yes xp should be fine
in need of help badly
#41
Posted 04 July 2014 - 05:29 PM
#42
- cmh714 likes this
#43
Posted 04 July 2014 - 05:45 PM
i will test it now on windows xp
(currently installing moto drivers for xp)
#44
Posted 04 July 2014 - 06:02 PM
this is sad... still not working on windows xp
i dont know what to do...
#45
Posted 04 July 2014 - 06:06 PM
im just wondering if this is okay
rsd lite shows this
should i be worried in that N/A parts
#46
Posted 04 July 2014 - 06:40 PM
Sent from my XT1053 using Tapatalk
- inkcorey likes this
#47
Posted 04 July 2014 - 07:10 PM
I see the issue and I'm stuck in the rain in a camper with no pc. Stop what you are doing and get the right fxz. Enough with the hom fastboot and any other nonsense. Use my rsd flasher with the proper fxz.
oh sorry about that..
my mistake, i was using the VZW_XT926_4.4.2-KDA20.62-10.1_CFC_1FF.xml file from your other thread... my bad
is it safe to download and use this fxz?
from
EDIT : currently downloading the FXZ
Edited by inkcorey, 04 July 2014 - 07:22 PM.
#48
Posted 04 July 2014 - 07:53 PM
#49
Posted 04 July 2014 - 08:16 PM
hmm now im kinda lost.. what fxz should i use?Um no. You need to be using 4.4.2. Anything older will fail to flash. Your post above shows 9.18.94.
coz im using VZW_XT926_4.4.2-KDA20.62-10.1_CFC_1FF.xml but it fails
#50
Posted 04 July 2014 - 08:28 PM
#51
Posted 05 July 2014 - 01:27 AM
#52
Posted 05 July 2014 - 03:45 AM
Correct fxz. Serious pc/usb/cable/driver problem. And it's not windows 8.1 that's the problem. I develop on it. Fastboot won't help either. It's something on your machine.
#53
Posted 05 July 2014 - 04:32 AM
Sent from my GT-I9505G using Tapatalk
#54
Posted 05 July 2014 - 05:46 AM
#55
Posted 05 July 2014 - 05:58 AM
Could be a badly worn mUSB port on the phone. Does it have problems charging at all? Sent from my S-Offed One M8
no known problems in charging the device sir. should i try it with jigs?
Also tagged with one or more of these keywords: XT926, encryption unsuccessful, locked, failed update
