Droid Razr Hd Xt926 Firmwares Superthread
31 replies to this topic
#1 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
  • LocationLa Rioja - Argentina
Posted 18 October 2012 - 10:25 AM
proudly presents "DROID RAZR HD XT926 firmwares Superthread"!
!!!USE AT YOUR OWN RISK!!!
ALL FIRMWARES ARE UNLOCKED. FLASHING A FIRMWARE WILL NOT UNLOCK YOUR PHONE!!!
!ALL FILES ARE OEM MOTOROLA!
DROID RAZR HD XT926
Branding: Verizon USA
Version: 7.7.1Q-144_VQW_S3-34 FULL
Android Version: 4.0.4
Bootloader Version: N/A
Webtop version: WT-3.0.0
Requires RSD Lite 6.0
How to request for a firmware:
Submit the following files (using adb pull):
/system/default.prop
/system/build.prop
MSU.txt of Motorola Software Update (You only need the version of Flex)
Configuration > About phone > Webtop version
NOTE: I only MIGHT find that firmware or newer version of it.
Total Credits to "
  • mattlgroff and kanagadeepan like this
Firmware Team: Kent_lkc - Kwachu - daywalker04 - Pzyduck - Skrilax_CZ - toto221
#2 Skrilax_CZ
Skrilax_CZ
    Firmware Team
Posted 18 October 2012 - 11:02 AM
Here:
  • Pzyduck likes this
#3 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
Posted 18 October 2012 - 11:05 AM
Thanks bro :D
#4 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 18 October 2012 - 11:06 AM
hello system.img!
#5 Droid Commando
Droid Commando
  • 6 posts
Posted 18 October 2012 - 03:14 PM
#6 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 18 October 2012 - 03:55 PM
Moved to the Verizon DROID RAZR HD section. Thanks firmware team!
#7 tucstwo
  • Google+:tucstwo@gmail.com
Posted 18 October 2012 - 06:41 PM
merged redundant stuff :)
#8 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
Posted 18 October 2012 - 09:17 PM
#9 tucstwo
Posted 19 October 2012 - 12:38 PM
It's a post from a redundant thread another user made which was merged into yours. Ignore ;)
#10 Smizzo
Smizzo
Posted 21 November 2012 - 08:45 AM
So if I flash this, will it give my RAZR Maxx HD Webtop abilities? I see that it says WT-3.0.0 is included.
#11 htowngtr
htowngtr
  • 25 posts
  • Twitter:htowngator
  • Current Device(s):RAZR HD Developer
Posted 22 March 2013 - 07:27 AM
So this includes the sbf files for 4.1.1 and 4.1.2?
#12 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 23 March 2013 - 07:16 AM
The first post is only for 4.0.4, but the link in the second(and 5th post) has all 3 firmware files for download... 4.0.4, 4.1.1 and 4.1.2
Always good to have all 3 just in case.
#13 beholder88
beholder88
  • 17 posts
  • LocationPennsylvania
  • Current Device(s):RAZR MAXX HD Employee Edition
Posted 07 May 2013 - 06:50 AM
"Requires Moto Android (De)packer 1.4 to edit."
So where can one obtain this tool?
#14 mhous33
mhous33
  • 480 posts
Posted 07 May 2013 - 11:59 AM
Pzyduck includes that in all his posts. 1.3 is the latest version publicly available and works only on sbf files, not fxz files.
#15 Pzyduck
Pzyduck
    Firmware Team
  • 45 posts
  • Twitter:Pzyduck
Posted 17 July 2013 - 11:17 PM
New Update, Firmware Available by Firmware Team
sbfdownload.droid-developers.org/vanquish/VRZ_XT926_9.8.1Q-79-1_CFC.xml.zip
  • Memnoch73 likes this
#16 lordraikalo
lordraikalo
Posted 19 July 2013 - 06:55 PM
I read that the unlock exploit was patched in the new 9.8.1Q-79 soak update, so don't update if you aren't unlocked and still want to.
#17 kanagadeepan
kanagadeepan
  • 13 posts
  • Twitter:kanagadeepan
  • Google+:kanagadeepan
Posted 11 August 2014 - 06:48 AM
Thanks for the link (
) friends... It has all firmware links incl latest 4.4.2.. My friend has soft-bricked his RazrMAXX_HD.. Phone bootloops, but can reach bootloader mode.. He was earlier in 4.1.2 with bl hack patched firmware... He doesn't need root..
Now my question is, to un-brick that phone, can I just download the 741+MB 4.4.2 and flash it via RSDLite? Or any other precautions has to be taken?
Thanks friends, in advance...
#18 livinginkaos
Posted 11 August 2014 - 07:04 AM
Nope, that should do it.
  • kanagadeepan likes this
#19 kanagadeepan
kanagadeepan
  • 13 posts
Posted 11 August 2014 - 07:22 AM
Thanks Admin... Why I am asking is, on my DroidMAXX, I have to remove the lines saying "getvar", before flashing...
Another question... Phone needs to be in USB Debugging enabled in Dev options or NOT?? I don't know, whether he has enabled that option, earlier...
Thanks again friends...
#20 livinginkaos
Posted 11 August 2014 - 08:11 AM
Ah, well, you are correct with the getvar lines.  The easier thing to do it to use SamuriHL's RSD Flasher to take care of this.  It will take care of that for you.  As for debugging, no, that has no bearing on fastboot mode, which is where you flash fxz's.
  • kanagadeepan, SamuriHL, johnthehillbilly and 1 other like this
