[How-To][Mobile-Downgrader] Flash Back 1.0 (09-14-14)
downgrade flash 4.1.2 flash 4.4.2 easy button TWRP 2.8.0.0
46 replies to this topic
#1 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 15 July 2014 - 03:41 PM
This project has been on my mind for sometime now, and I finally got around to free up some time to look more into it. My first attempt was to just install a different boot.img, but that just wasn't going to happen. The whole reason for this project was to make it easier for one to downgrade and revert in between the 2 different Base versions without the use of having to hunt down the PC to fastboot or RSD. I have used both zips which in turn allowed me to revert and downgrade through TWRP so I could install source built roms, stock based roms and also restore TWRP backups from both bases. After heavy testing I am releasing this to the Unlocked community so you may have more choices to use without needing a PC by your side. I created 2 different installation zips that install through TWRP Recovery. One is to be used to downgrade your current 4.4.2 system to be able to install 4.1.2 based roms. The other will basically revert those changes so that you will be back onto the 4.4.2 base system. Both come with there matching updated TWRP recovery programs for the base that it will be used on. Also a Slightly modified boot-logo will replace your current one, If you still have the unlocked bootloader warning you are welcome and if you have a favorite one that you use you can always unzip these and replace the logo with the one of your choice. Installation Instructions below must be followed so that everything will fall into play. Please Read, Read, then Read again. I have used this multiple times to get it setup so that one will not have issues while using this. So if you don't read just put the phone down and step away........
Thanks in Advance.
To the Testers that got to use this before you did
and put it through the hoops to make it easier to
use for you.
To Jay and Teamlightspeed.com for server space
To Droidrzr.com.......
And yes to that tech at Motorola that made the
mistake....Much Thanks.
Before Starting this I must advise backing up what is on your internal storage first. Why you ask, well Moto thought that they wanted to change the format of the data partitions. The data/cache and data/data partitions are fine as they get changed when you do the Factory reset before flashing, but some testers had issues accessing data/media which is the internal emulated storage on the first install of FlashBack to 4.1.2. The processes only has to be done once so that when you are downgrading and reverting you won't have issues accessing the internal storage.
FORMATTING INTERNAL STORAGE
Back up what ya got on the current ROM you are on YOU WILL LOOSE EVERYTHING IF YOU DON"T
Boot into current TWRP 2.8.0.0 then go into wipe settings then press Format Data. You will be given a warning and will have to type the word "yes" in order for it to proceed. Once this is done it is done you will not have to do this any longer. Boot back into the ROM that you are currently running and transfer back over the content that was once on your internal storage.
Changing ROMs (Fresh Clean installs Either a 4.1.2 base or 4.4.2 base)
1. Download both installation zips to you Internal or External Storage (External preffered)
2. Choose the ROM that you would like to run and note the Stockbase on which it was built from (Either 4.1.2 or 4.4.2)
3. Boot into TWRP recovery. (If you don't like it oh well it is what you are getting with these zips.)
4. Once in TWRP recovery you are going to go into wipe settings then advance wipe settings and choose data, cache, dalvik and system then wipe.
5. Install the FlashBack zip that will be needed for that ROM to boot.(The updater is setup to boot back into recovery after it is done)
6. Once back into TWRP recovery perform a wipe data factory reset then install the ROM of choice and if it needs Gapps throw it in as well.
7. Reboot into System and Enjoy being unlocked.
Restoring a backup (Either a 4.1.2 base or 4.4.2 base)
1. Download both installation zips to you internal or external Storage (External preferred)
2. Make sure you have that backup in the proper folder for TWRP to see it.
4. Once in TWRP recovery you are going to go into wipe settings then Advance wipe settings and choose data, cache, dalvik and system to wipe.
5. Install the FlashBack zip that will be needed for that base to boot.(The updater is setup to boot back into recovery after it is done)
6. When it boots back into recovery then you can restore your backup of choice.
7. Go back into wipe settings then Advance wipe settings and choose cache plus dalvik then wipe.
8. Reboot into System.......
Droid RAZR M xt907
Question: Will this allow me to update to the official 4.4.2 without having to fastboot?
Answer: No, You will need to be on 4.4.2 first and be Unlocked before attempting this.  :wacko:
Question: Will this work even if I am not unlocked?
Answer: Put the phone down and just walk away before you break something.  :o
Quesiton: I have a different device that is not posted on here will this work on that?
Answer: Refer to the answer from question #2  :blink:
Question: My phone is dancing around and acting weird is that normal?
Answer: Yes. The reason for that is because it is free from restrictions.  :D
  • SamuriHL, livinginkaos, nprevette420 and 6 others like this
#2 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Reserved
#3 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 15 July 2014 - 03:59 PM
first
  • nobe1976, shane1 and jl90 like this
#4 jl90
jl90
    \m/
  • 1,642 posts
  • LocationPhoenix, Az.
Posted 15 July 2014 - 04:16 PM
Second...I was eating dinner. Lol! :)
  • Bama and nobe1976 like this
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
You got first post but i got first test. Lol. I tested it out yesterday :D
Great work Charles, this will be very useful. Thanks again.
  • nobe1976 and randysw like this
Need Help? Send me a message
#6 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 15 July 2014 - 04:25 PM
I think there is more of a call for this since more people are unlocked now.... Gotta have that easy button..
  • nprevette420 likes this
#7 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 15 July 2014 - 05:00 PM
Somebody has been busy!
  • nobe1976 likes this
#8 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 15 July 2014 - 11:25 PM
Can we now flash JB and KK ROMs with TWRP 2.7.1.0 with this?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#9 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 16 July 2014 - 02:02 AM
Your one of those that scan through the OP huh.......  :p
This is going to switch you Base and TWRP on the fly. The FlashBack to JB will install TWRP 2.7.0.0 that will allow you to properly prepare your device to install a rom off of that base.
  • Noigel likes this
#10 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 16 July 2014 - 01:27 PM
If you flash the JB flashback then it installs the JB bootloader and whatnots and TWRP 2.7.0.0 and you can flash roms built for the JB bootloader. IF you flash the KK flashback then it installs the KK bootloader and whatnots and TWRP 2.7.1.0 and you can flash roms built for the KK bootloader
#11 moroshek
moroshek
  • 62 posts
Posted 16 July 2014 - 05:51 PM
works like a CHARM! THANKS
#12 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
  • Current Device(s):XT907 jbbl Blisspop
Posted 17 July 2014 - 12:11 AM
Very cool! I'll be downloading this when I get home for sure. Thanks!
Tapatalk'n it from my XT907 (MoKee 4.4.4) on Page Plus Cellular.
#13 randysw
randysw
  • 20 posts
  • LocationJamaica
  • Current Device(s):Motorola Droid RAZR M XT-907
Posted 17 July 2014 - 06:09 AM
Thanks you so much for this my good sir much appreciated!
EDIT: Hi im not sure if you can advise me. Im trying to backup my data folder, but it says google wont allow me to do it, (using RES file explorere) Do i need another program to do this to bypass the google blockade? It says if im rooted (which i am) i can perform all these functions, but it just wont do it x.x
EDIT: it seems i misunderstood something, but everything is ok now, thanks again!
Motorola Droid RAZR M XT-907 running Kitstalk 4.4.4 ROM
#14 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 July 2014 - 12:23 PM
Ive tried to zip it then move the zip, but at the last stage of compression it just seems to loop on itself x.x
Google shouldn't be blocking it. Try hooking it up to your computer via USB and copying it to your PC
#15 xKroniK13x
xKroniK13x
  • 284 posts
  • LocationAtlanta, GA
  • Current Device(s):Moto X 2014 Pure Edition || Motorola DROID RAZR M || Archos G9 101 || Microsoft Surface Pro 2 || Chromecast
Posted 18 July 2014 - 06:46 AM
Worked great, but for some reason JB based ROMs wouldn't connect to WiFi... it would detect the network, and upon hitting "Connect" nothing would happen. I tried Validus 6.0, Paranoid and the CM11 M8 Snapshot... all the same issue.  :blink:
EDIT: Nevermind... I'm an idiot.  ;) Great tool!
Moto X 2014 Pure Edition Unlocked on Pure Rooted 5.1
#16 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 18 July 2014 - 08:27 AM
Glad ya got it worked out and also glad this tool comes in handy for alot of people... $3π+ £®m€ ×X× ®∆z® |/|@xX Π¶ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
#17 xKroniK13x
xKroniK13x
  • 284 posts
Posted 18 July 2014 - 08:41 AM
Glad ya got it worked out and also glad this tool comes in handy for alot of people...$3π+ £®m€ ×X× ®∆z® |/|@xX Π¶ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
It works great as long as you type your WiFi password correctly ;)
Sent from my DROID RAZR M using Tapatalk
#18 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 18 July 2014 - 08:42 AM
Yeah that would help out too 😚
  • xKroniK13x likes this
#19 thewraith420
thewraith420
    Crack Flasher
  • 112 posts
Posted 20 July 2014 - 08:20 PM
Do you plan on putting this on XDA or mind a link over there? It really is handy to have on my sdcard
#20 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 21 July 2014 - 02:09 AM
Me personnaly would rather keep my Download links here. Just like my Omni Rom. If you would like to create a tread over on XDA then by all mean I cannot stop you, but make the Download links point back ro this tread. Much appreciated.
  • livinginkaos, jl90, xKroniK13x and 1 other like this
Also tagged with one or more of these keywords: downgrade, flash 4.1.2, flash 4.4.2, easy button, TWRP 2.8.0.0
