[ROM][Unified msm8960][Unofficial][Odex][4.4.4]BAKED (08-26-14)
unified msm8960 Dark New 4.4.4
131 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 26 July 2014 - 07:48 AM
From the creators of the Darkest, Fastest, Smoothest Firmware you will ever put on your Device
I give to you
In no Particular Order
CynogenMod, AOKP, AOSP, SlimRoms, Team Baked
Google, Droidrzr.com, Dhacker, Hascode, Livinginkaos, Tucstwo
What Works.
Everything that I know of.
Anything that comes to my attention will be added and
fixed to the best of my ability........
Installation Instructions:
NEED TO GRAB THE CORRECT ONE FOR YOU CURRENT Bootloader
- Copy GApps and the Baked zips to your internal/external SDCard
- Make sure you're running a proper and working custom recovery such as CWM or TWRP.
- Boot into Recovery
- Make a Backup of what you are running if you want to
- Wipe Data factory reset
- Flash Baked zip from internal/external SDCard
- Flash GApps zip from internal/external SDCard
- Reboot
Changelog:
08-26-14
Updated Fixes built in to KK BL build
More fine tunning on both builds
New Custom Default Wallpaper
Apex Launcher set as default
Viper Audio built into System (Still need to install Drivers)
08-22-14
Updated device tree with minor fixes
Added a few tweaks of my own
Optimized and Odex the ROM for performance.
Downloads:
ROM: KK Bootloader
MD5= 0ff4fc891f6c7e61c5d7f159786a8ed3
ROM: JB Bootloader
MD5= 060ae9084ae2b60aa12b902d7688568b
Suggested Gapps:
I don't normally ask for Donations and I will not start now, but if you feel the need then it will be greatly appreciated
  • mrlolli, nprevette420, cmh714 and 3 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 26 July 2014 - 07:49 AM
Having issues booting up and you are well known that your device is on the 4.4.2 bootloader. Well Guess what
Here is the fix.
FYI this will wipe out everything on your internal Storage and start out fresh......
1st. Boot into TWRP 2.7.1.0
2nd. Select Wipe settings then Advance wipe settings.
3rd. Check mark Data and then select "Repair or Change File System"
4th. Select Change File System
5th. Select EXT4 and Swipe to Change.
Once that is done Go back to home wipe data factory reset in the first wipe settings
Install ROM and Gapps.....
You will still be able to load up other ROMs also without issues since the format is Universal... Including Stock ROMs..
  • ibolski, phil_mccrackenn, brubblu and 2 others like this
#3 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 26 July 2014 - 11:14 AM
first lol
#4 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 26 July 2014 - 11:29 AM
And it only took you 3 hours.. lol
#5 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 26 July 2014 - 11:34 AM
Is it on KK bootloader?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#6 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
  • Current Device(s):motorola droid razr maxx hd
Posted 26 July 2014 - 11:41 AM
Right in the first post:
NEED TO BE ON THE LATEST STOCK KIT KAT UPDATE Bootloader
  • nobe1976 likes this
#7 taterfry
taterfry
  • 17 posts
Posted 26 July 2014 - 12:46 PM
I've dl'ded twice and when trying to install, it fails. I downloaded it on my phone, no pc atm. Dunno if it makes a difference. Can anyone else confirm?
#8 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 26 July 2014 - 01:08 PM
Make sure that system isn't mounted after you wipe... or just wipe data factory reset like it's posted in the installation instructions.
#9 cmh714
Posted 26 July 2014 - 05:09 PM
nobe been sitting at the boot animation for way too long :) tried a wipe after install and still stuck at the animation....followed the directions too :)
#10 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 26 July 2014 - 05:35 PM
That it's strange. Your on 4.4.2 boot loader too huh?
Sent from my VS980 4G
#11 cmh714
Posted 26 July 2014 - 05:37 PM
yes sir. np with Omni.
#12 dvp95
dvp95
Posted 26 July 2014 - 07:27 PM
Mine flashes just fine but it gets stuck on the screen that says BAKED and doesnt go anywhere.  This is after a clean wipe.  After awhile I can get it to reset to recovery and restore my backup just fine.  I noticed that this has happened to a few roms for me like Carbonite (stuck at the carbonite screen).  Other roms work fine on the kitkat like beanstalk and liquid smooth.  I had to try a few different versions of liquid smooth to get that to work or else it kept going to the Motorola screen.  Any idea why some work and some get stuck?
#13 sunkim50
sunkim50
  • 58 posts
Posted 26 July 2014 - 07:43 PM
Flashed fine here. Used TWRP with unlocked KK boot loader.
Performed wipe but ended up having to format data because I couldn't restore my backup.
WiFi seemed a bit weak but that's all. Everything else seemed to work correctly.
#14 themiladoman
themiladoman
  • 41 posts
Posted 26 July 2014 - 09:39 PM
Links are broken :(
#15 taterfry
taterfry
  • 17 posts
Posted 27 July 2014 - 01:31 AM
Same here... Finally got it flashed, stuck at the Baked screen
#16 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 27 July 2014 - 02:36 AM
People that are stuck on Bootanimation. What Gapps are you using? Since we all know that your bootloader has to be on Kit Kat Stock I am trying to narrow it down. Links please
#17 taterfry
taterfry
  • 17 posts
Posted 27 July 2014 - 03:48 AM
I tried with slim and then no GApps at all
#18 sunkim50
sunkim50
  • 58 posts
Posted 27 July 2014 - 05:16 AM
Not sure if it helps but I used PA micro GAPPS and got it to work.
#19 cmh714
Posted 27 July 2014 - 05:53 AM
I use the latest release of PA Gapps always, generally the Stock package.
Im gonna try again here in a bit and will post back....
#20 themiladoman
themiladoman
  • 41 posts
Posted 27 July 2014 - 06:29 AM
....the links are broken both just take me to a blank page anyone have a mirror or something would love to try this ROM out please and thanks
Also tagged with one or more of these keywords: unified, msm8960, Dark, New, 4.4.4
