{Rom}{Full Throttle Retribution V2 Cm9}{10/19/12}
cm aokp ics full throttle
220 replies to this topic
#1 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 19 October 2012 - 10:11 AM
Full Throttle Retribution (CM9)
Based off DHacker and Hashcode's CM9
This ROM is a droidrzr.com exclusive. DO NOT post this ROM on any other site. You can make a link to this thread but do not post the zip file of this ROM to a different forum.
We would personally like to thank the following people in no particular order:
Dhacker & Hashcode - without them we would have no custom roms
- For the Boot Animation
- For all the wallpapers he has made
- Amazing Keyboard and vtwinbmx Light!!!
- Letting me use his inverted Gapps
-For the Full Throttle Theme
prstorero - Full Throttle Neon Green and Killer Extras
Aixelsyd, desireaftergod, and Brian for being my amazing testers and giving me feedback
Whirleyes - For the extra modules
RinkleMcbally22 - For Awesome Wallpapers
ZKK007- Pink Floyd Theme
- New Purple theme
Nobody but you is responsible for what YOU DO TO YOUR PHONE! You take on ALL RESPONSIBILITY by flashing this ROM!
Rom Features
SIO baked in
Changeable Governors
Data on Boot
Zipalign
Database Defrag
Custom Wallpapers (look in AOKP Wallpapers for them)
Custom Theme
Custom Softkeys (extra flash)
WiFi, 3G Tweaks
RAM, Disk, Cache Tweaks
Kernel Tweaks
GPU Tweaks
Gamma/Color, Screen Quality Improvements
Dalvik Cache Reliability Improvements
Battery Tweaks
Built in Inverted Gapps
Extra Goodness
Full Throttle Tweaks ( yeah we not saying what under the hood!!!)
This thing is Tweaked so hard I can't begin to tell you everything that has been done, Fastest strongest Throttle Yet,
A lot of things in this ROM actually have a tendency to slow things down. Gamma/dithering tweaks included for screen quality, dalvik optimizations were chosen for integrity over speed, etc. But this ROM is still the fastest around! Make sure you reboot and wipe dalvik and cache at least once after everything is set up! Then reboot once more. After that try not to wipe anything as it will get faster the longer the caches are used. It will take a few hours to settle in so benches will be slow at first. ENJOY!!!
You must be on ICS KERNEL to Flash this Rom!
Safestrap-ICS any version must be used to flash this ROM!
Install Instructions:
Download ROM and Full Throttle Gapps, and softkeys (if you want them) from links provided below.
Place ROM, Gapps, and softkeys, on your external sdcard
Reboot into recovery
Format System
Wipe data/factory reset
Wipe cache partition
Wipe dalvik cache
Flash ROM
Flash Gapps
Reboot
Set up phone
Wipe Cache and Dalvik
If you choose to at this point you can flash Killer Theme - (This initiates zipalign and database defrag)
Reboot
After that is done if you want to use SoftKeys and/or Killer Theme then boot into recovery once again and flash then reboot.
Flash and Enjoy!!!
Known issues:
Webtop
Hdmi
Do not forget to change the Governor on first Boot, it will run default until you do
hotplugx is recommended for Best performance and battery life
Download Links
Full Throttle Retribution:
Full Throttle Gapps:
Harley Davidson Theme:
Full Throttle Killer Blood Red Theme:
Full Throttle Killer Blue Theme:
Stronger Haptic Feedback:
Softkeys:
Purple Theme :
Full Throttle Wallpapers:
Pink Floyd Theme: So sweet !!!
The softkeys are extra you can download and flash if you want them. To remove them flash rom with a cache and delvik wipe
If you choose to donate to Full Throttle Squad, send a PM to one of the Developers to find out how.
If you like this ROM then please click the button Below!
  • davinmj, devlop, jbag1489 and 8 others like this
#2 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
ScreenShots
Posted ImagePosted Image
#3 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 19 October 2012 - 10:12 AM
one more
#4 jerkwad
jerkwad
  • 109 posts
Posted 19 October 2012 - 10:44 AM
but does bluetooth work? ;-)
Looking forward to trying this out after I get out of the office - thanks for putting in all the hard work!!!
(seriously, don't answer that first question)
#5 D Stave
D Stave
  • 175 posts
Posted 19 October 2012 - 12:18 PM
Is this sexy piece of hotness the one with linaro?
#6 schollianmj
schollianmj
  • 57 posts
Posted 19 October 2012 - 12:46 PM
I have been waiting for this one. I loved the first version you put out but the camera flash issue and the MS issue was a no go for me as I tend to use both fairly often. Hoping they are solved in this one... Downloading now and will find out soon. also how is BT in this one? do we still loose all volume if there are no connected devices but BT is still on?
Razr Maxx OTA, Rooted, Probably have some random ROM installled...
#7 papanut
papanut
  • 107 posts
Posted 19 October 2012 - 01:04 PM
cm9 had those issues?
  • davebob likes this
#8 saophen
saophen
  • LocationBeaufort, SC
Posted 19 October 2012 - 01:17 PM
Sorry I am kinda new to this whole hacking phone stuff. I currently have my razr flashed with simplex rom but I am starting to have problems like my phone icon disappeared and weird stuff happens when I browse the web. I reflashed it and some of the issues went away. I downloaded rom toobox and its like some of the features on there don't even work. The only thing I was able to change was my 3g icon, everything else wouldn't change like the signal bar and the battery icon. I'm downloading this rom right now, to flash it! Thank you for your hardwork!
#9 mikedav
mikedav
  • 18 posts
Posted 19 October 2012 - 02:36 PM
Thank you for getting this out. Love the first, know I'll love the second!
#10 D Stave
D Stave
  • 175 posts
Posted 19 October 2012 - 02:45 PM
I downloaded no frills and there is no hot plug x or sio?
#11 papanut
papanut
  • 107 posts
Posted 19 October 2012 - 02:48 PM
I went into settings and used performance and things looked fine.
On another note, when I signed into google play it didn't show my apps as being purchased, clearing play store cache and data cleared it right up.
I installed the blue theme, very nice looking rom, thank you
#12 D Stave
D Stave
  • 175 posts
Posted 19 October 2012 - 02:52 PM
I'll redownload it later and reinstall. Wonder if its a ss3 issue
#13 Stealthyscooby
Stealthyscooby
  • 92 posts
Posted 19 October 2012 - 03:00 PM
+1
#14 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 19 October 2012 - 03:03 PM
Maybe download again that odd I'm on ss3.04 everything there
#15 D Stave
D Stave
  • 175 posts
Posted 19 October 2012 - 03:48 PM
OK. I had it after install. After reboot with cache and dalvik wipe it said android is updating updating applications and then they were gone along with a super user permissions error.
#16 ifonekillr
ifonekillr
  • 56 posts
  • Twitter:@ifonekillr
  • LocationIndiana
Posted 19 October 2012 - 06:30 PM
I haven't been this excited about a rom since....um...ever. Damn download is taking forever (read: impatient). You guys rock. I'm praying this is the Linaro bad boy we've been hearing about. Thanks guys! I'm so hooked on flashing (read: Full Throttle) that I've bought a website that I'm aiming to help dev's with download space....rom reviews...etc. It's not up yet but it's Androidchicken.com. Just a funny picture I made up for now. I'm working on it in spare time. Hope to one day soon host some Full Throttle roms. Hell, have an entire section devoted to Full Throttle. Thanks again for the hard work!
  • vtwinbmx likes this
My Razr is sharp thanks to Droidrzr.com, I will cut you with it if I must.
#17 ifonekillr
ifonekillr
  • 56 posts
  • LocationIndiana
Posted 19 October 2012 - 06:34 PM
Also, vtwin, can you recommend a really good Nexus S 4g rom for my friends Nexus I'm flashing for him? I put Slim Bean on it but data stays at 1x and well, can't have that. Pointing me in the right direction would be much appreciated.
#18 saophen
saophen
Posted 19 October 2012 - 09:09 PM
Hmm I am having some issues with this rom, my camera doesn't work, it says camera has stopped working. Everything else seems to be working fine now besides that.. But I love the killer blue theme really slick and smooth!
#19 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 19 October 2012 - 11:13 PM
Will the center clock mod from high octane work with this?
Sent from my XT912 using Xparent SkyBlue Tapatalk 2
#20 Maxxaholic
Maxxaholic
  • 628 posts
Posted 19 October 2012 - 11:16 PM
Try camera effects from Google play store. I use it on another ft rom. Doesn't have panoramic but it works and has flash.
Also tagged with one or more of these keywords: cm, aokp, ics, full throttle
