[ROM][XT926][4.4.4][Kit-Kat] LiquidSmooth 3.1/3.2
100 replies to this topic
#21 cmh714
Posted 06 July 2014 - 08:06 AM
we have plenty of tools here from Sam that does the same....not sure why you seem to be confused...
  • watson387 likes this
#22 Not_A_Dev
Not_A_Dev
  • 66 posts
  • Current Device(s):Motorola Droid Razr HD Maxx
Posted 06 July 2014 - 08:44 AM
My device (XT926) was unlocked a while ago, and wasn't subject to the recent Towelroot goodness that many Razr HD owners came to enjoy a couple of weeks ago. As such, there was no need for me to flash back to VZW's KitKat stock firmware (which evidently also updates the bootloader to KK). My conundrum started with the most recent LS update that required an updated bootloader, and everyone's universal chant was "just update your bootloader". Fine. "Please tell me how to do it", was my reaction to that. Sorry, didn't mean to be a PITA, but I've learned from other people's misery that the slightest flashing fauxpas with these devices can lead to a brick.
#23 cmh714
Posted 06 July 2014 - 08:51 AM
Sorry didnt mean it that way....we havent really had many bricks especially with an unlocked bootloader
#24 watson387
watson387
  • 128 posts
Posted 06 July 2014 - 08:56 AM
Dude you're definitely not being a pain in the rear end. My response was the only good way I knew to help you. I'm not the best person to ask. Lol ;)
#25 pegs520
pegs520
  • 69 posts
  • Twitter:pegs520
  • Locationutica
  • Current Device(s):motorola droid razr maxx hd
Posted 06 July 2014 - 10:05 AM
My device had an unlocked bootloader already, so I'm not sure how the Towelroot thread applies here. But thanks anyway. Another poster on the G+ already provided exactly what I'm looking for, and for those that are interested in updating their bootloaders to KK, you might want to take a look here:
Thanks! This is exactly what I was looking for. I couldn't find much on updating the bootloader from googling, so this helps big time.
Update: just wanted to give people the heads up that this worked. I downloaded the zip, edited the XML, put it thru rsd lite, and then had to fastboot the twrp IMG. Not too many problems.
I decided to go with kitstalk 4.4.4, but it still works like a charm.
  • Not_A_Dev likes this
#26 andrusa
andrusa
  • 17 posts
Posted 06 July 2014 - 09:28 PM
Hi guys,
Can someone tell me what would be the best rom in terms of battery for our Maxxs? 'Cause I am trying right now the Kitstalk, it works very good but I'm dissatisfied with the battery, I can squeeze only ~1h for display and ~1h for calls by being in 3G mode for a period of 24h :( (I have always Mobile Data and Sync turned on)  By the way what are your stats for battery?
#27 Noigel
Noigel
  • 197 posts
  • LocationUkraine, Ivano-Frankivs`k
  • Current Device(s):Motorola Razr M XT907 / Motorola Razr I XT890
Posted 07 July 2014 - 12:20 AM
Hi guys,
I have 24+H on my Razr M (2000mA battery) with 3-4H screentime an 1-1.5 H calls... But - 2G only network.
One question - have anybody issues with mic? I have the next - my subscriber can`t hear me  sometimes..
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
post-103018-0-11429500-1388984908_thumb.
#28 andrusa
andrusa
  • 17 posts
Posted 07 July 2014 - 01:28 AM
Still did you try any other roms did you see any differences?
#29 watson387
watson387
  • 128 posts
Posted 07 July 2014 - 04:14 AM
I get really good battery life with Gummy. I get 15 hours or so in a really bad signal area.
  • andrusa likes this
#30 Noigel
Noigel
  • 197 posts
Posted 07 July 2014 - 04:17 AM
I tried KitStalk and have the same issues with mic... and  worst battery life..
#31 Not_A_Dev
Not_A_Dev
  • 66 posts
Posted 07 July 2014 - 06:37 PM
Finally running the 7-5 build on the 3.4 Kernel. Nice! But Bluetooth doesn't seem to recognize my Plantronics headset. :/ Anybody else experience this?
#32 andrusa
andrusa
  • 17 posts
Posted 07 July 2014 - 10:44 PM
Thanks mate! ;)
Any other experience regarding battery, anyone? :)
#33 Noigel
Noigel
  • 197 posts
Posted 08 July 2014 - 02:42 AM
Thanks mate! ;)
About mic issues - I found when it happens!!!
It happens when you use speaker in conversation and then switch to mic.. And then subscriber can't hear you... I tested it..
If I don`t use speaker then everything is normal, but if I turn it on once it disable mic to next reboot...
I posted about it to official G+ community.
#34 jlang11
jlang11
  • 29 posts
  • LocationFL
  • Current Device(s):RAZR HD MAXX
Posted 12 July 2014 - 09:06 AM
Noob question. xt926, on the "old" bootloader unlocked with root runnng twrp 2701 and SlimKat 4.4.2. If I install this "new" bootloader, can I still run the older ROMS that run on 3.0 bootloader till some more ROMS that are on the new BL come ouot stable??
Thanks for the help. Much appreciated!!
#35 Noigel
Noigel
  • 197 posts
Posted 13 July 2014 - 04:11 AM
No - if you can`t install 3.0 builds. You must downgrate for it.
P.S. 3.1. release is available for now!  (KK BL)
#36 cmh714
Posted 13 July 2014 - 03:42 PM
Having some app install issues on the Official 3.1....some of my games wont install, getting the Error couldnt install on USB storage or SD Card.
off to find a solution, unless someone has one already :)
EDIT: One very unperfect workaround is to dismount the external sdcard, install apps and remount sdcard.
Someone suggested a reformat of the sdcard in the phone, but havent tried that one yet.
#37 Sleehrat00
Sleehrat00
    Moot Consumer
  • 90 posts
  • LocationNorth Carolina
Posted 13 July 2014 - 06:51 PM
Before I take the plunge and clean flash again, goes the moto msm8960 official 3.1 version fix the speakerphone bug where if during a call you initialize speakerphone, you can no longer use the handset mic until rebooted???
Current consumer, but hopefully one-day purveyor, of high quality moot products.
#38 cmh714
Posted 13 July 2014 - 06:57 PM
just tested and yep that does happen
#39 nu2droid
nu2droid
  • 18 posts
Posted 14 July 2014 - 02:40 PM
i have a problem with my BT audio and the HDMI audio too
#40 jlstark1
jlstark1
  • 6 posts
Posted 15 July 2014 - 11:58 AM
Anybody else having issues with their GPS? I just installed the LS--KK-v3.1-official with a 7/12/14 build date and tried to use google maps navigation today and continually lost the GPS.
I started out on LS just a few days ago on one of the nightly builds. I liked it so much that when I seen the official build I updated right away. However, I never tried the GPS on the nightly build so I don't know if it was working then or not.
Just wondering if anyone else was experiencing difficulty locking on a GPS signal?
Thanks in advance!
