in need of help badly
XT926 encryption unsuccessful locked failed update
54 replies to this topic
#1 inkcorey
inkcorey
  • 31 posts
  • LocationPhilippines
  • Current Device(s):RAZR MAXX HD
Posted 02 July 2014 - 11:44 PM
good day!!
first of all, i am new to this forum, and also new to phone modding. i found this forum while searching for a fix in my phone problem.
i have a droid razr hd. it is on running on stock, i havent rooted or unlocked it. it was running on jellybean with no problems at all. problems came when i tried to upgrade it to kitkat, and accidentally the internet connection stopped because of power failure, so the update was cancelled and got messed up when i rebooted the phone and it show this encryption unsuccessful. i already tried to factory reset but still failed on booting past the encryption unsuccessful.i am afraid to try the methods posted in the forum coz im not sure of what to do and damage the phone so came here to ask for an advice how to revive my phone. thanks in advance :)
tried to open fastboot mode and took a screen shot,
#2 johnthehillbilly
Posted 03 July 2014 - 02:33 AM
..... Since you can get into fastboot you can follow the instructions in that thread and it should fix you right up......:):)
  • rickw and inkcorey like this
#3 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 03:15 AM
..... Since you can get into fastboot you can follow the instructions in that thread and it should fix you right up...... :):)
thanks sir for the reply.
i'm gonna try this now
#4 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 03:31 AM
..... Since you can get into fastboot you can follow the instructions in that thread and it should fix you right up...... :) :)
i tried it sir but it seems that there's a problem...
  • Attached File  1.jpg   135.61KB   51 downloads
#5 johnthehillbilly
Posted 03 July 2014 - 05:26 AM
Are your drivers up to date ....AND.... Are you using the Motorola (OEM) cable that came with the phone.......
  • rickw, cmh714 and inkcorey like this
#6 cmh714
Posted 03 July 2014 - 05:27 AM
AND USB 2.0 only
  • rickw, johnthehillbilly and inkcorey like this
#7 livinginkaos
Posted 03 July 2014 - 06:27 AM
And does your battery still show OK in the fastboot screen like it did on the screen shot?
#8 cmh714
Posted 03 July 2014 - 06:30 AM
And if all that doesnt work, then you need to try the fastboot method...
Maligayang pagdating to our site :)
#9 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 07:36 AM
drivers are up to date...alrdy installed the motorola manager that came with the phone and updated it. well the cable, came from my other phone.
AND USB 2.0 only
yes usb 2.0...  tried 3.0 but it doesnt work
battery is charged up pretty well
salamat po sa pagbati!  thanks for welcoming me! XD
i already read Mr. SamuiHL's thread
(yes all 15 pages of the thread, but the moto cable is unavailable so i just tried my luck with the other cable that i have)
ill try the fastboot method after i find the original cable of the phone. this phone was given to me by my friend from the u.s. so ill just have to get the cable from him later
thanks for the fast reply guys..
ill give you an update after i get the original cable :D
#10 cmh714
Posted 03 July 2014 - 07:39 AM
Basically you want an original Moto OEM cable for a Moto device. It does make a difference generally....
  • inkcorey likes this
#11 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 07:46 AM
ill keep that in mind sir. ill just have to get the original cable from my friend :D
#12 johnthehillbilly
Posted 03 July 2014 - 08:09 AM
Uninstall the moto device manager and use these drivers.....
#13 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 03:31 PM
thank you sir, i'll add this into my tools :)
#14 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 03:49 PM
hmmm wait sir, i think what i have is more updated than what you gave :)
i have 3.0 moto drivers. on the link is only 2.0 moto drivers
#15 johnthehillbilly
Posted 03 July 2014 - 03:56 PM
Indeed..... But, most of the time, the drivers included with device manager do not play nice with adb and fastboot.......
  • cmh714 and inkcorey like this
#16 inkcorey
inkcorey
  • 31 posts
Posted 03 July 2014 - 06:42 PM
ahhhh i see.. compatibility issues if i may say...
well i'll update you guys later after i have the cable :D
tyy
#17 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 07:13 AM
i got the original moto cable... but it still fails :( oh no
what should i do :(
#18 cmh714
Posted 04 July 2014 - 07:16 AM
Sounds like you need to try with a different PC.
#19 johnthehillbilly
Posted 04 July 2014 - 07:20 AM
Did you try fastboot instead of rsdlite...... ?
#20 inkcorey
inkcorey
  • 31 posts
Posted 04 July 2014 - 07:30 AM
hmmm
hmmm.. could you guide me on how to do the other process? or just some links
thanks, your replys are very much appreciated :)
Also tagged with one or more of these keywords: XT926, encryption unsuccessful, locked, failed update
