in need of help badly
XT926 encryption unsuccessful locked failed update
54 replies to this topic
#21 cmh714
Posted 04 July 2014 - 07:35 AM
Switch to Sams House of Moto 2.3 here:
its similar but generates the scripts to be used with fastboot.exe
For you to get to KK correctly you will need to use the Keep Data script which will keep youre data, while flashing the rest of the rom.
  • inkcorey likes this
#22 inkcorey
inkcorey
  • 31 posts
  • LocationPhilippines
  • Current Device(s):RAZR MAXX HD
Posted 04 July 2014 - 07:36 AM
thank you, im gonna try this now
#23 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 08:12 AM
noooo :(
#24 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 04 July 2014 - 08:33 AM
Right click on the exe to launch the house of moto program and run it in administrator mode. That should allow it to run thoses processes.
Sent from my G Harmony v2.8 using Tapatalk 2
#25 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 08:57 AM
i tried it on administrator mode, now console says file not found.
i cant see the xml scripts... but without running admin mode, i can see those scripts (full, keep data, universal)
whats wrong in here :(
#26 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 04 July 2014 - 09:13 AM
OK forgive the screenshots since they where taken using my Linux side, but the setup should be the same. You are going to need to make sure that it is setup exactly like this with the exception of the version you are trying to restore. As you can tell the last time I used it was messing around with MR2 4.1.2. This is also HOM 2.0 and not the latest so the setup should be about the same. The .bat file is what you will be using in Administrator mode not a .exe file, sorry that is what I get for thinking, I am use to using .sh with Linux. Run the HouseOfMoto.bat in the Administrator mode, and choose KEEP-DATA_xt926 when it ask you in the command prop. You have to make sure that the setup for the HOM is setup exactly how Sam states it or else it will not work. Refer to screenshots below for that.
Good Luck.
Screenshot%20from%202014-07-04%2013%3A47
Root of the FXZ_xt926 Directory.
The folder named Windows has the adb and fastboot binary for snapdragon devices. That is also needed if you don't have it already. Available for download over on Sams HOM tread.
Screenshot%20from%202014-07-04%2014%3A04
#27 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 09:26 AM
Good Luck.
we have the same directory setup sir, but when i run the bat file in admin mode this pops up
#28 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 09:31 AM
just double clicking it gives me this
#29 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 04 July 2014 - 10:25 AM
When you run through admin you will have to select the change device option so it will recognize the xt926 files in use.
#30 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 01:22 PM
ive done it before but still have the same results :(
#31 cmh714
Posted 04 July 2014 - 01:25 PM
are you using Win8?
#32 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 01:28 PM
are you using Win8?
yes sir, win 8.1
#33 johnthehillbilly
Posted 04 July 2014 - 01:33 PM
There's the issue..... Do you have access to a win 7 machine..... Or you can download a Linux distro (live CD) and run it within it....:)
#34 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 01:38 PM
There's the issue..... Do you have access to a win 7 machine..... Or you can download a Linux distro (live CD) and run it within it.... :)
ouch it's a win8 problem..
i can have access to a win 7 machine but not for now. omg
what is the problem with win8 failing the process?
i sure hope that all will be fine after i do this in win7 (fingers crossed) :)
#35 cmh714
Posted 04 July 2014 - 01:52 PM
I sort of noticed from one of your screen shots....win8 has UAC and other issues that we havent been able to solve simply and consistently.
You may find some suggestions by searching, but like I said not sure of how successful it would be.
#36 johnthehillbilly
Posted 04 July 2014 - 01:56 PM
If you grab a Linux live CD (Ubuntu or mint are the most common) and boot with it....(you can do it without affecting windows) ..... Then run the house of moto in Linux :)
#37 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 01:58 PM
ah yea, win8 has this issues, i tried disabling and tweaking uac but still no good..
anyways, ill update you guys again after i test it on a win7 environment :)
thank you
#38 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 02:00 PM
hmmm. i dont know where i can get it, ill search google :D
#39 johnthehillbilly
Posted 04 July 2014 - 02:23 PM
Yes.... Simply Google Ubuntu or Linux mint whichever you choose....:) there are download links typically right on the front page......:)
#40 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 05:11 PM
hmmm just a quick question... does the process work on windows xp?
Also tagged with one or more of these keywords: XT926, encryption unsuccessful, locked, failed update
