Did you try changing the font size in system settings?
Yes, HUGE still isn't big enough. And the notification menu, etc. doesn't change. Oh well........
Posted 10 December 2012 - 06:50 AM
Proud father of a US Marine
Posted 10 December 2012 - 10:33 AM
Posted 15 December 2012 - 11:12 AM
Posted 08 January 2013 - 05:47 PM
Posted 08 January 2013 - 06:46 PM
It works just fine on Batakang 1.00, that's what I'm currently running. Did you reboot after flash?No go on 1.00. Missing status and Nav bars
Sent from my DROID RAZR HD
This theme will work on stock based roms that are not deodexed.I really like this theme will u guys tell me if it'll work on any ROMs besides the stock .39 n .41?
Posted 08 January 2013 - 08:30 PM
Posted 09 January 2013 - 10:35 AM
I flashed on batakang but my icons arent themed
Posted 10 January 2013 - 06:00 AM
well where is it?because the icon pack wasn't included.
Sent from my RAZR MAXX HD using Tapatalk 2™
Posted 10 January 2013 - 06:32 AM
Posted 11 January 2013 - 08:33 PM
Posted 12 January 2013 - 05:53 AM
Wats it called?
If you are talking about the last screen shot that bignadad uploaded, the icons used on the bottom row are Tha Tech icons made by Tha Phlash which you can get in Tha Ultimate Icon app on the market.
Posted 12 January 2013 - 03:02 PM
advice taken...and I'm sorry...thanks for your advice and helpI see you are new, let me offer a small piece of advice. Before you ask a question where others have to search for information for you, try doing your own search, and then asking if you still cannot find the info. You should be able to hit ctrl+F in your browser window and it will bring up a search bar, type in "icon" and hit enter and it will search the entire page you are on for that word. Considering this thread is only 3 pages long this entire process would take maybe 2 minutes max if you are on a very slow connection.
With that said, here is the answer you are looking for, and it was on page 2 of this thread.
Posted 12 January 2013 - 03:16 PM
Wats it called?
Posted 28 January 2013 - 07:33 PM
Posted 28 January 2013 - 11:28 PM
OK sorry but I have a noob question...I'm a little confused about the process of putting the stock rom on a rom slot in safe strap. I looked at the post in the other link but it is describing the process with the 9.39 update not the 9.41 update. So the way I'm reading it the process would be:
Reboot into safe strap recovery
Make a backup of stock rom
Create a rom slot of at least 2gb
Activate the new rom slot
Restore the backed up stock rom to the newly activated rom slot
Then I can flash the theme from there
Is this correct?
I used the mattlgroff utility to flash back to stock ics then rooted & protected & took the OTAs to JB
Again I'm sorry to post such a noob question but I really want this theme!
Posted 29 January 2013 - 07:38 AM
yes that is correct. and just wipe cache and dalvik, then flash the theme and reboot system~ profit!
Posted 29 January 2013 - 02:29 PM
Posted 30 January 2013 - 02:11 PM
Went ahead and did, loving it so far! Thanks BigDx!
Is the Gmail not blacked out anymore? I read it was, then saw it was "fixed", wasn't sure if that meant its not blacked out anymore
Posted 30 January 2013 - 06:54 PM
it should be blacked out, chances are u had a version that is different than the one included in the theme. u might try and remove gmail from ur system/app directory, and data/apps, and then flash the ROM. BTW, if u want a fully dark experience., I have a Black Widow theme, and if u want a custom ROM that is darkkkk, I have 2 of those to choose from as well.
Posted 30 January 2013 - 06:58 PM
Thanks for the heads up. So I need to uninstall Gmail & reflash the theme? Or is it possible to just flash the right Gmail?
