Can't Flash Out Of Miui (Stuck!)
Posted 24 October 2012 - 03:50 PM
Posted 24 October 2012 - 03:53 PM
Posted 24 October 2012 - 03:59 PM
I have not tried wiping Dalvik yet. Trying now. What exactly do you mean by formatting system?Are you doing the wipes? Wipe Data, Cache, Dalvik and format system??
EDIT:
Dalvik wipe did not work...still booting MIUI.
Posted 24 October 2012 - 04:06 PM
EDIT:
Go to mounts and storage then go down to format system. After you wipe all 3 and format system install your new rom, only then reboot. If you format system and then reboot you will bootloop
Posted 24 October 2012 - 04:24 PM
Posted 24 October 2012 - 04:27 PM
Posted 24 October 2012 - 04:32 PM
my friend its time to fastboot start from scratch
I agree. Use this to get back to stock.
Also before installing roms be sure you have your safe side enabled in safestrap. I have a feeling you were doing all this on your unsafe side. You may want to read up a bit more and ask questions before diving too far into the deep end again.
Posted 24 October 2012 - 04:35 PM
ugh I can't even get to the Boot Mode Selection Menu...holding down Power/VolUp/VolDown creates a flash on the screen, then black. I'm guessing I'm going to have to fastboot from a computer. I'm downloading Matt's Razr Utility right now...am I heading in the right direction?my friend its time to fastboot start from scratch
EDIT:
Got it. Thanks for all the help, I think you're right about diving into the deep end.I agree. Use this to get back to stock.
Also tagged with one or more of these keywords: MIUI, flash, clockworkmod, cwm, ics
