[Cdma Razr][Gingerbread][Rom] Infex V1.1 | Crackflashers Build |1/23/2012|
457 replies to this topic
#401 topdog031382
topdog031382
  • 131 posts
Posted 30 January 2012 - 01:29 PM
Nevermind I misunderstood lol.
#402 StDevious
StDevious
Posted 31 January 2012 - 05:09 PM
I got the RAZR today. It's on .748 system version and build number 6.5.1-73. Do I just flash the bootstrap CWM here
and then flash this ROM like other phones ? Or is there another step ?
#403 Tmc363
Tmc363
  • 182 posts
  • Twitter:@tmc363
  • LocationHouston, Tx
Posted 31 January 2012 - 05:28 PM
Thats it root install bootstrap and flash rom its that simple just make sure you read the op to ensure you follow all instructions for flashing to the letter so you wipe the proper things.
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#404 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 01 February 2012 - 09:28 AM
will it work with safestrap? or is bootstrap prefered?
#405 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 01 February 2012 - 09:36 AM
Works on both.
#406 jrtem9
jrtem9
  • 9 posts
Posted 01 February 2012 - 10:53 PM
Loving this rom so far! My only issue so far is no music player. Tried to open my music off SD card and got a cannot open this file type message. I like Motorola's player because of the option to change the sound effects. When I put it in 5.1 surround and set it to Home Theater, it sounds awesome coming through my bluray system or my truck system. Can you pick and choose from motoblur what you want to install and would the player even be in there? Or can anyone recommended a player app with these capabilities?
#407 ISSIHAVOK
ISSIHAVOK
Posted 01 February 2012 - 11:18 PM
installed this bad boy on safestrap and its running nice and smooth:D thank alot th3ory
#408 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 02 February 2012 - 09:14 AM
i keep getting a "cannot open file error" even winzip didnt like it....i down loaded 2 different times. any ideas????
#409 jrtem9
jrtem9
  • 9 posts
Posted 02 February 2012 - 09:20 AM
You don't open it. Just place the zip file on root of SD card. Reboot into safestrap or bootstrap then update from SD card or install from SD card if you did not rename it.
#410 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 02 February 2012 - 09:24 AM
yep put on card, safestrap, install zip from sd card, choose zip, select infex, and i almost instantly get a "cannot open file" error out of my phone.
#411 jrtem9
jrtem9
  • 9 posts
Posted 02 February 2012 - 09:49 AM
Did you have safe mode enabled is safestrap?
#412 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 02 February 2012 - 10:27 AM
yep....i have run other roms through safestrap and have razrx v1.1 at the moment and yes I wiped per instructions but im afraid my finger went through the paper :(
#413 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 02 February 2012 - 10:49 AM
5th download worked,,,,,nothing to see here, move along.
#414 jasong127
jasong127
  • 25 posts
Posted 02 February 2012 - 06:34 PM
I did a search on this topic and didn't see anyone else ask... what about the calendar? Doesn't seem to be there. Did the cache/dalvik/system format before flashing.
#415 KANYONKRITTER
KANYONKRITTER
  • 41 posts
Posted 02 February 2012 - 06:57 PM
Weird.....my calender is there and uo to par.
#416 mindrazr
mindrazr
  • 18 posts
Posted 03 February 2012 - 12:47 PM
Love this ROM. Fast and clean.
#417 RandomBob
RandomBob
Posted 03 February 2012 - 03:50 PM
Very nice rom, any chance for a 1% battery increment? It doesn't seem to show more than 20% for me...
#418 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 03 February 2012 - 03:51 PM
Can't happen... It is a Odexed ROM. They don't take well to mods.
#419 weaponx
weaponx
  • 413 posts
  • LocationTX
Posted 03 February 2012 - 04:06 PM
try power amp music player. Best one IMO
Hey bub, I'm not finished with you yet..... SKNIT!!
#420 frankyvee
frankyvee
  • 74 posts
  • LocationGeorgia
Posted 03 February 2012 - 04:07 PM
Then try DT's Abysm ROM it is Dodexed and there is a link to the 1% battery update you need to flash after you install the ROM first.
Go here to get it from OP.
