[FXZ] 4.4.4 21.11.21
14 replies to this topic
#1 SamuriHL
  • 44,103 posts
Posted 13 July 2014 - 03:52 AM
WARNING: You REALLY need to UNDERSTAND and read EVERYTHING or you MAY brick your phone!
Purpose of this thread:
To get you, the locked or unlocked Droid Mini owner, from any version to 4.4.4 (SU4.21).
Things you will need:
FXZ SU4.21
Instructions:
Use the RSD Flasher with KEEP DATA to flash this on your phone with RSD.
OR
Use the House of Moto with KEEP DATA to flash this to your phone with fastboot.
This will get you a clean OTA install with no data loss.  You will lose root.
  • dee3 likes this
#2 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
  • Current Device(s):DROID RAZR M
Posted 16 July 2014 - 06:25 AM
Thx so much. I wonder if after this, safestrap would still be an option at boot? Probably not. If so, I could just reflash SuperSU, but with this phones inability to downgrade software I don't wanna be the rootless guinea pig.
#3 SamuriHL
  • 44,103 posts
Posted 16 July 2014 - 07:31 AM
If you FXZ this update on a locked phone, you will be rootless period.  FXZ's reflash all the partitions.  Root never survives.  Nor will safestrap.  Only your data partition remains untouched.
#4 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 16 July 2014 - 08:04 AM
I meant just flashing the needed parts myself via a modded .XML file. So I would flash only system, boot, modem, for now, in theory, I might keep safestrap as it's a separate directory. Then could possibly reflash superSU. I am a bit more savvy with RSD and fastboot, than your average user. Basically, I could do what you do with your HouseOfMoto. Just a little different.
#5 SamuriHL
  • 44,103 posts
Posted 16 July 2014 - 08:48 AM
Well you may be savvy with RSD and fastboot, but, you still don't appear to know where root and safestrap hooks live.  As soon as you flash system, you're done with both.  The su binary will be gone as will the hooks for safestrap as they both exist on the system partition.  Flashing that will completely overwrite system with the stock system img file.  IOW, there's no way to do what you're suggesting.
#6 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 16 July 2014 - 08:57 AM
Okay. I knew root itself would be gone as in /system/xbin/su. I just thought safestrap created a separate folder in / . for example like /SS so that even when you flashed /system safestrap could stay put. My bad.
#7 SamuriHL
  • 44,103 posts
Posted 16 July 2014 - 09:11 AM
Safestrap has to install its hooks on the system partition.  There are various ways he does that and I'm not up on the latest, but, it's always done on System.  So as soon as you wipe system, those hooks are gone and you lose safestrap.  Without root and WP off, you can't add them back in so flashing any part of this FXZ would lose both abilities.
#8 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 16 July 2014 - 09:13 AM
Yeah I got ya. Some weird symlink thing I'm sure.
#9 SamuriHL
  • 44,103 posts
Posted 16 July 2014 - 09:26 AM
FYI Skrilax_CZ is posting the images to the sbf site now and they md5 matches the files I posted.
#10 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 16 July 2014 - 09:33 AM
Sweet
#11 Flanger
Flanger
  • 18 posts
  • LocationTB
  • Current Device(s):Droid Mini XT1030
Posted 05 October 2014 - 11:55 PM
Hello.
Currently I have brand new factory unlocked (I believe it is a subsidy unlock by Motorola) xt1030, which came with 4.4 build SU2-3.3. Is it possible to unlock bootloader on this build? I would love to unlock it, before it becomes impossible to do. Phone bugs me with 4.4.4 OTA update messages :D
#12 Flanger
Flanger
  • 18 posts
  • LocationTB
Posted 10 October 2014 - 11:51 PM
I've found a non free software called Sunshine. Is it the only way?
#13 SamuriHL
  • 44,103 posts
Posted 11 October 2014 - 04:38 AM
Yes.
#14 carbonat87
carbonat87
Posted 12 January 2015 - 01:40 AM
Hello guys. I've bricked my Droid Mini with SU5-24 (Android 4.4.4) into qdload mode by blbrick and I didn't know blankflash from version 4.4.2 of official firmware wouldn't help me to restore boot. So, I'm asking you for dumps or backups of sbl3, aboot, tz, rpm, sbl2, sbl1, partition partitions from your Droid Maxx/Ultra/Mini with working SU5-24 firmware.
Edited by carbonat87, 12 January 2015 - 02:23 AM.
#15 manferrot
manferrot
  • Current Device(s):xt1030
Posted 26 March 2016 - 10:14 PM
Hello
How I could solve my problems with the mini droid ?
I can not just install a firmware stock with RSD Lite or House of Moto
Because when the process ends and it all ends properly droid mini starts as it was previously
notes
Normally you can not use because if you installed a apps and then turn off the cell this starts restarted without any data
How do I fix ?
