happened.
Like I said,I never dropped it, I turned it off for about an hour, and when I turned it back on, the phone worked, but had a ? in the battery. The phone eventually died, on the charger too.
Thanks for the help!!!
#6 xyz
xyz
  • 6 posts
Posted 27 July 2014 - 06:47 PM
I did let it charge for an hour or so, the phone actually came on for about 2 seconds, then died. I'll let it charge over night and go from there.
Also tagged with one or more of these keywords: ? in battery, wont power on, wont charge
