[Theme] Bigdx Jelly Bean Extreme For Droid Razr Hd Stock Odex Rom
#41
Posted 12 November 2012 - 04:30 PM
#43
Posted 13 November 2012 - 01:15 PM
Would love to try it but not able to get the file on the safestrap thread to add another rom-slot.11-13-2012 / v5
Blacked out the following apps
-Talk, Email
-Fixed blacked out Gmail and updated to version 4.2
#44
Posted 13 November 2012 - 02:09 PM
Quadjacks here you go had to dig it up off my sd card.
-tapped from my RAZR maxx HD with Safestrap
- quadjacks likes this
#45
Posted 14 November 2012 - 06:53 AM
Thanks!Quadjacks here you go
#47 Guest_24v_*
Posted 15 November 2012 - 12:58 PM
Do you have 1% working on the battery icons?
- Bignadad likes this
#48
Posted 15 November 2012 - 08:40 PM
#49
Posted 25 November 2012 - 10:02 PM
#50
Posted 28 November 2012 - 06:33 AM
it won't work with that ROM. Vitreous is deodexed. This is for an odex ROM.Anyone know if this will work with the Viterous Rom floating around? The only issue I see is the Odex/Deodex difference. Does it matter that much?
I'd like to see this for vitreous. But I can't do it myself.
Sent from my DROID RAZR HD
#51
Posted 29 November 2012 - 05:24 AM
#52
Posted 05 December 2012 - 06:33 PM
#55
Posted 09 December 2012 - 09:44 AM
#56
Posted 09 December 2012 - 10:04 AM
#57 Guest_24v_*
Posted 09 December 2012 - 10:18 AM
Those are icons more than likely from an icon pack that Big has in the play store.Im sorry for the silly question, but how did you get the bottom widgets to look like that, mine are just plain circles
You use a launcher like apex, adw, golauncher, etc. Then you get icon packs for them and you can apply them as themes in the settings for the launcher, or apply them individually to icons on the home screen.
Hopefully he can stop in and tell you which cause he has a ton.
#58
Posted 10 December 2012 - 02:56 AM
If you are talking about the last screen shot that bignadad uploaded, the icons used on the bottom row are Tha Tech icons made by Tha Phlash which you can get in Tha Ultimate Icon app on the market.
#59
Posted 10 December 2012 - 05:24 AM
If I use APEX, for example, will the icon/text size look more phonelike, with the tablet functionality?
EDIT: the answer is yes, does help.
The font is still a killer for me.
Proud father of a US Marine
#60
Posted 10 December 2012 - 06:40 AM
