[Cdma Razr][Gingerbread][Rom] Infex V1.1 | Crackflashers Build |1/23/2012|
#121
Posted 22 January 2012 - 05:50 PM
#122
Posted 22 January 2012 - 05:51 PM
Seems kind of a negative post for something that is free. Try it out, if you dont like it reflash what you had. =)
how is that negative in any way?
i just want to have the best rom on my phone and to unsuspecting people like me who have not very good technical know how
reading features this like that make it sound good.
like for example on marketing, directx 11 is better than directx 9 but there are so many variables that could affect the experience and for the average consumer, they don't know the difference
that is what i am right now
#123
Posted 22 January 2012 - 05:52 PM
Basic differences that one can see arctic is deodexed which gives the ability of pull down toggles, 1% battery mods, etc... arctic is 100% themed this rom is not as of yet. Both are fast and stable however IMO and experience arctic does not do aswell on battery life. Actic also has a rebbot option in the power menu this one does not. Arctic has a few force closes in the beginning that this rom does not. The question really is do you want a fast stable rom or a fast stable rom with a theme.
Both are great roms and it really comes down to personal preference on a users part. It is awesome that in the last few weeks we have went from no choices to a conversation about which is the best and which to choose.
Thanks Th3ory for all your doing
thanks for the constructive response
#124
Posted 22 January 2012 - 05:55 PM
It is fast. My init.d script does what is needs to, along with the GPU and Events hacks... Nothing more is needed.
As for the rest of the list??
The GPS only benefits from a edit to the NTP Pool once.
CPU Optimization? ? Sounds like snake oil. Without a custom kernel, the OS itself is the only thing that can help. Less Latency, and management. It the OS is streamlined the CPU does its job.
Build.prop edits? Only a few things can happen with regards to them. The GPU force, disable the check system in the kernel, and the FPS are the only tweaks I made in the prop. IMO, all that is needed.
The syscrl and ram optimization come in for the init.d to complete everything.
Its not like selling a used car, If the ROM wasn't fast, I wouldn't say it, nor would I bother posting or running it.
im gonna upgrade to your rom, hopefully everything goes well
#125
Posted 22 January 2012 - 06:27 PM
Go here to download the swype apk file.This sounds amazing! If I am on Razrx 1.1, I don't need to wipe data then? I'm using safestrap. Last question, is Swype included? I really like and use it a lot
#126
Posted 22 January 2012 - 06:30 PM
#127
Posted 22 January 2012 - 06:35 PM
Hmmm, I didn't see it, that's why I flashed my apk. Dang it..maybe I missed it.MOTO SWYPE is in the ROM.
#128
Posted 22 January 2012 - 06:45 PM
Not a deal breaker for me. There is an app that can give one 1% battery readings without being DEODXED.wish this was deodexed!! cant walk away from the 1% battery mod lol. any chance of this being deodexed in near future?
#129
Posted 22 January 2012 - 06:53 PM
And this app is called...?
#130
Posted 22 January 2012 - 07:01 PM
Is everyone wiping data?
no.... i didn't and everything has been fine so far.
#131
Posted 22 January 2012 - 07:02 PM
Battery Circle from the Market for free.And this app is called...?
- frankyvee likes this
#132
Posted 22 January 2012 - 07:24 PM
Minor cosmetic bug: When you are in messenging app and click on a contact, the dial icon appears as the news icon.Not seeing that. I made a new build, more bloat yanked out and I am doing some UI work. Let me know.
See attachment: 41.94KB 7 downloads
Edit: If you guys want to fix this before the next release, just replace the PhoneBlur.apk and PhoneBlur.odex files from the 748 apk dump file over to your system/app folder.
Don't forget to change permissions.
#133
Posted 22 January 2012 - 07:26 PM
Thanks MrFrank
#134
#135
Posted 22 January 2012 - 07:27 PM
#136
Posted 22 January 2012 - 07:30 PM
yea, i use battery monitor widget, it also has 1% readout but having it on the right, where the battery is.. just cant beat the lookNot a deal breaker for me. There is an app that can give one 1% battery readings without being DEODXED.
as you can see, its straight sexy lookin.. lol
Sent from my rooted DROID RAZR using Tapatalk
#137
Posted 22 January 2012 - 07:35 PM
Note to everyone looking for swype: I had my swype backed up with titanium and just restored it there...that way I was able to keep my data from that app (took me a long time to program all those dirty words in that app lol)MOTO SWYPE is in the ROM.
#138
Also, if you have Beautiful Widgets...it has a widget too.Thanks MrFrank
#139
Posted 22 January 2012 - 07:41 PM
I don't see a reply to your question...but it won't work on the blur apps...it'll stay on the progress screen forever unless you reboot or the battery dies...you can flash the blur add on or you can extract it and put the particular apk and odex files you want in your system/app folderThis is probably a seriously noob question but I am going to ask anyway in case I ever decide for some damn reason to do it. But if you used titanium backup on any of the blur apps (social networking or something like that) , could you restore those apps while using this rom without issues?
Sent from my rooted RAZR. If its not rooted, its not right! Droidrzr.com
#140
Posted 22 January 2012 - 07:44 PM
+1 to this. I had to do the same thing. Works great. I friggin love this ROM!
