Mobile Hotspot Hack
73 replies to this topic
#1 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 26 October 2012 - 12:02 PM
I'm driving ATM so I'm not going to get to into detail. If you don't have a subscription to the VZW hotspot/wireless teather app . This will bypass the security check and give you it for free.
All you need is
and
First go into moto settings, its the 3rd one.
  74.92KB   614 downloads
Then chose the only option in that sub menu. Next chose the middle one or this↓
  51.65KB   645 downloads
Now scroll down till you see "entitlement check " and change the 1 to a 0.
  108.95KB   572 downloads
Reboot and profit!
I have to stress that VZW. Can find out and you can get a crazy bill, highly unlikely though. DroidRZR and myself are NOT responsible for anything that can happen to your device.
DirtyDroidX
Tapped from my XT926, XT913 or SCH-i535.
  • loonie01, andlaw, syntrix and 1 other like this
#2 loonie01
loonie01
  • 190 posts
Posted 26 October 2012 - 12:32 PM
That's why I'm not giving up my unlimited.
  • wabmorgan likes this
#3 megahertz1970
megahertz1970
  • 228 posts
  • Google+:markw4itg@gmail.com
  • LocationPiscataway, NJ
Posted 05 November 2012 - 10:15 PM
Its there another app you cash use that you don't have to pay for?
#4 Guest_24v_*
Guest_24v_*
Posted 06 November 2012 - 05:17 AM
Yes, DB Browser. It's in the play store for free.
  • mattkilla likes this
#5 simaand
simaand
Posted 07 November 2012 - 11:25 PM
My SQL Light program is saying "No Databases Found" I did upgrade to Jelly Bean (still have root) Any help would be appreciated thanks.
  • Syeddanyal likes this
#6 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 08 November 2012 - 12:37 AM
Did you maybe accidentally deny the super user rights?
Sent from Razr Maxx running Full Throttle Killer Bean
#7 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Try clearing data in the app and uninstalling and reinstalling it.
#8 Gerland the Oracle
Gerland the Oracle
    Co-Owner and Support Specialist for Team Rage
  • 212 posts
  • Twitter:gerlandh
  • Google+:gerland.hardin@gmail.com
  • LocationJerome, Idaho
Posted 08 November 2012 - 01:17 AM
I have found that sqlite editor does not work on JB roms none i have tried anyway, just an FYI.
#9 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 08 November 2012 - 05:14 AM
This is true but this is not a rom its a Leak/OTA . It works fine for me . Hrmmmmm
#10 Gerland the Oracle
Gerland the Oracle
  • 212 posts
  • Twitter:gerlandh
Posted 08 November 2012 - 05:16 AM
LOL! Only i wouldnt see that!!
#11 jereroy
jereroy
Posted 08 November 2012 - 08:48 AM
I found in other site that WIFI Tether actually works in my RAZR MAXX HD with the LEAK JB OTA update IF in the settings --> Device Profile you set it to GENERIC ICS/JB (wlan0). This could be an option only available in the latest version 3.2 that i got from their google code website. Not the version found on the play store. Correct me if i'm wrong.
#12 simaand
simaand
Posted 10 November 2012 - 11:09 PM
Hey guys thanks for the suggestions, It looks like i may have lost root. I downloaded a Root Checker and it says not rooted. I followed instructions using Voodoo OTA root program to keep root while upgrading to JB but it seems like it wasn't sucessfull restoring root.. Although the program needs root to run and it works for some odd reason. Thanks guys ill keep trying to check if i have root or not.
#13 syntrix
syntrix
  • 44 posts
Posted 13 November 2012 - 03:19 PM
Using the free sql editor above is full of fail. Any recommendations on what to enter to get to the "app" db?
I don't mind paying the three bucks, but are there any other people that can verify tethering services? I just ran my battery down on a HEAVY test today, so charging back up. Don't want to JB it right now and experiment until I get a good charge. Again, are there any other confirms, especially with usb tethering?
#14 syntrix
syntrix
  • 44 posts
Posted 14 November 2012 - 03:41 PM
This works so far... exactly as stated in the first post. I'm using a usb tethering app.... before the entitlement mod, it did a "subscription check" and failed and then gave a vzw number to call.
Now when I launch it, no popup/number... see note about vzw charging you a bazillion dollars later!
edit: tried it with my "normal" usb tether app, and it works great! see note about my note about the vzw charge note that is covered in the op's post :) :)
#15 syntrix
syntrix
  • 44 posts
Posted 14 November 2012 - 03:52 PM
#16 TheloniousOne
TheloniousOne
  • 19 posts
Posted 17 November 2012 - 09:30 PM
how Can I grant super user rights to the app with super su?
#17 alexj714
alexj714
Posted 19 November 2012 - 02:29 PM
I can confirm this works. Typing this while tethered trough WiFi Tether,
#18 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 26 November 2012 - 01:55 PM
I am wondering if anyone is having the same issue as me, I have a Bionic running a custom Rom 247 based, I am trying to use the Hotspot Hack by editing the "entitlement check" i changed that to "0" and rebooted. Now When i go into Tethering & mobile hotspot, and click to turn on Mobile Hotspot.. It just freezes up and does nothing. It shows "Turning Mobile Hotspot on" but it never does anything beyond that. Anyone have any clue ?
Any Advice is Appreciated,
Thank you.
Ethan82691
#19 b_wat
b_wat
  • 79 posts
  • Google+:bwatkins232@gmail.com
  • LocationKnoxville,Tn
Posted 05 December 2012 - 09:34 PM
can anybody confirm this works for 9.1.41
#20 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 05 December 2012 - 11:29 PM
yes
Proud father of a US Marine
