[Cdma Razr][Gingerbread][Rom] Infex V1.1 | Crackflashers Build |1/23/2012|
#101
Posted 22 January 2012 - 04:10 PM
#102
Posted 22 January 2012 - 04:31 PM
ROMS flying! ! Everything smooth as a Ken Doll! Only thing I found was contact actions shows news icon instead of call icon. Running great though. For some reason first boot was much quicker than any rom flash previous
Not seeing that. I made a new build, more bloat yanked out and I am doing some UI work. Let me know.
- mattlgroff likes this
#103
Posted 22 January 2012 - 04:55 PM
i am thinking of trying out a new rom.
you claim that this rom is FAST
i have a few questions about this rom
does this rom integrate things like this or similar
- Cpu Optimization
- Speedy v7 scripts
- build.prop tweaks
- Webtop HDMI Hack
- Dalvikvm tweak
- RTL support
- GPS lock/accuracy tweak
- Smooth scrolling mod
- Wake on volume keys mod
- Ram optimization script
- Supercharge custom scripts
- Proximity tweak
- Gallery 3D
i am very hesitant on trying out another rom because it seems like others have less features
can anyone give some pros and con about the current roms
#104
Posted 22 January 2012 - 04:56 PM
#105
Posted 22 January 2012 - 05:11 PM
i am currently using the arctic rom and it seems like the development on that rom has stalled
- Cpu Optimization
- Speedy v7 scripts
- build.prop tweaks
- Webtop HDMI Hack
- Dalvikvm tweak
- RTL support
- Proximity tweak
- Gallery 3D
It is fast. My init.d script does what is needs to, along with the GPU and Events hacks... Nothing more is needed.
As for the rest of the list??
The GPS only benefits from a edit to the NTP Pool once.
CPU Optimization? ? Sounds like snake oil. Without a custom kernel, the OS itself is the only thing that can help. Less Latency, and management. It the OS is streamlined the CPU does its job.
Build.prop edits? Only a few things can happen with regards to them. The GPU force, disable the check system in the kernel, and the FPS are the only tweaks I made in the prop. IMO, all that is needed.
The syscrl and ram optimization come in for the init.d to complete everything.
Its not like selling a used car, If the ROM wasn't fast, I wouldn't say it, nor would I bother posting or running it.
#106
Posted 22 January 2012 - 05:12 PM
Pardon the ignorance, but why no landscape mode for the home screen? Otherwise this seems pretty speedy so far man, great job. Diggin the boot animation as well. Thanks!
Is it on? What launcher? Not disable or touched on my end.
#107
Posted 22 January 2012 - 05:16 PM
I love the way you think! This ROM is super fast and smooth like butter! Great job!It is fast. My init.d script does what is needs to, along with the GPU and Events hacks... Nothing more is needed.
#108
Posted 22 January 2012 - 05:19 PM
#109
Posted 22 January 2012 - 05:22 PM
- Cpu Optimization
- Speedy v7 scripts
- build.prop tweaks
- Webtop HDMI Hack
- Dalvikvm tweak
- RTL support
- Proximity tweak
- Gallery 3D
Seems kind of a negative post for something that is free. Try it out, if you dont like it reflash what you had. =)
#110
Posted 22 January 2012 - 05:23 PM
+1Seems kind of a negative post for something that is free. Try it out, if you dont like it reflash what you had. =)
#111
#112
Posted 22 January 2012 - 05:24 PM
does this rom integrate things like this or similari am very hesitant on trying out another rom because it seems like others have less features
- Cpu Optimization
- Speedy v7 scripts
- build.prop tweaks
- Webtop HDMI Hack
- Dalvikvm tweak
- RTL support
- Proximity tweak
- Gallery 3D
Basic differences that one can see arctic is deodexed which gives the ability of pull down toggles, 1% battery mods, etc... arctic is 100% themed this rom is not as of yet. Both are fast and stable however IMO and experience arctic does not do aswell on battery life. Actic also has a rebbot option in the power menu this one does not. Arctic has a few force closes in the beginning that this rom does not. The question really is do you want a fast stable rom or a fast stable rom with a theme.
Both are great roms and it really comes down to personal preference on a users part. It is awesome that in the last few weeks we have went from no choices to a conversation about which is the best and which to choose.
Thanks Th3ory for all your doing
- raclimja likes this
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#113
Posted 22 January 2012 - 05:27 PM
#114
Posted 22 January 2012 - 05:30 PM
This sounds amazing! If I am on Razrx 1.1, I don't need to wipe data then? I'm using safestrap. Last question, is Swype included? I really like and use it a lot
My friend, unless it specifies otherwise always wipe. With your contacts synced with google and your apps backed up with titanium backup your talking 10-15 minute restore. Plus it helps devs find actual bugs vs bugs from not wiping.I am so happy roms are finally coming to the razr! Now I have a reason to keep hitting refresh...mwuahaha......
#115
Posted 22 January 2012 - 05:34 PM
#116
Posted 22 January 2012 - 05:35 PM
Thanks for a great ROM DT!
#117
Posted 22 January 2012 - 05:37 PM
Just make a backup of your current ROM and give it a try. Best way to find out for yourself if you'll like it.i am currently using the arctic rom and it seems like the development on that rom has stalled
- Cpu Optimization
- Speedy v7 scripts
- build.prop tweaks
- Webtop HDMI Hack
- Dalvikvm tweak
- RTL support
- Proximity tweak
- Gallery 3D
IMO, this flies. I've tried all roms currently available(that I know of) and this seems by far the fastest and smoothest. Never see anything less from Droidth3ory. He is the beezneez
#118
Posted 22 January 2012 - 05:39 PM
It does specify not to wipe data in the original post.
" Since we are just having fun... Save your Data. No one likes dealing with all that. LOL
You must however
Wipe Cache
Wipe Dalvik
Under Mounts and Storage Format /System"
#119
Posted 22 January 2012 - 05:42 PM
With all do respect to all other ROMs, this one has been the best for me. runs fast and smooth. I'll stick with it for awhile. For those user who have to have the 1% battery, go and download Battery Circle for free. if you need the Reboot option go and download Quick Boot.
Well said.
#120
Posted 22 January 2012 - 05:43 PM
