help me i stuck with 4.4.4, with no root and locked BL
15 replies to this topic
#1 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 23 July 2014 - 01:02 AM
i got mobile in my hand in india few days before , i connected with wifi i got notification for update and i updated and its now running in 4.4.4,but
now i realized that i stucked with no root for 4.4.4 cant possible to downgrade also with a locked BL, i checked motorola website no official unlocking BL for droid maxx , screwed like anythyng,, also after the update battery draining like anything , also headphone also not detecting, before it worked perfectly in 4.4 , devs help me out , is any root method for 4.4
sorry for my bad english ;(
  • kerryh likes this
#2 SamuriHL
  • 44,378 posts
Posted 23 July 2014 - 02:22 AM
Nope. You're simply stuck. No root. No wp off. And no way to downgrade.
#3 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 23 July 2014 - 10:52 PM
sir,
if i buy unlock code for my mobile thru Chinese website,is it possible to install custom recovery and root?? is it possible kindly explain me how .. I'm planning to buy unlock code for my droid maxx.. if any help appreciated.. thank u..
#4 SamuriHL
  • 44,378 posts
Posted 24 July 2014 - 01:51 AM
I want nothing to do with people buying and using stolen unlock codes. What you do is your business but I want nothing going to do with that.
  • omahamatt, RikRong and spainter like this
#5 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 24 July 2014 - 02:51 AM
dear , I didn't get what u said can u simplify me what u exactly said .. I'm going wrong way ? buying unlock code .. ?? pls explain
#6 SamuriHL
  • 44,378 posts
Posted 24 July 2014 - 03:04 AM
You don't see anything fishy about having to buy an unlock code from "a guy in china"? If those codes were legit and not stolen Motorola property, you would not need to pay someone in another country to get one. I find the ethics of paying for stolen property to be wrong. Others do not share my feelings. I'm not telling you what you should or should not do. I'm simply saying that if you do choose to use a stolen unlock code you buy from some guy on the Internet in China, that you will have to do your own research on how to install custom recovery and root. The information is out there for you to find.
  • spainter likes this
#7 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 24 July 2014 - 05:12 AM
sorry actually I don't know more about this actually I read all r from internet .. I will never ever buy unlock code .. unless motorola officially release it.. thank u. sorry sir
#8 SamuriHL
  • 44,378 posts
Posted 24 July 2014 - 05:37 AM
Like I said, I don't care if you do or don't...it will get you unlocked if that's your goal, but, just know that they are selling you a stolen code.  If that doesn't bother you, then have at it.  I just personally have an issue with the whole thing.  You have to decide for yourself if you're ok with it.
  • aneeshmbabu and spainter like this
#9 livinginkaos
Posted 24 July 2014 - 05:43 AM
As far as DroidRzr is concerned, we do not condone the action and would appreciate that any further talk about going forward with such action not be done on here.  Thanks Samuri for voicing the concern and your position as well.
  • SamuriHL, RikRong, aneeshmbabu and 1 other like this
#10 aneeshmbabu
aneeshmbabu
    passionate
  • 222 posts
  • Locationindia
Posted 25 July 2014 - 01:18 AM
thank u
for the great advice
#11 jball
jball
  • LocationUnited States
  • Current Device(s):HTC ONE M8,NEXUS 5,DROID MAXX/ULTRA,GALAXY TAB S
Posted 24 February 2015 - 09:15 PM
How is it steeling if it requires your IMEI,its meant for your device.you can't use a code from another phone right ?
It would be a loop hole the same as all "root exploits"
#12 SamuriHL
  • 44,378 posts
Posted 25 February 2015 - 04:27 AM
And where do you think the unlock code comes from? Magic? They stole them from motorola. Just because it requires your imei doesn't mean it's legitimate. It wasn't that someone worked out an exploit that generates the unlock code from your imei. They simply stole a database containing them.
  • johnthehillbilly, transmissiontech and RikRong like this
#13 xXxTHECROWxXx
xXxTHECROWxXx
Posted 28 October 2015 - 12:39 PM
You can do a bootloader and you can flash back out of the current version you're in no matter. You can also gain root access running android version 4.4.4
I did it just yesterday using information from www.rootjunky.com
First you need to flash your device back then it'll run you through the steps on how to get past the bootloader and install root.
The only two things that I noticed that I wasn't able to do with the new root on the 4.4.4 version going from the original SU 6-7.2 back to SU 6-7 is that the Adaway apk (ad remover) doesn't work properly even though it still gets the job done, and that the SQL Editor apk for editing the entitlement check to gain free hotspot doesn't  work at all.
I'm currently looking for a sbf flash back to version 4.2.2 so that I can gain these two other features. Other than that though everything else is flawless.
Here's the videos and info on how to do the bootloader and sbf flash for the Droid Maxx, Ultra, Mini, etc.
www.youtube.com/watch?v=KyDnN3_hAmA
www.youtube.com/watch?v=hb0jKB8OFko&feature=youtu.be
Enjoy.
Crow
#14 xXxTHECROWxXx
xXxTHECROWxXx
Posted 28 October 2015 - 01:40 PM
You can flash back to another version. And you can do a bootloader change. I just did it with my new xt1080 Droid Maxx yesterday. It'll take you from SU 6-7.2 back to SU 6-7 and show you how to root it with it still using 4.4.4 version. However, my Adaway apk isn't wanting to work properly and also I cant edit the SQL editor for the hotspot. So I'm currently looking for a sbf flash to flash back to version 4.2.2 so these other things will work. But with this video you will get rooted and everything else but those two things (SQL edit for free hotspot and Adaway ad remover (works but doesn't cycle right).
www.rootjunky.com
#15 shawnlee6184
shawnlee6184
  • 118 posts
Posted 06 February 2016 - 02:27 PM
Any new firmware for security update 24.7.3obake maxx and working fastboot to stock ways? Rsd lite wont connect to phone when I go to flash stock firmwareCFCrkeys.zip. Can you flash CFC.releasekeys.zip from platform tools cmd on android studio if you put CFC files in platform tools folder and fastfboot flash each thing? Someway to flash xt1080 droid maxx so its able to root? Nothings worked so far. Any Recovery's(imgs) that work? Best way to fsstboot would be nice! I have firmware zip ready to flash. Thanks again.
#16 shawnlee6184
shawnlee6184
  • 118 posts
Posted 06 February 2016 - 02:43 PM
Does our droid xt1080 USB cable work or do we need to get another one from Motorola? Sometimes rsdlites been weird with moto drivers installed again. But not ever problems with USB cable. Does our stock cables not work? Droid maxx xt1080 stock locked 4.4.4
