[ROM][Stock 4.4.2][Base 183.46.15][xt926](Bloat-Free)DIY-ROM-(10-24-14)
Stock Base xt926
136 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 19 July 2014 - 11:50 AM
I am not going to go all fancy dance with this tread. I am posting this in hopes of other developers, or even new comers, to have a base that will install through TWRP to work with.
Installation Instructions.
You must have a Custom Recovery already installed.
You must already have the 4.4.2 OTA installed.
You must have a Unlocked Bootloader. A TRIPPLE MUST!!!!!
Place package on either Internal or External Storage.
Full Wipe that A$$ before installing this.....
Install package then reboot.
Changelog:
Updated base to 183.46.15
Updated PlayStore and Google Services
Added WiFi tether Hack
Updated installation Script (Shouldn't need to unmount System after full wipe)
Updated SuperSu and Su Binary (SuperSu.apk located in priv-apps)
Update: 10-24-14
This update is broken down Debloated Stock 183.46.15 update. No Root, No Busybox,
lightly modded build prop for tether hack and speed. This is going to be as far as this Project
will be going. If you want root well you should already know how to do that. If you want
anything else added, well that is why it is called DIY-ROM.........
The Goods
Stock Odex Debloated
Stock Deodexed Debloated
And to the icing on the cake for those that haven't taking the 183.46.15 update
Flash after Rom installation...
This Mod Still works on 183.46.15 update.
Advance Power Menu and 1% mod can be found in Below link.
Click
  • Memnoch73, Bama, eye__dea and 16 others like this
#2 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 19 July 2014 - 11:53 AM
first
  • nobe1976 likes this
#3 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 19 July 2014 - 11:58 AM
Had some time to kill... So what the Hell..  :p
#4 watson387
watson387
  • 128 posts
Posted 19 July 2014 - 01:49 PM
Wait, you can only flash this over the stock ROM? I can't flash this over Gummy or CM11, etc.? I'm just making sure I understand what I'm reading. Thanks for this man!
#5 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 19 July 2014 - 02:07 PM
This is the full Stock 4.4.2 Rom. Put together in a install zip for people to play with. If coming from another Rom such as Gummy the only thing that matters is that your bootloader be on the 4.4.2 and not 4.1.2.
  • watson387 likes this
#6 watson387
watson387
  • 128 posts
Posted 19 July 2014 - 03:09 PM
Cool! Thanks again man!
#7 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 19 July 2014 - 03:30 PM
cool!
#8 bytethegroove
bytethegroove
    #HappyEnding
  • 158 posts
  • Google+:bytethegroove
  • LocationBerwyn, IL
  • Current Device(s):Motorola Razr HD
Posted 21 July 2014 - 07:36 AM
now all we need is 1% battery mod and advanced reboot menu......and i mean without using xposed.....
I have my buuf theme that is slowly getting updated to KK....just soooo muched changed...and now im 1 handed(totaled my bike the other night)
so hopefully ill have something soon
peace
byte
I'm as honest as the day is long, The longer the daylight then less I do wrong!
My MIUI v4/v5 ICS/JB photon/electrify/ and now Razr HD offerings http://bytethegroove.com/PublicDL/
#9 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 21 July 2014 - 01:29 PM
You can do it man...
#10 parkerr
parkerr
  • Current Device(s):xt926
Posted 28 July 2014 - 07:37 PM
I followed the instructions and it won't boot. I can still get into my recovery with a lot of trial and error but cannot get it to boot the rom. Any help?
#11 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 29 July 2014 - 12:01 AM
A bit more information like is it stuck on boot animation or splash screen? What band base were you on when you tried installing this? What recovery are you using?
Sent from my VS980 4G
#12 watson387
watson387
  • 128 posts
Posted 29 July 2014 - 04:44 AM
Not to be a douche but this should be required info when posting about issues.
  • RikRong likes this
#13 bmwh0r3
bmwh0r3
  • 13 posts
Posted 23 August 2014 - 05:36 PM
Just tried both files. Both worked. Thanks man.
#14 justchiln
justchiln
  • Locationarkansas
  • Current Device(s):RAZR HD
Posted 02 September 2014 - 05:37 PM
this is the only rom i could get to work on my phone.
#15 michagin
michagin
  • 21 posts
Posted 03 September 2014 - 12:11 PM
you have to change the format to ext3 i believe to install most roms.  beware you loose all data on your internal.
#16 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 03 September 2014 - 02:13 PM
Its Ext.4 not ext.3.
Here is the fix... >>>>>
Updated OP with a much lighter version.
Bloat Free Completely stock...
Sorry guys I been holding out on this one  :D
  • michagin, watson387 and j37hr0 like this
#17 sunkim50
sunkim50
  • 58 posts
Posted 07 September 2014 - 12:08 PM
Thanks for this.. love the rom without all the bloat!  Works great!
#18 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 11 September 2014 - 05:25 PM
OP updated with link to additional Mods....
Enjoy
  • Joseberga likes this
#19 j37hr0
j37hr0
  • 13 posts
Posted 14 September 2014 - 04:00 PM
Holy smokes! That's a lot of bloat you pulled out!
#20 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 14 September 2014 - 04:19 PM
Hacked like Abe Lincon on the cherry tree...
