[Cdma Razr][Gingerbread][Rom] Infex V1.1 | Crackflashers Build |1/23/2012|
#161
Posted 23 January 2012 - 05:26 AM
#162
Posted 23 January 2012 - 08:45 AM
#163
Posted 23 January 2012 - 08:51 AM
Just clean up a lot of thing I was hasty doing. I will get it up shortly.
- Aixelsyd, (TSON), MrFrankRazr and 2 others like this
#164
Posted 23 January 2012 - 09:02 AM
#165
Posted 23 January 2012 - 10:11 AM
#166
Posted 23 January 2012 - 10:20 AM
Thanks for the info DT!Finished up on a full new UI, much cleaner, subtle, and just fits together much better, trimmed some more fat out, added MOTO SWYPE, MOTO Home Fix to swap launchers, updated all the apps to current versions. Push a few more tweaks in the system, added some others with regards to WIFI Scan interval and Ring Delay time. Permanent Root and Banner support in Terminal.
#167
Posted 23 January 2012 - 10:31 AM
Are you planing on releasing a gsm version, or will this stay cdma exclusive?
Sent from my XT910 using Tapatalk
#168
Posted 23 January 2012 - 10:51 AM
#169
#171
Posted 23 January 2012 - 11:02 AM
Awesome, I can't wait to see it! I'd like to see some of the spiffy stuff that is in Eclipse. I'm staying away from that ROM since I don't want Cheesecake. But the stuff it comes with is freakin awesome.
Why worry about it. For one you dont need to use cheesecake to update. And 2 its proven you can flash backwards t ostay on path. And last but not least the .173 update works wonders. Much smoother & the radio update is juts ROCKIN. I now have LTE signal at work where NO other LTE device gets it. And mind oyu I own a charge, Bionic, Razr, Gnex...etc. Only one to pull LTE is Razr after updating to .173
#172
Posted 23 January 2012 - 11:03 AM
Update V1.1 is in the OP. Enjoy
WOOT!!!! you rock bud. So happy to see you at least back hanging out with us Moto fans and here on DroidRzr.com.
#173
Posted 23 January 2012 - 11:39 AM
#174
Posted 23 January 2012 - 11:40 AM
Sent from my rooted DROID RAZR using Tapatalk
#175
Posted 23 January 2012 - 11:56 AM
Hey DT can i flash this right over v1? Thanks for the great ROM!
Your call... At the least Cache, Dalvik, Format System.
#176
Posted 23 January 2012 - 12:22 PM
#177
Posted 23 January 2012 - 12:23 PM
#178
Posted 23 January 2012 - 12:29 PM
#179
Posted 23 January 2012 - 12:37 PM
#180
Posted 23 January 2012 - 12:41 PM
Hate to ask, but if i wanted to revert to Arctic, should i wipe everything including data? Only reason i ask is that battery life seemed better on Arctic.
Has this ROM been out long enough to determine battery life?
